SS box vaccum line???
Old Sep 1, 2008 | 06:28 AM
agallardo's Avatar
agallardo
Default SS box vaccum line???
Hey guys, I just got done putting on my Vortech And I LOVE IT!!!! Anyway, I am trying to finish up so that I can take it out for a drive, but this vacuum hose off the Split second box is holding me back. I have been searching and sending pm's for the last hour and no reply yet, so figured if I posted I would get a quicker response. Anyway, there is a short vacuum hose with a t-fitting off the ss box, but its way too short to reach any other vacuum hose. It says to tap into the manifold, but doesnt reach? So I tried using the stock nipple off the top plenum, passenger side in the front, where N/A it comes with a vacuum rubber cap. And I ran a line from there to that fitting, and from that fitting to the FMU, tapped to the Bypass valve.
Is this right? Or anyone have any suggestions?
Old Sep 1, 2008 | 07:32 AM
superchargedg's Avatar
superchargedg
Damn Noobs
You should be fine with that.
Old Sep 1, 2008 | 08:44 AM
agallardo's Avatar
agallardo
My car, from time to time, the idle will drop a little, then pick up. Is there a way to fix that?
Old Sep 1, 2008 | 09:05 AM
ekelly36's Avatar
ekelly36
Does the cobb access port work with the vortech?
Old Sep 1, 2008 | 09:22 AM
JET MECH's Avatar
JET MECH
the line you are talking about on the SS box if i remmember correctly is for the manifold pressure reference reading. once it senses boost/positive pressure in you manifold it toggles a small relay in the SS box that in turn switches the vortech aux fuel pump on and off under boost and non boost conditions. when i was running the SS box on my enitial setup i ran that line directly to the upper plenum.
Old Sep 2, 2008 | 04:56 PM
agallardo's Avatar
agallardo
What about the idle? Is there a way to fix that? Its dies out a bit, but doesnt completely shut off...
Old Sep 2, 2008 | 06:36 PM
rookie's Avatar
rookie
Could be vacuum leak if it's almost stalling out.
Old Sep 2, 2008 | 08:03 PM
agallardo's Avatar
agallardo
Yeah, for the most part, it idles fine, and from time to time it would drop, but not shut off.
Old Sep 3, 2008 | 01:43 PM
SC 350Z's Avatar
SC 350Z
if you havent had it tuned yet the idle mite need to be set hgiher the supercharger puts unexpected load on the engine and it bogs a bit mite just need teh idle turned up but yet you have to flash the ecu for that,
Old Sep 4, 2008 | 09:41 AM
turtle1678's Avatar
turtle1678
I had the same idle problem I bought a blox vac distribution block for $30 on ebay and havent had the problem since, it takes like 10 min to install and works great seperate ports for everything
Old Sep 4, 2008 | 10:45 AM
ADMAN's Avatar
ADMAN
Yep. Stillen is the same way...
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
