built short block,T-trim,NOS project to start!
Old Sep 29, 2008 | 06:34 AM
Floridaboy1605's Avatar
Floridaboy1605
you can get the bearings in the v2!! thats what i have/had it sounds redic!! and it sure does ramp up power i had the 3.12/34/28 setup on and made 17 psi with it!!!!! if you get a v1 you might have to do a little custom fab to make it fit cause i know the v2-t was a tight fit!
Old Sep 29, 2008 | 06:57 AM
booger's Avatar
booger
Jet Mech
Do you have a close up pic of the bloer and jackshaft assembly for the rrev up ? My first thought when I read you wanted to go to the 8 rib like Quamen did , was .....is there going to be enough room for the wider serp pulley on the jackshaft . Maybe the Rev -Up is different , but on the older kits , I dont think there would be enough room . Im going to search around to see if I can find a pic of what Im talking about .
Here is the area I was thinking of . And it looks to have plenty of room for a wider pulley....never mind...lol
Attached Thumbnails built short block,T-trim,NOS project to start!-belt-20and-20supercharger-2-.jpg
Old Sep 29, 2008 | 07:23 AM
JET MECH's Avatar
JET MECH
Talking
Originally Posted by str8dum1
But why go so deep with a blower? YOu can get that kinda power with a turbo and be much more efficient about. It will negate the addition of NO2 bc you will already have lots of torque. No custom 1 off machine parts. No being without your car for 6 months again. And maybe athat tank of gas would last more than a weekend with the higher mpg from a turbo.
Just curious.
I totaly see your point!!!! and have scrutinized this for a while.
but honestly at this point i have so much invested in my current setup i feel like i cannot turn back now. i ran the numbers on purchasing a tuner turbo kit greddy,aps or PL single and all of the associated upgrades needed such as boost controler/ turbo timer/ different exhaust setup etc, etc and i know i would have to invest more money into a turbo build that to do the s/c upgrades i have planned. i want 500RWHP AND 450 RWTQ. That is my goal and i i know i can do it with the planned upgrades. i am not one of these people that has to make rediculous HP figures on a dyno to impress others. and i am not one of the highway roll on run type of individuals. i am older now and have been there, done that in my younger years when i was heavy into modding fox body mustangs. i plan on doing alot of track time in this car in the near future " road race " and i feel this setup will best suite my needs. i like the linear power band of the centrifical s/c. it has the manners of a N/A car but just on steroids. i have owned turbo cars in the past and dont get me wrong the sundden thrust of power is a awsome feeling but for the application this car will be used for i just feel it will be alot more predictable under hard driving conditions. the nitrous setup will be for those once i a while times when i want that sudden thrust / turbo feel, lol
Old Sep 29, 2008 | 07:30 AM
JET MECH's Avatar
JET MECH
Originally Posted by booger
Jet Mech
Booger it is good to see you are staying around!!! i have measured the area you are talking about and yes a 8 rib will fit on the rev-up applaication. there will not be much extra clearance though.. 1/16 of a inch is all that will be left between the serp pully and the volute retainer plate. i may be able the shim the blower out some for some extra clearance but in turn i will have to adjust for on the cog idler pulley at the same time.
Old Sep 29, 2008 | 07:45 AM
JET MECH's Avatar
JET MECH
i have done some research on the v1's and v2's. the case/gearbox dimensions are the same. the differnce is the straight cut gearing in the v1 versus the helical cut gears in the v2. also i was in formed the v1 had heavyer duty beings installed. he did not elaborate on the v2 HD bearing option, "i wil look into that". the differnce in the T-trim versus the S/SC/Si trims is a larger impeller and larger volute assembly installed . if i remember correctly the S/SC/Si trims have a 3.5" inlet dia and the T-trim has a 3.75 inlet dia. " trying to remember off the top of my head". also the impeller dia is slightly larger as well. vortech also proceeded to tell me that most if not all of its sponsored drift z s/c applications are running the v1-T-trim. not the v2 for maybe durability reasons. the performance factory sponsored drift z is running a v1 T-trim as well. i had a long talk with the driver at the last vegas drift event, he loves how the car handels and how the power comes on very predictably with the s/c setup.
Old Sep 29, 2008 | 08:04 AM
JET MECH's Avatar
JET MECH
BTW this project will not be starting till the first of the new year. i just got done putting a CST suspension lift on my titan truck. pro comp wheels, 35" rubber, bullydog engine programer and some other odds and ends things. NEED TO RE-COUP THE PLAY TOY ACCOUNT!!!! i refuse to build cars/ or anything for that matter on credit cards. back in my early 20's i built a couple of mustamgs that way and it took me years to pay those cards of well after the cars had been sold!!!
Old Sep 29, 2008 | 10:49 AM
sentry65's Avatar
sentry65
the burninator
sounds like a great project!
I'm curious to see how it turns out.
I wish we knew more about how E85 works out with our cars because that'd give you some more power and even higher octane for about half the cost of race gas.
Old Oct 17, 2008 | 03:50 PM
JET MECH's Avatar
JET MECH
made the first step for my build project. here is the spare 06 rev-up engine that i will be building .i picked up for a steal "$350.00" from a local nissan tech " thanks to Stan " it has 22000 miles on it and was pulled for the oil consuption bulliten. i know the previous owner of the engine due to he is part of the vegas z club out here. the nissan tech i purchased the engine from let me know that this engine BARLEY met the criteria for this engine to be replaced under warranty and that he had to fuge the figures a bit for the owner to get a new engine in his z. regardless it does not matter due to the pistons and rod's among many other assemblys will be upgraded. over the next couple of weeks i will be doing the teardown and inspection as well as start my laundry list. will keep you posted.
Attached Thumbnails built short block,T-trim,NOS project to start!-z-pics-003.jpg   built short block,T-trim,NOS project to start!-z-pics-004.jpg   built short block,T-trim,NOS project to start!-z-pics-005.jpg
Old Oct 17, 2008 | 04:01 PM
iStan's Avatar
iStan
ZR
yay.
Hmm, you have room there for another longblock...mind if I keep one there?
Old Oct 17, 2008 | 04:07 PM
JET MECH's Avatar
JET MECH
for you Stan! no problem. lol
Old Oct 17, 2008 | 04:08 PM
iStan's Avatar
iStan
ZR
I may take you up on that.
So, uh, are we doing an alignment this weekend?
Old Oct 17, 2008 | 04:18 PM
JET MECH's Avatar
JET MECH
not this weekend it's my "B" day. my girlfreind is throwing a party at my house. there will be alot of this you and the guys are welcome to come over for the party. BTW i am at that age that i am couting backwards now! i will be 35 now. dont forget it!!!!!!!
Old Oct 18, 2008 | 04:50 AM
05Z33's Avatar
05Z33
Have you thought about increasing the displacment for your build? A 4.2 with stock compression should put you well over 500-550whp.
Old Oct 18, 2008 | 12:48 PM
iStan's Avatar
iStan
ZR
No ?
Give me a ring later.
Backwards huh? Woman.
sherm
Apr 11, 2020 05:21 PM
