My Build: The Good, The Bad & The Progress
Old Mar 8, 2009 | 01:20 PM
  #561
Cass007's Avatar
Cass007
Originally Posted by Glex25
I wouldn't mention this cause the shop should know this.
Since its a fresh motor he did pull the fuel fuse out
so oil can circulate through the motor before cranking it over?
Also again since this is a reassembly there probably was no fuel in the lines.
I would have turned on the ignition 2-3 times to get the fuel circulating through
the fuel lines before cranking it over.
The smoke and burned oil smell is normal might stick around for a few days.
As far as the compression findings don't know what to say there but it might
just as you stated and they just need time to seat correctly.
The fuel system your using I see a Aeromotive Fuel Regulator and return system but no rails. Is that the new CJM basic fuel return system?
Apart from that everything looks great
The fuel system was primed prior to start-up because Frank made sure it would hold pressure. I have no idea on the fuel fuse prior to start-up though. The compression is the area that has my attention right now. Sharif has helped put me at ease about the start-up issue.
Old Mar 8, 2009 | 01:35 PM
  #562
superchargedg's Avatar
superchargedg
Damn Noobs
Good luck Cass as your in good hands with Frank and Shiroma san.
Old Mar 8, 2009 | 06:50 PM
  #563
Cass007's Avatar
Cass007
Finally figured out the vids - this is the initial start-up:
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i556.photobucket.com/player.swf?file=http://vid556.photobucket.com/albums/ss9/cassese007/InitialStartup.flv">
Old Mar 8, 2009 | 06:59 PM
  #564
rrmedicx's Avatar
rrmedicx
Congrats Cass!!! Sounds like we have a winner!!!
Old Mar 8, 2009 | 07:05 PM
  #565
Sylvan Lake V35's Avatar
Sylvan Lake V35
Looks like its getting close. Is it running on the Vi-PEC yet?
Old Mar 8, 2009 | 07:08 PM
  #566
Cass007's Avatar
Cass007
Thanks man - I know that you have been down this road before, you are the king of the DIY threads. After seeing how difficult doing things was in a full service shop I can't believe you did this stuff in your driveway.
Old Mar 8, 2009 | 07:14 PM
  #567
Cass007's Avatar
Cass007
Dave had an issue with the Vi-PEC not linking up with the accelerator pedal on the drive-by-wire. The tech rep for our area was in Florida for his birthday and had some kind of burst eardrum from the flight down and was in the hospital - just my luck. Dave is hoping to have things resolved by Monday or Tuesday at the latest. Now I just have to find a friend that wants to drive me to Virginia .
I may get in touch with your contact if things don't get resolved quickly - I just want to see the car on the road again. I don't mind waiting on the tune to be right, but waiting for a customer service issue would be unacceptable.
Old Mar 8, 2009 | 07:17 PM
  #568
Jay'Z's Avatar
Jay'Z
Can you please record up close to your engine sometime.. I wanna know if it sounds like mine..
Old Mar 8, 2009 | 07:19 PM
  #569
jtgli's Avatar
jtgli
If I weren't down here for vacation I'd drive you down. Glad to see how far along its coming. I get home thursday so I expect a ride friday at some point haha ; )
Old Mar 8, 2009 | 07:21 PM
  #570
Cass007's Avatar
Cass007
Second vid coming shortly.......takes forever to load. Did you see the question I had for you about your vacuum at idle? If not, how much vacuum are you pulling at idle? I'm around -12 psi on the Defi boost gauge.
Old Mar 8, 2009 | 07:28 PM
  #571
Sylvan Lake V35
Let me know my tuner had some issues as well that he managed to get straightened out. I can get you his number if its needed.
Old Mar 8, 2009 | 07:29 PM
  #572
Cass007's Avatar
Cass007
Some of the fun new noises the car makes:
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i556.photobucket.com/player.swf?file=http://vid556.photobucket.com/albums/ss9/cassese007/revups.flv">
I see many a ricer flyby in my future
Old Mar 8, 2009 | 07:30 PM
  #573
Jay'Z's Avatar
Jay'Z
Damn, I wish I could tell you taht.. I dont remember off hand.. I just dropped my car off again to have some scratches removed/painted.. I cant tell you till next wk prob.. Sorry..
I could have told you my Defi reading/HKS boost controller reading...
Old Mar 8, 2009 | 07:33 PM
  #574
Cass007's Avatar
Cass007
Aren't you in Florida for spring break?? As a fellow Nittany Lion, I must say that I am disappointed that you are still sober at this hour .
At the rate things are going I may need a ride down on Thursday if you are available. Keep your cell on and I'll let you know.
Old Mar 8, 2009 | 07:34 PM
  #575
Jay'Z's Avatar
Jay'Z
I wanna hear if your cams sound like mine and timing chain area..
Sorry I didnt see your post earlier....
Old Mar 8, 2009 | 07:51 PM
  #576
Cass007's Avatar
Cass007
I will be going back down tomorrow or tuesday, I will get another vid and post it for you.
Old Mar 8, 2009 | 07:54 PM
  #577
Jay'Z's Avatar
Jay'Z
Thanks!! Ill be sure to get you that info asap.....
Old Mar 8, 2009 | 08:22 PM
  #578
Chef-J's Avatar
Chef-J
Booooosstt!!
HolY!! it's comming!
Old Mar 8, 2009 | 10:22 PM
  #579
terps's Avatar
terps
nice when its up and running you should do a highway pull video with kickstart my heart for audio
Old Mar 8, 2009 | 10:49 PM
  #580
BlinkerFluid's Avatar
BlinkerFluid
It takes a lot of time and patience to get everything perfect Chris, you'll get there! Just remember, every issue you encounter and overcome is more blood, sweat, and tears that you have into the project. I can assure you, in the end when you mat the throttle and a grin appears on your face from ear to ear, it will all be worthwile. Most only dream of completing such a build as yours, the bumps and ruts have to be expected. You looked over my build for the GSX, I'm coming up on almost a decade of changing it and it's still not done!
I wouldn't get too hung up on the low run time compression numbers, it will come up when you get some miles on it and wear the rings in a bit. The units should be Psi. Also keep in mind that changing the static compression ratio and the camshafts will have an effect on cranking compression pressure.
The APS FMIC is a heavy piece isn't it? I didn't expect it to be that much weight when I got mine either. But hey, the more mass, the better it's heatsink ability.
The car is coming together looking awesome! I can't wait to see the highway pull videos.
