Vortech oil feed
Woah wait .. are you talking about the return or the pressure line? You don't tap the block for the feed line.
The return line must be tapped into the upper oil pan. Either that, or get a new pan with a return line fitting already on it. I tapped the upper oil pan for my return per the instructions because I didn't want my return line beneath the oil level.
The pressure line can absolutely be tapped into a sandwich adapter on the oil filter, but it isn't necessary. You can just use the supplied fittings and tap into the oil pressure sending unit - it's a piece of cake.
