smoke out the exhaust
Old Sep 18, 2008 | 07:39 PM
AaliyaRocks's Avatar
AaliyaRocks
Default smoke out the exhaust
I am hoping someone can shed some light on my issue. My car has Greddy TT and many other bolt ons. The car was running great at 370rwhp, daily driver. I decided to add reurn fuel system, since then, the car lets off huge amounts of smoke when you let off the gas. No smoke when your foot is into it, only when you let go of the gas. Doesnt smell like oil, and its white. My mechanic convinced me that buying a Haltech ECU would solve all my problems, so I did. He has installed it, but we are still have the same problem.... anyone have any ideas, I am hoping it is something minor, before I have to change out the stock internals, was hoping to wait till next spring to take on that project.
Old Sep 18, 2008 | 10:27 PM
Great question for the forced-induction forum.
Old Sep 18, 2008 | 10:33 PM
samjcg's Avatar
samjcg
^^ i swear u are everywhere, oh gawd, i wish i was as knowledgeable and mono-tone as you to comment on people's thread like that.. sir u have some talent.
Old Sep 18, 2008 | 10:39 PM
Spork's Avatar
Spork
Old Sep 18, 2008 | 10:51 PM
Emerald99's Avatar
Emerald99
This is definitely a Great question for the forced-induction forum.
Old Sep 18, 2008 | 11:00 PM
Barzten1's Avatar
Barzten1
I think its a issue with most Greddy TT owners. My car lets out a good random puff of smoke also. Seems the Greddy seals are leaking and can be somewhat fixed by running a thicker oil weight.
Old Sep 19, 2008 | 04:57 AM
peaches05's Avatar
peaches05
I had a similar problem when I ran 5w-30 in my z with the turbonetics kit. mine would smoke when I ran up high into the rpm range and then smoke on decel. did you change your oil/oil weight when you installed the return system?
Old Sep 19, 2008 | 06:31 AM
express705's Avatar
express705
yeah when i drive behind people with TN's i notice the white puff.
dangerous? i think not.
Old Sep 19, 2008 | 08:07 AM
AaliyaRocks
thanks everyone for the ideas, will sugest heavier oil to my tuner...
Bill
Old Sep 19, 2008 | 08:30 AM
IslandZavage's Avatar
IslandZavage
Just curious, but why did your tuner suggest that buying a Haltech would solve the problem?
Old Sep 19, 2008 | 08:35 AM
Chaser720's Avatar
Chaser720
Lemoned Z
Yeah. Just dropped a few bucks ehh
Old Sep 19, 2008 | 08:41 AM
Cannysage's Avatar
Cannysage
because Haltech and Fcon is be-all, end-all solution to all problems. you don't even need an annual checkup from your doctor, when you have a standalone
Old Sep 19, 2008 | 08:44 AM
XKR's Avatar
XKR
WOW...expensive...and then to find out it did not fix the problem
Old Sep 19, 2008 | 09:10 AM
SpoilsofWar's Avatar
SpoilsofWar
Its a common issue with most turbo setups. There are a bunch of things that can cause it:
Too thin oil being used
PCV system plumbed wrong, or PCV valve spent
Turbo seals leaking
Turbo drain lines kinked/plugged/too small
Excessive piston ring wear
You just have to work your way thru the suspects until you find which one(s) are causing the issue. Unless its due to internal engine wear, its probably an easy fix. Finding it is the hard part!
Old Sep 19, 2008 | 10:38 AM
UMW350Z's Avatar
UMW350Z
willa leakdown or compression test check this?
Old Sep 19, 2008 | 11:53 AM
alan21's Avatar
alan21
this is not a greddy thing ive run the kit for a while on my built motor and never have one ounce of smoke ever
Old Sep 19, 2008 | 11:55 AM
SpoilsofWar
Well it will tell you if you are getting blowby due to poor ring sealing.
Nope it certainly not a greddy-specific thing. I've seen threads of this nature from people running pretty much every turbo kit out there.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
Li1ag
Sep 28, 2015 02:07 PM
