C-2 Procharger Belts and Bearings
Old Aug 6, 2008 | 10:41 AM
masterbunta's Avatar
masterbunta
Default C-2 Procharger Belts and Bearings
I have found a place to get the 2 belts for the C-2 Procharger for $33 and $28 a piece as well as the bearings to rebuild the pulleys that are located in the front bracket. Search those part numbers in google and you will find them.
(Quatity)
(1) 8808MGT30 Front Belt
(1) 5608MGT30 Rear Belt
(2) 203vv, 62032RS, 62032RD (all the same bearing, I choose the 62032RD)
(2) 6205RD, 62052RD (all the same bearing, I choose the 62052RD)
For the small drive belt pulleys
(4) 203vv, 62032RS, 62032RD (I choose the 62032RD)
(2) 6003LB, 6003RS or 6003RD (I choose the 6003RD)
RS means it has a standard seal on the side.
RD means it has a extremly light contact seal on the side.
LB means there is no seal contact on the sides.
They will both work just fine and can be ordered from many bearing supply houses.
Just an FYI if you are going to DIY
Old Oct 24, 2008 | 06:28 PM
zcar03's Avatar
zcar03
Will this work with a 9lb pulley?
Old Jul 3, 2018 | 05:41 PM
NissanZcrazy's Avatar
NissanZcrazy
Default Awesome!!
Im aware this is a really old post but thank you to the OP for taking the time to post this.Saved me a lot of down time!
Anyone have the part numbers the C2 internal bearings and seals as well
Obadabot
Jun 18, 2023 11:31 PM
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
samansharif
Sep 25, 2015 12:31 PM
