HALTECH owners-need advice
Old Dec 17, 2008 | 06:27 AM
james12345pt's Avatar
james12345pt
Default HALTECH owners-need advice
I have recently installed an powerlab turbo kit and Haltech ems on an 06 g35 and am having several small issues. I would like some constructive input.
My issues are as follows:
1. SES codes 0151 and 0131 lean shift front o2 sensors
2. Bad cold starting- 3 attempts to start the car.
3. Running extremely rich at idle and cruising: 11 to 1 a/f, this is killing my fuel mileage.
4. ses codes: 0011 and 0022 cam timing
Thanks for any help in advance.
Old Dec 17, 2008 | 06:39 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
1. 0131 and 0151 - the fsm states o2 voltage ~0v. Check for disconnected o2 sensors or cut/melted wires.
2. Cold start needs tuning. Email me your map and I'll take a look and see if I can adjust. Not always possible, but I can often help clean this up for people without being there.
3. Needs to be tuned. 11:1 at idle and cruise is verry rich, this will not only kill gas mileage but also plugs, o2 sensors, cats, etc
4. 0011 and 0022 are soft codes that will not cause trouble or trip the CEL on their own. Once your other CEL codes are resolved these will sit quietly in the background and not give any trouble. They are caused by Haltech having complete control of cam timing, and the stock computer noticing. If you are dead set on wanting them to go away we have two options: reflash so the stock computer does not check on that, or rewire the harness and take cam timing control away from Haltech and give it back to stock computer.
Old Dec 17, 2008 | 06:48 AM
james12345pt
Default Hal to the rescue
Thanks for input Hal, You will be fixing these things for me on Jnauary 5th.
I was posting to get any response from others on the board. One question: I did notice some unconnected wires in the wiring harness at the haltech connection. One was red with a solid black stripe. Are some of the wires not connected from the factory on purpose?
Old Dec 17, 2008 | 06:52 AM
Dynosty's Avatar
Dynosty
No, they come fully wired. The only thing exposed are the 3 breakout connectors which have 2, 3, and 4 pin connectors crimped on the ends. The red/black wire(s) you speak of could likely be wideband bank 1 and 2 inputs if they were cut for aftermarket wideband wire-in.
Old Dec 17, 2008 | 08:21 AM
SlideFox's Avatar
SlideFox
Hal is the man!!
Old Dec 17, 2008 | 09:48 AM
rcdash's Avatar
rcdash
just sounds like you need the car tuned.
Old Jan 10, 2009 | 11:35 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Not quite true, 0011 and 0022 will trip the CEL. Those are the only two codes I ever get when I clear my codes b/c the CEL light is on. Probably about every 100 miles or so.
Old Jan 10, 2009 | 12:18 PM
rcdash's Avatar
rcdash
Haltech + Osiris FTW! No more useless CELs. Thanks Hal and Jared! Hal you should start a reflash service, just to remove a few of the troublesome CELs, as a pkg deal with the Haltech.
Old Jan 10, 2009 | 12:52 PM
Dynosty's Avatar
Dynosty
Dave, you are the first car I've heard of with 0011 and 0022 tripping the CEL. You are certain there are no other codes?
rcdash, good idea. I may do just that.
Old Jan 10, 2009 | 01:22 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Bummer. Sometimes being unique is good. Sometimes, not so much...
Old Jan 10, 2009 | 01:23 PM
SmallTuner's Avatar
SmallTuner
what will happen if we set the cam timing map set all to 0 ???
is it gonna be as stock ???
Old Jan 10, 2009 | 01:32 PM
Dynosty's Avatar
Dynosty
Then your cam sprockets will sit at 0 degrees.
Old Jan 10, 2009 | 01:48 PM
SmallTuner's Avatar
SmallTuner
ehehehee that realy helpd me allot.
what about the DE engines ? is it controling the intake and exhaust ?
or only intake ?
Old Jan 10, 2009 | 03:03 PM
Dynosty's Avatar
Dynosty
Intake/exhaust depends on what your motor is equip with. Non-revup VQ35DEs have variable intake cam timing only, and revups have variable intake and exhaust cam timing. Haltech Platinum has separate tables for intake cam timing and exhaust cam timing.
Old Jan 11, 2009 | 03:19 AM
SmallTuner's Avatar
SmallTuner
thanks, things are clear for me now
liqalu04
Jan 2, 2022 12:58 PM
