Crankcase Ventilation Mod w/Pics
Old Jun 27, 2015 | 11:51 AM
  #361
rcdash's Avatar
rcdash
Originally Posted by meanz
That's how he's setup i believe. But under boost, oil sprays out of the breathers. It's kinda bad.
Then you can put a large catch can in between. That's the purpose of the catch can. Just use large diameter hoses so the hose itself does not impose a restriction for gas release.
Old Jul 3, 2015 | 03:16 AM
  #362
taywan's Avatar
taywan
I have breathers on drilled pcv and the rear driver valve cover. The middle hose that connects the 2 is still there.
Old Jul 3, 2015 | 05:25 AM
  #363
2bad240's Avatar
2bad240
Here is mine. It's mounted to the front of the radiator support. And one hose goes to the back of the driver valve cover the other hose goes to the drilled out Pcv. Mostly I find water in it with a oil skim on top.
Old Jul 3, 2015 | 01:07 PM
  #364
rcdash's Avatar
rcdash
Pretty nice spot. You get any fumes coming into the cabin at idle with the can mounted there?
Old Jul 3, 2015 | 01:10 PM
  #365
bmccann101's Avatar
bmccann101
I run a baffled catch w a breather off of it from.the drivers side valve cover.
I filtered each valve cover instead of a crossover tube. And I added a breather on the pcv.
I just bought a v1 arc catch can.. so now that I am officially a fancy pants..
ill route which ever filter gets the nastiest to the arc breathing can and call it a day.
Old Jul 3, 2015 | 01:18 PM
  #366
2bad240's Avatar
2bad240
No fumes at all. I used to have it in the engine bay and you could smell it then. Only real
Issue is there isn't enough heat in the bumper to cook the water out of it. So it fills with condensation pretty quick. Usually have to empty it once a month.
Old Jul 3, 2015 | 07:47 PM
  #367
taywan's Avatar
taywan
I'll prob run mine to a catch like you have 2bad, when I get it back anyways.
Old Aug 13, 2015 | 01:28 AM
  #368
R6n350GT's Avatar
R6n350GT
Thank god for this thread:
I have a brand new built engine top and bottom but with white smoking turbo with oil leaking at the hot side. was told turbo was damaged and need a new one.
Would this crank case pressure be the cause of not only the turbo but also no power being made past 15psi despite more boost ?
Tuner said it is valve float and I need to pull heads off and replace me BC racing springs on my newly built heads...
Old Aug 13, 2015 | 01:45 AM
  #369
R6n350GT's Avatar
R6n350GT
My PCV hose goes to my Saikou Michi catch can , the other side to the plenum . That's the current setup.
Reading every post I see now I should use 3/8" if hose
Block off plenum port
Drill out PCV and hose to IN of can
Drivers VC port to the IN of can and tee it into the PVC (since it only has one IN) and run the OUT of the can to my pre turbo intake near filter ?
Questions
Do I need check valves ?
Am I better of using 5/8" filter on the driver VC instead of running it to can
And am I better off putting a breather on the OUT of the can instead of running long hose to the turbo intake since can is mounted near the PCV
Thanks
Old Aug 13, 2015 | 08:34 AM
  #370
thatv35guy's Avatar
thatv35guy
I ended up drilling out the passenger side PCV and placing a breather filter on it, I also placed a breather on the back of the driver side valve cover, and blocked off the plenum port. Removed my catch can, check valve, etc.
Old Aug 13, 2015 | 09:04 AM
  #371
R6n350GT's Avatar
R6n350GT
Thanks for the help again. I asked the tuner for the oil pressure , dyno graphs but still waiting...
3/8" on PCV and 5/8" on the drivers side right ?
You don't have any oil leaking around the breathers ? The rear drivers VC do you use a 45 degree hose Angling up with the breather on top?
The PCV how much did you drill it out, just from the inside or you drill the outside opening also ?
And the drain back valve in the VC on the inside under the PCV valve u drill that out ?
So rcdash and all the one way valves in his diagram not needed ?
I was worried with not using the catch can made for the 350z it would smell with just the breathers..
Thanks once again. I wonder if this will fix my "valve float " issue and I can make more power
Old Aug 13, 2015 | 02:38 PM
  #372
i-break-things's Avatar
i-break-things
I'd check for internal crank pressure and the turbo drains. Nothin should connect to the intake, imo, even with a check valve and catch can. The pressure has no where to go when the valve is closed!
Turbo drains, -3 feed, should have a smooth fall direct the turbo to the oil pan or sump pump. The drain must enter ABOVE, the oil level in the pan. The turbo should not be mounted more 10*~20* , vert, of the feed to drain.
Old Aug 17, 2015 | 03:52 AM
  #373
rcdash's Avatar
rcdash
No check valves is best. That means not hooking any lines up to manifold since that sees boost. Turbo intakes are best source of vacuum because they are always in vacuum. (agree with last post)
Open breathers work and are simpler. Depends if you can tolerate fumes and dirty engine bay.
Old Sep 9, 2015 | 10:27 AM
  #374
R6n350GT's Avatar
R6n350GT
My current set up has the Drivers side rear VC port using a 5/18" / 16mm hose running to the pre turbo filter, the hose length is 150mm ... is there any point replacing this with the 90 degree hose and breather since its able to pull air in via that filter already?
Old Sep 19, 2015 | 10:11 AM
  #375
i-break-things
Only if your filter is getting soaked with oil or oil into the intake.
If you are not passing oil youre fine.
If you are getting oil up there vent it elsewhere.
Old Oct 22, 2016 | 04:59 PM
  #376
OdesiTT's Avatar
OdesiTT
Default What about na???
What about NA Z's? Do I need to drill PCV? We need a vacuum, so probably not. I just replaced my PCV with a new one, because I could blow trough it both ways with a little restriction. I just can't figure out what about drivers side. It seems like there is no PCV.
If I blow into drivers side port, air coming out from pcv valve on other side.
I know that crankcases connected to equalize the pressure, but is there no valve on the drivers side(I mean that port that should be connected to intake pipe)? Both my port vented to the atmosphere trough the catch can, but I'm interested why there no valve? It's causing leak, isn't it?
Help please! Thaks!
Old Oct 22, 2016 | 05:50 PM
  #377
Conway_160's Avatar
Conway_160
Help please! Thaks!
Yes drill the Passenger side, and no there isn't a check valve on the driver side. Your Catch can don't "Need" a vacuum but it helps.
Old Oct 22, 2016 | 07:14 PM
  #378
OdesiTT's Avatar
OdesiTT
I know its will help with turbo, but NA engine need a vacuum... Are you sure that NA engines don't need a pcv valve? Car runs much better with new PCV, idle and AFR is steady as never before.
Old Oct 22, 2016 | 09:22 PM
  #379
Swaglife81's Avatar
Swaglife81
I'm gonna run a basic oil/water separator with filter removed at the passenger side and cap of intake and run a breather on the driver side. I'm N/A stock right now and the car is at 200k but needs some new regular repairs first before I worry about a expensive setup. I just know how blowby is. Plus I found residue inside my intake before the TB and my TB was horribly dirty.
Stevo Z
Oct 3, 2015 09:14 PM
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
