Do you have to use a Vortech BPV with the kit
Old Jul 31, 2008 | 08:58 AM
turtle1678's Avatar
turtle1678
Default Do you have to use a Vortech BPV with the kit
Do I have to use a Vortech BPV or what else do you guys recommend
Old Jul 31, 2008 | 09:52 AM
350Z400rwhp's Avatar
350Z400rwhp
Why wouldn't you want to use the Vortech BPV? If it ain't broke why fix it? Don't complicate things, FI is already complicated enough.
Old Jul 31, 2008 | 10:09 AM
frankie945's Avatar
frankie945
I have heard the Vortech BPV is really good, not to many problems with them. I think I have seen guys with Hks ssqv bov's on there vortech setups.TRY SEARCHING.
turtle1678's Avatar
turtle1678
Haha I think its broke thats why Im wondering
Old Jul 31, 2008 | 10:24 AM
SnyperZ's Avatar
SnyperZ
changing it will do nothing to your cars peformance...so it would be a waste of money to change it.
Old Jul 31, 2008 | 10:34 AM
turtle1678's Avatar
turtle1678
well let me ask this how can I be totally sure that its broken, do I just have to jack it up and look under the car?? What should I look for
Old Jul 31, 2008 | 10:36 AM
SnyperZ's Avatar
SnyperZ
...what would make you think it was broken? Are you not making any boost? When you let off the gas you can hear it purge right?
Old Jul 31, 2008 | 10:37 AM
turtle1678's Avatar
turtle1678
I get some air escaping from the blower filter when it lets air out so Im assuming its not functioning correctly
Old Jul 31, 2008 | 10:40 AM
turtle1678's Avatar
turtle1678
unless thats normal
Old Jul 31, 2008 | 10:43 AM
iStan's Avatar
iStan
ZR
Loosen the top nut and loosen bolt. It'll open up a little earlier. You're getting compressor surge. Just play with the BPV until it no longer surges out the Filter.
Old Jul 31, 2008 | 10:48 AM
turtle1678's Avatar
turtle1678
so thats all I have to do? I have asked like 10 different shops and they say its probly bad I've never seen that happen before. So just loosen that jam nut and then the bolt, is there anything else I should know about it when adjusting it?
Old Jul 31, 2008 | 11:15 AM
iStan's Avatar
iStan
ZR
You'll have to play with it for a bit until you get it. I think normal threads showing above the locking nut is 6-7 threads?
Old Jul 31, 2008 | 12:12 PM
booger's Avatar
booger
Turtle
You seem to be a worry wart !
Any time you are ....NOT... boosting the car , air will be coming out of that bypass valve . When you give it enough gas and vacuum drops , it will close and boost will start to build . There should be 6 to 9 threads showing above the nut on the adjustment bolt .
Old Jul 31, 2008 | 01:09 PM
turtle1678's Avatar
turtle1678
If you went through half of what I did when Nissan screwed up my car you would worry about things too, plus Im new to all the FI and I am finally understanding everything. But let me get this straight when my car is at idle the bpv will be open and when I give it gas it will close correct? there should be 6-9 threads showing, and how often does that breather on the BPV need to be changed
Old Jul 31, 2008 | 01:14 PM
frankie945's Avatar
frankie945
It's going to blow till you hit enough vacum then close. Should close around 4000 or so depending on your pulley.
Old Jul 31, 2008 | 01:24 PM
turtle1678's Avatar
turtle1678
so if I take it off the car and look at it will it be open or closed with no vac hooked up to it
Old Jul 31, 2008 | 01:33 PM
frankie945's Avatar
frankie945
On my procharger the Bpv was open till vacum closed it to build boost.
Old Jul 31, 2008 | 02:05 PM
05Z33's Avatar
05Z33
That's how it work.
Old Jul 31, 2008 | 03:16 PM
turtle1678's Avatar
turtle1678
I got it now
Old Jul 31, 2008 | 03:42 PM
frankie945's Avatar
frankie945
I guess you don't call yourself turtle for nothing, lol Good job man, were all still learning thats what the forums are for.
