my A/F = 7.4
Old Aug 7, 2008 | 06:58 PM
Cannysage's Avatar
Cannysage
Default my A/F = 7.4
I went to the drag strip and did a burnout to warm up the tires. My wideband started going wacko (E 8 code?) and not it read 7.4 at all times. Did my ecu put my car on safe mode?
Old Aug 7, 2008 | 06:59 PM
doug's Avatar
doug
if your car still goes over 2500 RPMS .. then i would say your wideband needs to be recalibrated..
what EMS do you have? if you have an F-Con you won't go into safe mode
Old Aug 7, 2008 | 07:00 PM
Cannysage's Avatar
Cannysage
I have unichip
Old Aug 7, 2008 | 07:04 PM
doug's Avatar
doug
well did it let you go over 2500 rpms? or you didn't try?
if you can't go over 2500 rpms.. have you checked your piping? usually if the charge pipe between the MAF and the TB or after the maf comes off.. it will put you in limp mode.. check all your piping and couplings first
Old Aug 7, 2008 | 07:06 PM
Cannysage's Avatar
Cannysage
it drives and sounds perfectly fine. It's not on limp mode. I can go full boost/rpm. I'm gonna go try to reset the wideband..
Old Aug 7, 2008 | 07:08 PM
doug's Avatar
doug
recalibrate time ..
if your car was really at 7.4 it would be running super super rich and you would be puffing black smoke.. the car wouldn't even run.. it would start.. then it would be flooded with fuel and shut off
Old Aug 7, 2008 | 07:11 PM
diwun67's Avatar
diwun67
What kind of wideband?
Old Aug 7, 2008 | 07:28 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
From that description... Innovate. Time for recal or possibly a new sensor.
Old Aug 7, 2008 | 07:40 PM
Cannysage's Avatar
Cannysage
hmm.. I think recal. sounds about right. thanks for the input, yall. Yes, it's innovative. resetting didn't do anything.
Old Aug 7, 2008 | 08:06 PM
nomyth46's Avatar
nomyth46
how do you recalibrate them?
Old Aug 7, 2008 | 08:13 PM
diwun67's Avatar
diwun67
Get up to a good speed and let go of the gas. Once your gauge reads o2 20.X% hit the button 3 times quickly. It should start flashing "CAL". Hit it one more time as it's flashing "CAL" to calibrate. You have to be off the gas the whole time it's calibrating or else it'll screw up the calibration. It only takes a few seconds.
Old Aug 7, 2008 | 08:15 PM
Blackbird CPV35's Avatar
Blackbird CPV35
I thought this was a trick post and you converted to E85
Old Aug 7, 2008 | 08:55 PM
Cannysage's Avatar
Cannysage
I went for a drive and recalibrated the wideband. I had to do it a few times and it's back to normal!!
Old Aug 7, 2008 | 08:57 PM
Cannysage's Avatar
Cannysage
excellent post. not too many people know about this. Not sure if it's required, but you may have to hit the gas before hitting the button after the 'cal' blinking light. At least I did.
P.S. HAHAHA I Just figured out your avatar!
Old Aug 7, 2008 | 09:15 PM
SPRacing's Avatar
SPRacing
I just had the same problem. is it a recall?
Old Aug 7, 2008 | 09:49 PM
wannabuy350z's Avatar
wannabuy350z
your WB sensor is F'd common with innovate
Old Aug 8, 2008 | 12:23 AM
GTM's Avatar
GTM
The latest firmware fixes the common "E8" error, so as long as the ground are properly connected you will be ok.
Make sure to run the latest firmware, and always calibrate the sensor in free air to ensure accuracy.
Innovate is still the most accurate wide band on the market.
-George
Old Aug 8, 2008 | 05:06 AM
diwun67's Avatar
diwun67
No prob man Why did you have to hit the gas before calibrating?
Old Aug 8, 2008 | 06:52 AM
doug's Avatar
doug
good to hear
Old Aug 8, 2008 | 07:14 AM
DanielW's Avatar
DanielW
innovate wideband?
