Any results from 3in downpipes to APS 3.5
Old Aug 22, 2008 | 06:18 AM
turismo's Avatar
turismo
Default Any results from 3in downpipes to APS 3.5
Just wondering if its worth purchasing the APS 3.5in dp's? Are there any benifits going to a 3.5dp to a dual 3in APS exhaust? Any sound difference? Thanx!
Old Aug 22, 2008 | 06:39 AM
coachk's Avatar
coachk
When I had the 2.5 APS test pipes going to my 2" Injen exhaust I put down 380ish whp. When I changed over to the APS 3.5 test pipes and the greddy evott( I expanded the bottleneck to 3") I put down 425 whp. The tune was slightly more agressive on the 425 whp, but everything else was the same. Hopefully that will give you some idea...I love the way it sounds with the greddy evott
exhaust
Old Aug 22, 2008 | 06:40 AM
thawk408's Avatar
thawk408
They wont fit your Greddy turbos without major modification to the downpipes. Not worth it at all. You wont see any power difference over 3 inch downpipes.
Old Aug 22, 2008 | 07:20 AM
App6MT's Avatar
App6MT
Originally Posted by thawk408
They wont fit your Greddy turbos without major modification to the downpipes. Not worth it at all. You wont see any power difference from 3 inch downpipes.
Do you mean you won't see any difference between a 3" and a 3.5"?
Old Aug 22, 2008 | 07:40 AM
thawk408's Avatar
thawk408
Not on these tiny turbos. If it was a larger framed turbo, then yes . But on these sized turbos you will be pressed to notice any real difference.
Old Aug 22, 2008 | 09:42 AM
turismo's Avatar
turismo
So whats the bottleneck? The turbos? Exhaust? So going from 3in to 3.5 into a APS dual 3in, wont make a difference?
Old Aug 22, 2008 | 10:01 AM
thawk408's Avatar
thawk408
The turbos can only flow so much. A 3inch downpipes off these turbos is plenty big. The 3.5 APS downpipes wont work on the Greddy turbos anyways, so no point in thinking about it.
coachk's Avatar
coachk
More flow = more power
Thawks right...APS no worky on Greddy
Old Aug 22, 2008 | 10:08 AM
thawk408's Avatar
thawk408
More flow ususally means more power, but when these turbos are already so small, 3 inch downpipes is more then sufficiant. If you could do back to back dynos of 3.5 vs 3 on greddy turbos I would put money on there being hardly a difference. Expecially a difference big enough to outweight the cost in $500 downpipes.
Old Aug 22, 2008 | 10:25 AM
coachk's Avatar
coachk
Agreed.........2.5 to 3.5 you can squeeze a little more out
Old Aug 22, 2008 | 05:04 PM
Cannysage's Avatar
Cannysage
I have 3.5" APS with greddy evoTT 3" (or 2.75, should I say). I don't think there's any benefits to this at 500-550whp.
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
bcoffee20
Nov 19, 2015 06:39 PM
