Vortech SC to SI trim (worth it)
Old Sep 18, 2008 | 09:20 AM
jpc350's Avatar
jpc350
Default Vortech SC to SI trim (worth it)
Thinking of the upgrade but would appreciate any and all thoughts on benefits of the upgrade...Str8dum experience with it has been it runs hotter (AIT) than SC trim with no appreciable power benefit. What is the consensus of the benefits shelling out about $400.0 for the mod on the VQ engine?
Old Sep 18, 2008 | 09:47 AM
sentry65's Avatar
sentry65
the burninator
IMO I wouldn't think about doing it until you think about doing cams, headers, and HF cats
I also wouldn't consider it at all if you're on the stock engine
that's just me though. You'll need larger injectors and obviously a retune
Old Sep 18, 2008 | 10:10 AM
jpc350's Avatar
jpc350
[QUOTE=sentry65]IMO I wouldn't think about doing it until you think about doing cams, headers, and HF cats
Have headers.
What are your concerns with the stock engine? Plenty cars making well over 400 with stock engine..A good tune is the solution..
Have a RFS and walbro, 440's and a retune of course
You have not provided any pro's..surely there must be some?
Old Sep 18, 2008 | 10:18 AM
JET MECH's Avatar
JET MECH
boost comes in alot quicker with higher over all boost numbers. but the down side with this blower is the higher IAT's. water injection would help bring the temps down. i would not recommend it unless you plan on having the appropriate supporting mod's. the only thing i would have to add next is cam's and head work to get it to perform as it should correctly, i am upgrading in the near future to the V1 T-trim . after that when i pop the engine i am building a 10.5:1 compression built stroker short block with worked heads, cam's, 3" system piping, larger fmic and reinstalling the T-trim. i will be shooting for a 550 RWHP s/c setup.
Old Sep 18, 2008 | 11:08 AM
05Z33's Avatar
05Z33
I'ld really like to see this build take place. I'm sure you can break 550whp with a 4.2 stroker and a T-trim. Modified Mag featured a 4.1 stroker with a stillen stage 4 kit that broke 500whp.
Old Sep 18, 2008 | 11:23 AM
Mr_pharmD's Avatar
Mr_pharmD
I don't think it's possible until someone can figure a safe way to stop the slippage. A T trim with the right pulley setup can push around +20psi but the real question is can u actually see 20psi all the way to redline or will the boost keep falling off at WOT?
Old Sep 18, 2008 | 11:46 AM
sentry65's Avatar
sentry65
the burninator
with a larger engine via stroker kit, boost psi will go down so you'll never even get to 20 psi. It'll probably be more like 16 psi with a 4.2 liter engine at 6600 rpms. I think with the right belt mods, you can probably hold 16 psi.
But you're right about 20 psi probably not working out and slipping too much if it was the stock 3.5 displacement
Old Sep 18, 2008 | 02:34 PM
Quamen's Avatar
Quamen
There should be good alternative being released next week assuming that all goes well with my dyno this weekend!
Old Sep 18, 2008 | 04:59 PM
JET MECH's Avatar
JET MECH
keep us posted, this may be interesting........
Old Sep 19, 2008 | 11:15 PM
Quamen's Avatar
Quamen
Thread posted
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
Tochigi_236
Sep 27, 2015 03:40 PM
Calinismo350z
Sep 14, 2015 04:04 PM
