Help HKS Twinpower DLI II popping
Old Nov 8, 2008 | 08:07 AM
sajazzman007's Avatar
sajazzman007
DIY'er Unite
Thumbs down Help HKS Twinpower DLI II popping
Hey all,
I just installed the HKS DLI II on my car, and it sounds like it is miss firing and making loud popping noises. I also smells hella rich also. Could it be that I potentially installed this wrong? I have it grounded to a part of the engine. I looked for instructions can't find any but the install is fairly easy? The red light is on showing that it is on.
Old Nov 8, 2008 | 08:56 AM
Zivman's Avatar
Zivman
I would guess you mixed up the wiring to the coils.. car is firing in the wrong order
Old Nov 8, 2008 | 08:57 AM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
I would say that it is certainly hooked up incorrectly. Popping would be misfiring... and you are smelling unburnt fuel.
Old Nov 8, 2008 | 06:29 PM
meatbag's Avatar
meatbag
The connectors on the driver side are easy to confuse if the numbers are gone and you pulled everything off at once. Just double check everything.
Old Nov 9, 2008 | 04:42 AM
sajazzman007
DIY'er Unite
Thanks the wildest thing is that the HKS isnt numbered.
Old Nov 9, 2008 | 04:44 AM
Zivman's Avatar
Zivman
and it doesn't need to be.... you can basically hook any plug into it. You need to make sure each output is correct to each bank based on the oem input to it
Old Nov 9, 2008 | 11:07 AM
sajazzman007
DIY'er Unite
Went back and checked it out, fix the problem, and the CEL light is on now but the car runs hella strong. How do I turn the CEL light off?
Old Nov 9, 2008 | 11:15 AM
diablo1356's Avatar
diablo1356
how strong is "hella" strong?
Old Nov 9, 2008 | 11:27 AM
weslutes's Avatar
weslutes
"YeeeeHaaw" strong
Old Nov 9, 2008 | 11:35 AM
sajazzman007
DIY'er Unite
A whole lot. I tell ya what this is worth the money if you are FI just need to figure out how to reset my ecu.
sajazzman007
DIY'er Unite
Originally Posted by weslutes
"YeeeeHaaw" strong
Yeap i'm excited
Old Nov 9, 2008 | 11:39 AM
Jay'Z's Avatar
Jay'Z
Did this help ur start ups?
Old Nov 9, 2008 | 12:01 PM
sajazzman007
DIY'er Unite
It help everything. Just trying to figure out how to turn off the CEL. How do I reset my ECU?
I would recommend this ignigtion to anyone FI. I mean you can feel it in the idle, acceleration, and everything. I mean I ran it a few times down the street and it is the truth. I have to figure out how to turn of the CEL or reset my ecu so I can run my map correctly without the ecu running in safe mode.
Old Nov 9, 2008 | 12:03 PM
Jay'Z's Avatar
Jay'Z
Just pull your battery for a few mins.. or try the technosquare ecu reset.. search..
Old Nov 9, 2008 | 12:09 PM
str8dum1's Avatar
str8dum1
HAHA. unless you were blowing your spark out, its all placebo effect. a $400 placebo effect
you'd prolly love nology wires as well
Old Nov 9, 2008 | 12:10 PM
sajazzman007
DIY'er Unite
Great I'll go with the battery idea
Old Nov 9, 2008 | 07:18 PM
sajazzman007
DIY'er Unite
Yeah your right I love the nology wires to smart a$$. No seriously you can tell there is a difference.
Old Nov 9, 2008 | 08:22 PM
thom000001's Avatar
thom000001
Why are you guys getting spark blowout? Have you checked your plug gap?
There are people on here running a lot of boost on the stock ignition with no problems at all (myself included, at 30 psi no spark issues).
Just wondering who is having these issues?
Old Nov 9, 2008 | 08:35 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
+1 Intense has been making big power (906whp on the widebody shop G and 1,014whp on mazoo's twin GT37R widebody Z) with the stock ignition.
I was thinking of getting the HKS DLI II, but Intense and Jason Siebels with ProEFI recommended against it. They said it is totally unnecessary and that the stock ignition works just fine.
Old Nov 9, 2008 | 09:30 PM
thom000001's Avatar
thom000001
Hmmmm so all the 4 figure power cars are on the stock ignition (SP is too) ......I know I've never had an issue. And I'm only 1 step colder than stock on the plugs, but gapped a little bit down. Not too much though.
07ZEKE
Aug 23, 2021 09:15 PM
gonzalo_300zx
Dec 18, 2015 04:14 PM
