Crankcase Ventilation Mod w/Pics
Old Feb 24, 2011 | 02:19 PM
  #301
shakuya88's Avatar
shakuya88
Originally Posted by rcdash
Perfectly normal by product of combustion - no worries.
YAY! Thats good news. Thanks! I did a custom catch can for my setup with baffles etc. This is V2 of the design, if I make a V3, I think I'll try the hoses like you have them rcdash. That hose setup does look the best.
Old Jul 14, 2011 | 04:41 PM
  #302
thePunkville's Avatar
thePunkville
so for FI rcdash's system is best?!
Old Jul 15, 2011 | 08:43 AM
  #303
rcdash's Avatar
rcdash
I no longer have a connection between the catch can and the driver's side turbo intake. It didn't contribute enough to warrant the extra plumbing. This also eliminates another route for oil to get into the intake piping. Instead I left a check valve open to air on the catch can (along with another little breather filter). That provides another escape route for gases under boost.
Old Jul 15, 2011 | 01:50 PM
  #304
thePunkville
picture?!
Old Jul 19, 2011 | 09:51 AM
  #305
Tantaro348's Avatar
Tantaro348
Default greddy oil catch can on N/A engine..
This is how i put in my greddy catch can and i can see that it the inlet hose it a bit more yellow than the outlet hose...i think its working i guess..its been a month.
Attached Thumbnails Crankcase Ventilation Mod w/Pics-350z-engine-bay.jpg
Old Jul 19, 2011 | 12:08 PM
  #306
midz350's Avatar
midz350
If those are the stock greddy hoses then change them ASAP. they are weak and tend to close the ends up.
Old Aug 22, 2011 | 08:27 AM
  #307
Andrei's Avatar
Andrei
Originally Posted by JETPILOT
It is basically same thing Sharif did, but he ran his driver side breather to the catch can as well.
On NA it's causes a vacuum leak if it draws vacuum. I tried it and I'm 100% sure of it. Don't know if it still does with no vacuum drawn. Don't know how it wouldn't on FI.
Old Nov 11, 2011 | 10:40 AM
  #308
Tantaro348's Avatar
Tantaro348
haha yeah found that out like 2 days later...now i got better hoses. Thanks.
Old Jan 1, 2012 | 09:37 AM
  #309
binder's Avatar
binder
Where is everyone getting their check valves at?
I've been looking everywhere for a 3/8" check valve for my setup. I found some for an air compressor that are 3/8" NPT and would work good but they don't list which direction flow is on the website. I don't want to spend 11$ each if they are the wrong direction.
Old Jan 1, 2012 | 11:09 AM
  #310
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
This would work:
http://www.usplastic.com/catalog/ite...6843&catid=489
At $.70 you can't go wrong.
Old Jan 1, 2012 | 11:57 AM
  #311
binder's Avatar
binder
Originally Posted by Boosted Performance
This would work:
this is why you get paid the big bucks.
thanks!
Old Jan 11, 2012 | 05:23 AM
  #312
suprasam's Avatar
suprasam
Sorry, to continue beating this dead horse, but I'm getting a smelly, watery, yellow liquid in my catch can. Kind of like a watered down vegetable oil. I had about 2 shot glasses worth after my 1100 mile drive from South Carolina to Texas.
My plumbing is passenger and drivers valve covers to catch can then outlet to driver's turbo intake.
Old Jan 11, 2012 | 08:18 PM
  #313
rcdash's Avatar
rcdash
^ then you are getting rid of fuel and water vapor. It's working correctly!
Old Mar 2, 2012 | 11:16 AM
  #314
RA11325's Avatar
RA11325
Sorry to revive an old thread but what OD are the two valve cover ports, need to order some breathers for them.
Old Mar 2, 2012 | 11:56 AM
  #315
str8dum1's Avatar
str8dum1
5/8" for the drivers and like 3/8" for the passenger
Old Mar 2, 2012 | 03:26 PM
  #316
RA11325's Avatar
RA11325
Thanks so much.
Old Mar 10, 2012 | 08:20 AM
  #317
05Z33's Avatar
05Z33
I keep having to replace my seals on the vortech. I just reinstalled an upgraded seal from 928 motorsports, and was wondering if maybe the reason behind my seals going bad have somthing to do with my PCV setup. I have the driver side vented with a breather, and the passenger side has a catch can between the PCV and the plenum(not vented). Here are my options now.
1. replace catch can with a vented one and plug the plenum.
2. same as above with drilled out PCV.
3. drilled out PCV with breather filter.
The reason I ask is cause the new seals came with a pamphlet stating that an improper PCV setup can cause seal problems due to increased crank case pressure. What are your thoughts on this?
Old Mar 10, 2012 | 11:07 AM
  #318
rcdash's Avatar
rcdash
It sounds like your PCV may be letting boost back into the crankcase. Put another check valve in line with the intake manifold to prevent boost from getting into your catch can. Then you can opt to drill out the PCV if you wish, which will help out of boost evacuation only.
Old Mar 11, 2012 | 11:20 AM
  #319
binder's Avatar
binder
i'm failing to see the connection between vortech oil seals and crankcase pressure. Increased crankcase pressure will cause valve cover seals to fail but it won't do anything to the pressure inside the gearbox on the vortech unit.
Old Mar 12, 2012 | 07:03 AM
  #320
05Z33's Avatar
05Z33
I'm leaning towards capping the plenum and just venting the drilled out pvc through a vented catch can. I was going to also run a hose into the catch can from the rear driver side. I'm tired of getting soot all over my fire wall. Just have to find a good mounting spot for the can, because of how the Vortech is mounted.
This is per 928 Motorsports.
"If the crankcase is building pressure, the supercharger case (which drains into the crankcase) is building pressure too, and this may be the cause of the seal weeping. Vent the crankcase correctly and the seal leak may stop".
