My build, can I reach 600rwhp?
Old Oct 12, 2008 | 07:41 AM
  #61
chris'smax's Avatar
chris'smax
Originally Posted by coachk
Same can be said about my JWT C8 cams....my car pulls very hard up top.
+1 coach!!!!
I vote for the C8's also
Old Oct 12, 2008 | 10:29 AM
  #62
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by SmallTuner
hey Alberto
is the power ur talking about came from the BC STG III cams, ????
or the Math + extra timing in the ignition map ????
what about if we have the same setup with the JWT C2 cams ??
Different tuning, and BC 3 cams. That was on pump gas, low boost, NO METH! I dont know how your cams compare.
Old Oct 12, 2008 | 02:23 PM
  #63
SmallTuner's Avatar
SmallTuner
Originally Posted by RudeG_v2.0
Like Fluid1 said... It depends on what your application is and what your priorities are in determining what's the best cam for you.
There is no single answer for what's the best cam to make 600whp either. It depends on what your turbo setup is. For example, a large single turbo setup like the PowerLab GT37R doesn't even need aftermarket cams to reach 600whp. A single turbo setup produces more top end power, while a twin turbo setup produces more midrange power.
The reason you're hearing so much about the BC stage 2 and stage 3 cams lately is because they seem to shine at making top end power on twin turbo setups. This is something that a lot of twin turbo FI guys have been looking and waiting for. BC cams have shown in Julian/MRC's reviews and on SP's 1,033whp shop car to make power beyond 6500RPM. The first cams I noticed making power above 7000RPM were the BC stage 2 cams, when Julian posted his review. SP is making power with these cams to 8400RPM.
The BC cams are great if you have a twin turbo setup and your priority is top end power. There is nothing wrong with JWT cams or the other brands. As Alberto has posted in his thread, the JWT S1 cams are great if you want nasty midrange power. If you want stock idle quality without having to adjust idle and/or want more low to midrange power, than big top end biased cams aren't for you. Up to this point though, the BC cams are the only brand that have been shown consistently to make power up to 6500RPM and beyond.
Another interesting fact that should be noted is that all 3 members of the 1,000whp club (Injected, SP, and Intense) are using BC stage 2 cams in their shop cars.
All this being said... For the OP's standard APS setup and 600whp goal, I'd recommend the BC stage 2 cams. The stage 2 still has decent idle quality and it won't sacrifice a lot of low to midrange power. If you want to make big numbers with a smaller twin setup, a cam with good top end performance like the BC cams will be essential to achieve your power goals.
nice write up THNAKS
Old Oct 12, 2008 | 02:40 PM
  #64
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
You're welcome. I hope this answers some of your questions.
I'm not personally familiar with the JWT C2 cams. But I looked up their specs. Their duration is 261, but they have higher lift than the BC stage 2.
Here is the link to the specs on all of JWT's cams:
http://www.jimwolftechnology.com/wol...INCL_REVUP.pdf
Old Oct 12, 2008 | 03:02 PM
  #65
Cass007's Avatar
Cass007
Rude - I got the specs on my cams today and I was hoping for input fro you, bert or quick. Tomei intake is 256 and exhaust is 264. these any good? Any idea on the kind of top end I can expect. I ask those who know since I am a noob in this area. Thank you again. - Chris.
Old Oct 12, 2008 | 03:44 PM
  #66
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Hmmm... That sounds similar to GTM's stage 1 turbo cams. They have a shorter duration on the intake side. Doesn't sound very aggressive or optimal for top end power, but maybe some guys with the GTM stage 1 turbo cams can chime in and provide their feedback about how their cams perform in the higher RPM's.
Old Oct 12, 2008 | 04:04 PM
  #67
wannabuy350z's Avatar
wannabuy350z
nice thread. I am going to be doing my internals soon.
Old Oct 12, 2008 | 04:51 PM
  #68
coachk's Avatar
coachk
Do you know the degree of overlap on your cams?
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
