Powerlab issues(after a month of driving)
Old Oct 4, 2008 | 03:12 PM
  #61
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
dss makes them, however they are unreleased yet....
We carry them as backups in the trailer, though we have yet to break the Level5's... I guess we aren't making enough power
Snyper, love the look with the big tires !!
Old Oct 4, 2008 | 03:47 PM
  #62
coachk's Avatar
coachk
Originally Posted by SnyperZ
they are 325/50/15s ( i think 50s)... and no they are billet wheels...flat black is just rice haha..they look SO much better in person..youll see em this weekend ed. The back rims are 15x10
I have a set of the 325/50/15 on a 10" wheel as well. They look great until you launch the car. They're going to rub like crazy on the fenders. I also have the 275/50/15 on a 8" wheel and they work perfect at the track.
Old Oct 4, 2008 | 04:09 PM
  #63
Dynosty's Avatar
Dynosty
Interesting... we have used a 325/50/15 on our Z many times without rubbing. We rolled the fenders, did you?
Old Oct 4, 2008 | 04:10 PM
  #64
SnyperZ's Avatar
SnyperZ
Sent you a PM on the boost fluctuations..it had nothing to do with the MAP,vacuum lines or Haltech.....
Old Oct 4, 2008 | 04:18 PM
  #65
coachk's Avatar
coachk
No....but you also have a stiffer suspension in the rear don't you?
Old Oct 4, 2008 | 10:43 PM
  #66
SnyperZ's Avatar
SnyperZ
yeah mine fit fine..they dont rub.
Old Oct 5, 2008 | 03:22 AM
  #67
coachk's Avatar
coachk
No doubt they fit fine, so did mine. Its when you launch the car hard or turn a sharp corner...Did you roll the fenders?
Old Oct 5, 2008 | 11:52 AM
  #68
SnyperZ's Avatar
SnyperZ
I did a series of hard er launches on the street with no problems and yeah I rolled the fenders..
Old Oct 5, 2008 | 12:59 PM
  #69
coachk's Avatar
coachk
Well there you go....I guess I need to roll my fenders
What back spacing did you go with?
Also it looks like you went with skinnies up front...What are the sizes of the tire and wheel?
Thanks
Old Oct 5, 2008 | 01:32 PM
  #70
SnyperZ's Avatar
SnyperZ
Thanks
They are the mustang sizes..only with no spacers on either side. Honestly..they fit perfectly..within a milimeter. 15x10 with a 6.5 backspace on the back and I just ordered 15x3.5 for the front..I think it was only one back space..but they fit perfect.
Old Oct 5, 2008 | 04:39 PM
  #71
IIQuickSilverII's Avatar
IIQuickSilverII
...oh you are making plenty of power
its been a hit and miss issues...i am sure styles of driving might have a play in there too but its no secret this level 5s have "falin" on peeps with half the power you've got
Old Oct 7, 2008 | 06:30 PM
  #72
SnyperZ's Avatar
SnyperZ
Well, found my exhaust leak (I thought it was a loose clamp)..it was ripped there and in a separate spot on the other side.(this is the cross over where the wastegate mounts)
What happened was..when i first got the kit the dump tube was too short(about 3/4") and I had to start the bolts and tighten them to close the gap..I figured the flex section would be enough to "stretch" the pipe..guess i was wrong. All the pressure pulling ripped the metal next to the weld(the metal was thin around it. What I also did was shorten the downpipe so the merge met up with the dump tube. Its close now but its not perfect and I dont want to risk ripping it again so im going to pretty much remake the dump tube so its actually a little tight. I fixed the cracked section ...
For now im running an open dump and blocked off the merge. HOLY SH*T is it loud when it comes into boost haha. Im gonn run around like this for a little bit until I feel like making the new pipe.
Old Oct 8, 2008 | 06:28 AM
  #73
foreignsoda's Avatar
foreignsoda
that happened to me, exact spot... that part of the exhaust system is seriously the hottest part, the color of the pipe tells you that. the weld is obviously the weak point and heat is looking to escape. mine broke and i was running what sounded like open headers for a week. got it rewelded and reinforced so it won't happen again...
Old Oct 8, 2008 | 08:40 AM
  #74
SnyperZ's Avatar
SnyperZ
yeah well the dump tube was the cause of mine ripping off. The was pulling too hard on the waste gate. I'm going to remake that pipe so it actually fits.
Old Oct 8, 2008 | 11:39 AM
  #75
cwylie's Avatar
cwylie
Originally Posted by SpoilsofWar
http://projectptp.com/ptp/ptpturbo-b...s/g-55518.aspx
note that PTP direct sells them cheaper on ebay.
You don't want to deal the PTP (Protech Performance) I had a very bad experence with them as well as may others around Austin.
Go directly to the source
www.boostlogic.com
Good guys and PTPs source last time I checked.
Old Oct 8, 2008 | 11:53 AM
  #76
cwylie's Avatar
cwylie
http://www.boostlogic.com/xcart/prod...&cat=23&page=1
Old Oct 9, 2008 | 05:37 AM
  #77
Driver06's Avatar
Driver06
Dam, you can see a lot better when its not on a phone.. yep, its broken.
Did you get it fixed yet? Thats 2 powerlabs that broke there, did they address the issue for either of you?, that has warranty written all over it..
Old Oct 9, 2008 | 07:31 AM
  #78
foreignsoda
they offered to replace it/reweld it. but being my daily driver i can't take that downtime, plus the sound was driving me insane.
i got mine rewelded at a local shop and reinforced. won't happen again hopefully.
Old Oct 9, 2008 | 09:17 AM
  #79
SnyperZ's Avatar
SnyperZ
..No. I got the usual "we'll call you back"..3 days ago. I gave up on that so I fixed it myself.
Update...powersteering is done for. The downpipe rubbed through the alum. hardline and left the fluid all over the road. Looks like ill be taking everything out to replace that line.
Old Oct 9, 2008 | 11:03 AM
  #80
Driver06's Avatar
Driver06
That sucks, but it could have been a lot worse.
Aluminum hardline, an oxymoron at its finest.. like jumbo shrimp
The vertical part in the new weld, is that just a booger?, or did he have to chase a hole?
