APS ST and EMS/Uni-chip question
Old Jan 7, 2009 | 12:29 PM
DracoLancet04Z's Avatar
DracoLancet04Z
Default APS ST and EMS/Uni-chip question
Ok here is the deal, in October i had my APS ST installed, it has been running great, burning a bit of oil though and i had to use the stock exhaust until i got a new exhaust. (which i ordered today) A few weeks ago, i had a problem with my positive battery cable coming off the post, i have since fixed the problem, but before i did it happened often enough that it started setting off the service engine light and spit out a code saying there was a short to the ECU, once i fixed the issue the light never came back on.
here is the question, since then i have only been boosting up to 6psi when my former tune was set to 9psi, has the tune possibly been lost through all of the times of resetting the ECU from the cable coming off? (needed to get a new tune anyways with the new exhaust coming in but i just wanted to check)
Thanks in advance
Old Jan 7, 2009 | 01:19 PM
athenG's Avatar
athenG
Answer is no... look at at this way, if you did loose your tune then you should've been fvvcked even at only 6psi
Old Jan 7, 2009 | 01:23 PM
westpak's Avatar
westpak
SFZCC
nope as already mentioned
If I remember right the unichip controls boost I can see your concern that something was lost.
If not boosting you have a leak somewhere or the boost control solenoid is damaged
Old Jan 8, 2009 | 09:41 AM
DracoLancet04Z
Thanks guys, i will use the time that i have the car on jack stands putting on my exhaust to see what i cant find.
Old Jan 8, 2009 | 11:27 AM
ToastZ's Avatar
ToastZ
You need to pm Zivman. He has installed a number of these APS-ST kits over the past several years and is very familiar with the problem areas.
Old Jan 8, 2009 | 03:25 PM
Jay'Z's Avatar
Jay'Z
Post pics of the installed exhaust or fail!!
Old Jan 8, 2009 | 04:53 PM
Zivman's Avatar
Zivman
for the record, only 1 APS single, a full APS TT install on my car, then again when I built the motor, then again when my buddy bought his car. I have also done a Vortech kit. I don't need to get into the N/A parts I have installed because as we all know they are worthless
In regards to the OP's situation, it could be a lot of things. The fact that he had a short somewhere would make me think he could have shorted out the solenoid. He potentially could have a boost leak somewhere, which is always a potential issue. With the car burning oil, I wouldn't worry about it yet. Get your new exhaust on, that I will add, should have been installed when you originally installed the kit. Get the exhaust on, recheck your oil levels, recheck wiring the solenoid/unichip, and see where you are at
Old Jan 8, 2009 | 05:02 PM
ToastZ's Avatar
ToastZ
Your obviously qualified to give advice, lol.
Old Jan 8, 2009 | 05:14 PM
Zivman's Avatar
Zivman
maybe.... regardless, it is hard to diagnose over the net. One ride in the car and a peak under the hood could tell me 10 pages worth of descriptive writing on the forum
Old Jan 8, 2009 | 05:20 PM
ToastZ's Avatar
ToastZ
very true.
Old Jan 8, 2009 | 05:22 PM
Nexx's Avatar
Nexx
Dragon, what oil are you using btw?
Old Jan 9, 2009 | 12:26 PM
DracoLancet04Z
Eneos 0 - 50 at the moment, just changed my oil to it.... starting to think that the really thin oils in this constant 80 degree weather that we are having might cause a slight oil burn too
Old Jan 9, 2009 | 01:48 PM
Zivman's Avatar
Zivman
try something like the standard 10w40 amsoil.
Old Jan 9, 2009 | 11:40 PM
Nexx's Avatar
Nexx
+1 anything but enos. that stuff burns in the VQ, it did in mine and US HM 350z's car. i highly recommend Rotella Tsyn 5w40, Castrol Syntec 0w30 european formula or M1 0w40. amsoil is good stuff too.
Old Jan 10, 2009 | 09:24 AM
DracoLancet04Z
i had motul in it before and it was burning as well
Old Jan 10, 2009 | 10:15 AM
terps's Avatar
terps
aps recommends 10w40, otherwise there is possibilty of oil passing through turbo seals and heavy smoking issues, ehhh i stilll use 0w40 m1 euro but ive noticed alot more burning oil than when i used the 300vchrono motul 10w40. but the stuff is expensive!
Old Jan 17, 2009 | 07:36 PM
DracoLancet04Z
yeah i was under her today.... oil is gathering on the outside of the condenser housing of the turbo....... the exhaust sounds fantastic though
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
