Gauge/Vortech questions
Old Aug 19, 2008 | 08:46 AM
350z006's Avatar
350z006
Default Gauge/Vortech questions
I have an AEM UEGO Wideband for A/F, and Xline gauges for Oil temp and Boost that I need to install to go with my Vortech.
1) Do I have to create a new hole/bung before my cats for the Wideband gauge sensor?
2) I'm going to to buy an oil block adapter for the Oil Temp gauge; can I install the oil feed line for the Vortech on the block as well, so I don't have to re-plumb the oil pressure line (BTW, how many lines go out of a typical oil block adapter? I was thinking of using it for an oil cooler as well...)
3) Is this the where I need to hook up the mainfold vacumm hose for the SS box (see pic)? If not, where should I hook it up, and can I tee off the same line for my boost gauge?
Attached Thumbnails Gauge/Vortech questions-vacumm.jpg
Old Aug 19, 2008 | 09:05 AM
05Z33's Avatar
05Z33
1. yes you need to add a new hole for the wideband.
2. Depends on the oil block you buy 2-4.
3. yes you can hook it up right there and T off for the boost gauge.
Old Aug 19, 2008 | 02:45 PM
350z006's Avatar
350z006
Thanks muchas! BTW, did you have your car over at Performance Nissan? I could have sworn I saw a decked out Z w/ a playboy bunny when I took my car in for service a few months ago...
Old Aug 19, 2008 | 03:59 PM
05Z33's Avatar
05Z33
No, that's not my car. I'm in south Florida. I just like the Playboy car so it's my avatar.
Old Aug 19, 2008 | 06:54 PM
JonnyC's Avatar
JonnyC
Check out my build thread and you can see that I am successfully running the feed line out of the oil filter adapter plate.
https://my350z.com/forum/forced-induction/360295-jonnyc-s-vortech-build-and-tune-thread.html
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
