Something weird in my coolant over flow bottle
Old Oct 11, 2008 | 03:20 PM
  #41
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Chris - ever use any sort of coolant additive before? Water wetter, etc?
Old Oct 12, 2008 | 09:34 AM
  #42
QuadCam's Avatar
QuadCam
wow. all this coolant talk................and guess what? my car randomly overheated today while waiting to get my starbucks in the drive thru lane.
still don't know why it happened. Fortunatley, there was an Advnaced Auto Parts across the street. I picked up some 50/50 coolant, a screw driver, a new radiator cap, and a funnel. I let it all cool down, refilled it, bled the air out, and installed the new cap. everything is perfect.......so far. I am clueless as to what happened though. also, I added almost a full gallon of the 50/50 coolant! I must not have had anything left in the car!!!!!
Old Oct 12, 2008 | 10:08 AM
  #43
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by Q45tech
Where would rust come from? Rust requires Iron to make the iron oxide. What part of coolant exposed system is made from anything but aluminum alloys?
High School Chemistry
The coolant line that runs along the passenger side of the motor is steel....along with a couple others. I've seen rust on the inside of mine.
Old Oct 12, 2008 | 10:21 AM
  #44
j.arnaldo's Avatar
j.arnaldo
Is she overheating? Any coolant puddles? A miss? Take it to a radiator repair shop, have
'em check the whole system out. Good luck.
(Post your findings!)
Old Oct 12, 2008 | 12:30 PM
  #45
QuadCam's Avatar
QuadCam
most of the coolant pipes have scale and corrosion over time. All the used ones I have seen looked crusty.
Old Oct 12, 2008 | 12:36 PM
  #46
SpoilsofWar's Avatar
SpoilsofWar
The full coolant capacity is something like 2 1/4 gallons IIRC. Although that is with an aftermarket 36mm radiator that undoubtedly holds more then stock.
Since we're talking about coolant, I finally fixed my coolant leak from the rear crossover pipe. It was missing the OEM gaskets completly . Suprisingly the driver's side sealed with just the rtv that was used. Had to completely remove it and install new gaskets, talk about a lot of work - theres not much room to manuever and theres a lot of stuff in the way. Only took me about 5 1/2 hours
Also, those of you concerned with corrosion or rust in the cooling system, if you switch to Evans you wont get any, since theres no water in it.
Old Oct 12, 2008 | 03:35 PM
  #47
QuadCam's Avatar
QuadCam
that's a b1tch of a job to do with the motor in the car.
Old Oct 13, 2008 | 03:42 AM
  #48
Audible Mayhem's Avatar
Audible Mayhem
My350z
even using distilled water (which we do) it seems to rust the water pump fins just a little. it combined with the inside of the brass looking tube on the passenger side of the motor are the only items that tend to get a little rust in them. i am sure thats what it is. i have seen it on stock motors when you switch to 50/50...
how many ulcers do you have chris
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Uriyo_
Sep 8, 2021 08:46 AM
SharX59
Sep 27, 2015 09:23 AM
