Fuel System Noise
Old Nov 10, 2008 | 08:47 AM
phunk's Avatar
phunk
CJ Motorsports
westpak are you running twins or a single?
Old Nov 10, 2008 | 08:49 AM
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by leeboyNY
It definitely gets louder as the engine gets heat soaked. It hums pretty loud after driving for longer than an hour. Should I be concerned or is this normal? I believe pumps are running fine, but I would like your input Charles.
when its humming really loud try opening the gas cap and see if the sound chills out a bit. if it does that gives me somewhere to start... but without hearing the noise myself i cant tell for sure if the noise youre hearing is normal or if there is something to look into
Old Nov 10, 2008 | 08:50 AM
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by westpak
Mine whines a bit but not too loud, but I took a long drive a few weeks ago (couple hundred miles) and it so so loud when we got to ur destination it was crazy
Charles are these just cheap pumps? are there better quality drop in pumps out there?
i dont think its an issue caused by cheap pumps... they are certain rather cheap compared to the bosch 044 or the likes, but the opening of the gas tank flange is too small to put 2 of those in there.... the walbros flow well and can be reliable as long as they dont starve or cavitate
Old Nov 10, 2008 | 08:54 AM
XKR's Avatar
XKR
Originally Posted by phunk
does it actually get louder as the car warms up or is it possible that it just sounds louder since the idle sits lower at operating temp?
At idle you can hear my CJM Twins...but driving you have to be looking for the sound over the exhaust to hear it
Old Nov 10, 2008 | 09:03 AM
westpak's Avatar
westpak
SFZCC
single
Old Nov 11, 2008 | 12:04 AM
Havok_RLS2's Avatar
Havok_RLS2
I hear mine as well. I just turn up the volume on the DVD player.
Any other ways to kill the buzz?
Old Nov 11, 2008 | 05:07 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Seems like you and I have the same symptom...
Old Nov 11, 2008 | 06:54 AM
jonnylaw's Avatar
jonnylaw
Symptons/causes for starvation or cavitation?
Also, this may be a really stupid question, but is it harder for a fuel pump to push the requisite gas when the gas tank isn't full (e.g. 1/4 full)?
I noticed on my AFK that when I was at 1/4 of a tank, I was running a little lean, but after I filled up the tank, the AFR's were running how they should...
Old Mar 15, 2009 | 05:17 AM
G35cTT's Avatar
G35cTT
Hopefully someone can help me here since it's of same topic. I just got a new fuel pump assembly so had to redrill everything and put the old pump back in. The car drove great and then a week or 2 after it just kept cranking not turning over to start. Before I would hear the pump turn on and it'd fire up. Checked the fuse and it's good any clues? It's not the crank position sensor also as that has been changed.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
