06 powerlab install underway
Old Dec 15, 2008 | 04:53 PM
  #41
IntenseFab's Avatar
IntenseFab
Intense Motorsports
Originally Posted by QuadCam
to install the aluminum oil pickup spacer, you need to:
1) unbolt the oil pick from the engine (oil pump actually).
2) place the spacer between the pickup and the oil pump.
3) install supplied longer bolts through the pickup and speacer.
4) hand thread bolts into the oil pump, then torque to spec.
I am assuming these are the instructions for this item. there's not a whole lot of other ways that this item could be installed. additionally, they may or may not want you to use some rtv on both sides of the spacer.
Well said, just to add, you only need to put RTV sealant on the grooved side of the oil pan spacer, then apply RTV to the grooves on the actual oil pan.
-Marc
Old Dec 16, 2008 | 06:03 PM
  #42
txshldm's Avatar
txshldm
B8BB8B88
UPDATE>>>>
Got most of the install done in the past 2 days. Tomorrow i will finish up with installing the UTEC, filling it with oil and running the line from the BOV to manifold. one question i have is where do I tap into for manifold pressure? I need to tap in for the utec and the BOV. I will post some pics up in a few.
thanks Keith
Old Dec 16, 2008 | 06:42 PM
  #43
txshldm's Avatar
txshldm
B8BB8B88
pics from today
Attached Thumbnails 06 powerlab install underway-img00066-1-.jpg   06 powerlab install underway-img00064-1-.jpg   06 powerlab install underway-img00063-2-.jpg
Old Dec 16, 2008 | 06:51 PM
  #44
SlideFox's Avatar
SlideFox
Nice work!! I'm assuming everything fell into place when you got the '06 pipe?
Old Dec 16, 2008 | 06:56 PM
  #45
txshldm's Avatar
txshldm
B8BB8B88
yes and no.... the down pipe was a PITA. I dont know how jeffie did the install by himself?? I didnt even work on the car unless i had a roomate around to lend a helping hand. Also the directions missed a few things, so i had to stop and take time to research. now that it is done i am glad i did a DIY and did not pay a shop. It let me understand my own car a little better!!
Does anyone know which line is the throttle body EVAP line?
Old Dec 16, 2008 | 07:01 PM
  #46
IIQuickSilverII's Avatar
IIQuickSilverII
keith..i think on e of your pipes is on backwards
it should look like this:
Old Dec 16, 2008 | 07:06 PM
  #47
txshldm's Avatar
txshldm
B8BB8B88
The pipe off of the TB? now that you say that i think it is. wierd... it all ligned up perfect. thanks for pointing that out jorge.
Old Dec 16, 2008 | 07:43 PM
  #48
SlideFox's Avatar
SlideFox
^^Yup... That last pipe is on back wards (from the throttle body).... flip it around and your good to go!!
Old Dec 16, 2008 | 07:44 PM
  #49
txshldm's Avatar
txshldm
B8BB8B88
damn i was just looking at it and i scratched the bottom of that pipe a little. and now the bottom will be flipped to be the top.
Old Dec 16, 2008 | 07:51 PM
  #50
SlideFox's Avatar
SlideFox
You should be able to use so polish to buff it out... depending on how bad it is...
Old Dec 17, 2008 | 05:00 AM
  #51
z2envy's Avatar
z2envy
Looking good man! Ya flip that pipe and if it's alil scuff you should be able to polish it out with a buffer. I had alil scuff on mine and was able to buff it out as well.
Props to jeffie also for doing that whole thing solo! I had to use my roomate for most of the build. I think jeffie has 4 arms...
*that blue Z looks familiar *
Old Dec 17, 2008 | 05:01 AM
  #52
UMW350Z's Avatar
UMW350Z
blanket the turbo!
Old Dec 17, 2008 | 08:25 AM
  #53
god350z's Avatar
god350z
want to know power putting down!
thinking of this kit fo rmy 06 z.
keep us updated.
videos !!!
Old Dec 17, 2008 | 08:31 AM
  #54
Cass007's Avatar
Cass007
keep us updated.
videos !!!
Similar build here - dyno numbers on page 10:
https://my350z.com/forum/forced-indu...o-install.html
Old Dec 17, 2008 | 09:00 AM
  #55
god350z's Avatar
god350z
alright nice.
so you are expecting 650hp on full out tune?
i am wanting to hit 600whp and be done.
Old Dec 17, 2008 | 09:03 AM
  #56
god350z's Avatar
god350z
do you have a list of complete mods?
like pistons or what not?
Old Dec 17, 2008 | 09:10 AM
  #57
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
alright nice.
Not on a stock block. This turbo kit is capable of 650whp on a built motor, but jeffie and the OP here have stock blocks. jeffie made 373whp on a DD dyno, which is probably closer to 400whp on a DJ.
https://my350z.com/forum/5677372-post188.html
Old Dec 17, 2008 | 09:13 AM
  #58
Cass007's Avatar
Cass007
alright nice.
Easy Trigger..... your bordering on flamable material here. I gave you a thread with a dyno # on it . Now start here and do some reading:
https://my350z.com/forum/forced-indu...ion-noobs.html
Old Dec 17, 2008 | 09:19 AM
  #59
SlideFox's Avatar
SlideFox
I'm so happy I made that thread...
Old Dec 17, 2008 | 09:30 AM
  #60
Cass007's Avatar
Cass007
- I have an idea, maybe we could have a mod set it up so that if you have <50 posts and you click on the F/I section it automatically pops up and you have to click one of those "I have read the terms and conditions of posting in F/I" buttons. Its such a great thread BTW.
