Spark Plug tubes: anyone replace them yet?
Old Mar 5, 2009 | 06:27 PM
350 Rookie's Avatar
350 Rookie
Originally Posted by Blackbird CPV35
even tried looking a hook through the holes and using a cherry picker to try and pull them out and the damn thing picked up the whole engine
Old Mar 8, 2009 | 07:13 PM
Blackbird CPV35's Avatar
Blackbird CPV35
heelllp!
Old Aug 6, 2009 | 11:22 AM
Entaille's Avatar
Entaille
bumping an old thread.. did you guys ultimately end up getting new valve covers for this stupid tube? : (
Old Aug 6, 2009 | 11:53 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
His problem was with the tubes themselves, not the seals - so new valve covers would not fix. Ultimately I believe he was able to remove the tubes by fitting a socket inside the tube (to keep it from crushing in) and using vice grip or similar to squeeze the outside and twist them out.
Old Aug 6, 2009 | 11:57 AM
Entaille's Avatar
Entaille
Thanks Hal. hopefully mine can do the same. I didn't understand why they sold the tubes separately if you cannot swap them out without getting a new valve cover.
Old Aug 6, 2009 | 12:00 PM
Dynosty's Avatar
Dynosty
I believe you are confusing tubes with seals.. the seals are built into the valve cover and can not be replaced. This is the most common problem with oil leaking. The tubes will only be a problem if the heads were dropped/dented/etc.
Old Aug 6, 2009 | 04:54 PM
Entaille's Avatar
Entaille
thanks again, you must be correct.
Old Aug 7, 2009 | 08:54 AM
Rafa's Avatar
Rafa
tell me about i have the exact constant battle oil filling in my spark plug tubes and its really annoying
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
