Powerlab 37r install begins tonight..
Old Aug 21, 2008 | 06:18 AM
westpak's Avatar
westpak
SFZCC
LOL what excitement you could start your own forum section with all of the threads on your build
4SHIZZIL's Avatar
4SHIZZIL
Originally Posted by thawk408
Its a special tool set. Looks like a circle with a 1/4 of it missing. You slide it on the pipes on the condensor then push it into the connection and it pop off.
release pressure first...wear goggles..lol
Old Aug 21, 2008 | 06:58 AM
thawk408's Avatar
thawk408
I forgot to release the pressure last time and I shat my pants when it popped off, lol. O wellz....
Old Aug 21, 2008 | 07:02 AM
SlideFox's Avatar
SlideFox
So your installing it on the stock block now, and your building the motor when?
Old Aug 21, 2008 | 07:03 AM
4SHIZZIL's Avatar
4SHIZZIL
yeah I knocked off one on accident install a Vortech on a friend covertible z....line was ghetto fixed from when he bought it used....
I thought I was going to die when that shizzil hit me in the face! It was funny though...neighbors coming outside to see what the noise was...lol
NEVER AGAIN THOUGH>....lol
Old Aug 21, 2008 | 07:25 AM
doug's Avatar
doug
Originally Posted by rrmedicx
for EMS did u mean VPro?
Haltec
Old Aug 21, 2008 | 09:47 AM
SnyperZ's Avatar
SnyperZ
Ok, I didn't have time to load all the pics up yesterday so ill do them tonight after all the piping is on. First off..so far for the MOST part its been extremely easy. Not till the very end (most likely from lack of sleep) did this kit test my patience. By far the hardest(only hard part) was lining up the up pipes and getting everything to fit properly. Clearance is null on this kit everywhere haha. They are all on and tighend up for the most part. Im not sure if maybe something isnt lined up right but theres about 1/2 mm between the DP and the fender..pretty much with everthing. Also it says something about using a pry bar to move a water line out of the way...anyone care to elaborate on this one? I should have everything finished tonight.
Old Aug 21, 2008 | 09:49 AM
DanielW's Avatar
DanielW
so is your motor built?
Old Aug 21, 2008 | 09:50 AM
SnyperZ's Avatar
SnyperZ
Did you go for the full kit or a tuner version...what are the specs of the parts ordered? Please share while we await your install pics.
I went with the 37r tuner kit. I then purchased the Haltech platinum, walbro 255(cjs twin/fuel return coming but im going to sit on it till i do the motor),and DW 850cc injectors. My plan right now is .3bar(about 4 psi) just to make sure EVERYTHING works properly, once everything is up and running good for about a month im going to take it all apart, check for any clearance issues(pipes hitting/melting things) and then build the motor and break it on on .3bar.
Oh yeah, thanks z2envy for the instructions! This kit can be installed with without instructions for the most part...but they did help clear a few things up.
Old Aug 21, 2008 | 10:14 AM
DanielW's Avatar
DanielW
what are your plans for tuning?
Old Aug 21, 2008 | 10:28 AM
SnyperZ's Avatar
SnyperZ
Pruven Performance or ICS in CT.
Im also going to look into purchasing one of those engine torque braces. Everythings so close and I know those are supposed to help limit sideways movement and might help the pipes from getting banged up against the side of the car and what not.
Old Aug 21, 2008 | 10:56 AM
350 Rookie's Avatar
350 Rookie
Why dont you come down to MRC with me. we'll go as civics, come back as lambos
oh ya and also, why dont you take progress pics. you know, pics as you go. not every little detail but just to give us an idea.
Old Aug 21, 2008 | 11:04 AM
SnyperZ's Avatar
SnyperZ
I did, im going to post them all up at once though..so they are easier to find. Jeffies post helped me alot. I used his as the instruction manual since I didn't get it until today from another member.
Old Aug 21, 2008 | 11:31 AM
SlideFox's Avatar
SlideFox
Are yous till coating the I/C and piping?
Old Aug 21, 2008 | 11:38 AM
DanielW's Avatar
DanielW
I would suggest MRC as well in your area. Even though Julian can be a D bag apparently he knows what the hell he's doing when it comes to tuning.
Old Aug 21, 2008 | 01:14 PM
rrmedicx's Avatar
rrmedicx
I would then recommend solid motor mounts. Also improves the response and feel for the car.
(Does add a touch of vibration, but the Ladies don't seem to complain...LOL)
Old Aug 21, 2008 | 01:44 PM
IntenseSales's Avatar
IntenseSales
Vendor - Former Vendor
Thumbs up
WOW, I had a good LOL on that one.... on another note its not a little vibration it is considerable. Just my 2 YEN
Old Aug 21, 2008 | 01:49 PM
  #38
boostintt's Avatar
boostintt
im in for the ride!!! i'll b starting my build soon too!!!
Old Aug 21, 2008 | 02:34 PM
  #39
IIQuickSilverII's Avatar
IIQuickSilverII
IMO solid motor mounts plus 3.79$ might just buy you about a gallon of 91 octane......that how much i think they are worth
Old Aug 21, 2008 | 03:24 PM
  #40
350zfun19's Avatar
350zfun19
i cant wait for pics!!!
