Engine damper w/ TT's, anyone?
Old Sep 12, 2008 | 12:47 PM
350zzzgunnar's Avatar
350zzzgunnar
Default Engine damper w/ TT's, anyone?
Is there any engine damper that fits w/ TT's (suction pipes)?
Old Sep 12, 2008 | 02:38 PM
SIN3's Avatar
SIN3
i have the stillen on my g35 with a vortech...
Old Sep 12, 2008 | 05:49 PM
ToastZ's Avatar
ToastZ
Weapon-R, easy install, works great.
Old Sep 12, 2008 | 05:50 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
+1 When I make hard right turn, APS TT pipe rubs against my steering column... so I installed weapon-R, and it rubs less now.
Old Sep 12, 2008 | 11:25 PM
350zzzgunnar
thanx! i had newer heard of them. but it looks great i'd really appreciate some pics when installed
must be shure that it flush w/ the greddy twins
Old Sep 13, 2008 | 12:11 PM
bbs350z's Avatar
bbs350z
stillen wont fit with the greddy setup. the passenger side induction pipe is in the way
Old Sep 13, 2008 | 12:42 PM
ToastZ's Avatar
ToastZ
Here is a pic of a weapon-R installed on a G35 APS-TT.
Old Sep 13, 2008 | 10:45 PM
350zzzgunnar
Thanx much approeciated!
Still I like to know what bolts it uses on the engine, so there will be no doubt that it fits
Old Sep 13, 2008 | 11:03 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
You are looking at the picture, and there are several of us already using them with no problem.. So, why do you worry so much? All the necessary bolts comes with it... Just buy the darn thing already.
Old Sep 14, 2008 | 07:04 AM
westpak's Avatar
westpak
SFZCC
I looked at both the weapon R and Ingalls and even bought them both but was not crazy about putting that kind of load on the plenum or front timing case after trial fitment, I would feel better with solid or polyurethane engine mounts to keep the engine from rocking.
Old Sep 14, 2008 | 10:41 AM
350zzzgunnar
that's what I was afraid of, that it bolts on to som part that can't stand it. or that I don't have...
But solid motor mounts as well as polyurethane ones get's driving go a bit shakey, don't they?
[my engine bay]
Old Sep 14, 2008 | 01:01 PM
westpak's Avatar
westpak
SFZCC
well that is also what kept me from installing the solid mounts I had purchased but the feedback seems to be 50/50 some say they don't like the vibrations others say they don't feel any.
I might try the polyurethane ones, my main issue was to try to keep the exhaust from moving too much and causing cracks or loosening of bolts
Old Sep 14, 2008 | 01:47 PM
350zzzgunnar
Thanks for info
I've heard the same about solid mounts so maybe I'll goo for polyurethanne ones then.
Thinking that they who have vibrations maybe haven't done balancing in a rotating assambly?
I'm welding flex pipes into my Greddy Evo TT's, finishing it up tomorrow and in goes v-band fasteners (don't know it that's the term in english) as well
Old Sep 14, 2008 | 02:27 PM
ADMAN's Avatar
ADMAN
I've seen photos of the Stillen brace on the driver's side too.
Confused. I thought the intake would be in the way.
Old Sep 15, 2008 | 07:38 AM
Driver06's Avatar
Driver06
I had the Stillen, but like you said, it got in the way of the APS.. So I took it off..
Then My steering column was rubbing on the turbo.. So I took the bolt out, ground the flange, and welded the column to the Knuckle
You just have to be creative where it will fit..
Old Sep 16, 2008 | 01:51 PM
OCG35's Avatar
OCG35
anyone have links to solid or poly engine mounts?...
Old Sep 16, 2008 | 03:40 PM
westpak's Avatar
westpak
SFZCC
http://www.hopupracing.com/merani35enmo.html
Old Sep 16, 2008 | 04:43 PM
OCG35's Avatar
OCG35
nice, thanks! Those look different than the Megan I thought I saw (I thought they were rectangular block shaped)...
Anyone have reviews of these?...
Old May 17, 2009 | 12:11 PM
350zzzgunnar
Just an update.
Got solid motor mounts from Injected Performance. I haven't got more vibrations at all, it just feels... more responsive and - solid
Old May 17, 2009 | 01:00 PM
tiguy99's Avatar
tiguy99
At what power level do the stock motor mounts no longer support the added power from a boosted motor?
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
