ses light p0507 engine idle higher than expected help!
Old Nov 25, 2008 | 08:46 AM
drumminguy81's Avatar
drumminguy81
Default ses light p0507 engine idle higher than expected help!
ok i have an 03 z with a vortech kit 3.12 pulley and ss box ever since install i have had a ses light on with code p0507 which is engine idle higher than expected or something of that nature. i have tried everything i know to try and not had any luck.i gotta get this figured out very soon because my emissions is due next month. so far i have tried all the throttle reset procedures, installed a new tb, checked for vaccume/boost leakes, cleaned and check maf, and made sure all ss box wiring is correct. my car is running very rich i was told the ss box was tuned for 13psi before i installed it and im only running 9psi. my aem uego reads 10.0 at wot which i know is not good could this cause the ses light and my car to "idle too hight"? the odd thing is my car is not idling very high usually around 950rpm which seems like it is barely idleing even at that.. does anyone have any insight to what i could do to take care of this before next month? i would really love to get it tuned to fix the rich problem but i dont have money now and probably wont until spring so if that is the cause does anyone have any possible solutions?
Old Nov 25, 2008 | 09:46 AM
athenG's Avatar
athenG
I'm in the same boat and due for inspection this December. 950rpm is high.. are you sure you did the Idle relearn right? I thought I have done the procedure right and the code keep coming back after a few miles of driving or 10 mins of idling. It took me 5 tries to get it working, you will know you got it right when your idle start to drop around 750rpm or lower. If your RPM is still above 900rpm then you didnt do it right.
Make sure get a stop watch and follow the exact procedure.
Accelerator Pedal Release Position Learning
1) Leave ACC pedal "as is”
2) Turn IGN switch “ON” – at least 2 sec
3) Turn IGN switch “OFF” – at least 10 sec
4) Turn IGN switch “ON” – at least 2 sec
5) Turn IGN switch “OFF” – at least 10 sec
Wait 10 sec for next procedure
Throttle Valve Closed Position Learning
1) Leave ACC pedal “as is”
2) Turn IGN switch “ON” – appr 3-4 sec
Idle Air Volume Learning
2) Start engine and warm up to operating temp – temp gauge around middle
4) Turn IGN switch “ON” – 3 sec
5) Fully depress and release ACC pedal – 5 times within 5 sec
6) Wait 7 sec
7) Fully depress ACC pedal for appr 20 sec – during this time CEL blinks
8) When CEL light is “ON”, not blinking – fully release ACC pedal
9) Turn the engine “ON” within 3 sec
10) Start engine and idle
11) Wait 20 sec
12) Rev engine 2-3 times and check IDLE and TIMING
Old Nov 25, 2008 | 12:07 PM
UMW350Z's Avatar
UMW350Z
go in with a consult and lower the RPM's manually...your dealer can do this.
And for the love of sweet Baby Jesus, get tuned
Old Nov 26, 2008 | 07:22 AM
drumminguy81
i have done the throttle relearn several times and it did shut the light off but the light always came back i will try it again following your instructions they seem slightly different than the ones i found online..
Old Dec 5, 2008 | 02:07 PM
drumminguy81
well i did it it seems to have helped adjust the idle down but now my car sputters at idle and dies at stop lights.. this sucks.. i would rather have the high idle..
Old Sep 27, 2010 | 07:16 PM
burubuduy's Avatar
burubuduy
anyone ever solve this problem?
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
