the next CJM intake
Old Jan 23, 2009 | 02:36 PM
  #61
phunk's Avatar
phunk
CJ Motorsports
Definately won't clear aps strut bars
Old Jan 23, 2009 | 06:46 PM
  #62
XKR's Avatar
XKR
Keep it coming Charles......Looks good.
Old Jan 23, 2009 | 06:58 PM
  #63
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by phunk
I sold my aps plenum so we would only have stock for comparison...
thow a spacer in there. I think maybe Larry can do this as well....
Old Jan 24, 2009 | 05:23 AM
  #64
QuadCam's Avatar
QuadCam
looking very good charles!
Old Jan 24, 2009 | 07:43 AM
  #65
synth19's Avatar
synth19
Well done Charles!
Old Jan 28, 2009 | 05:46 PM
  #66
deyj28's Avatar
deyj28
looking good charles!
Old Jan 29, 2009 | 06:48 AM
  #67
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
You had me until you mentioned it can't clear the APS strut brace.
Nice work!
Old Jan 30, 2009 | 10:12 AM
  #68
TTRANK's Avatar
TTRANK
That thing is awesome looking. Can't wait to see the initial test results.
Old Jan 30, 2009 | 10:28 AM
  #69
Motormouth's Avatar
Motormouth
with the intake moved to the front, I bet a three point strut brace can be used much easier. like the Evo.
much stiffer.
Old Jan 30, 2009 | 02:55 PM
  #70
Snow-G's Avatar
Snow-G
That looks bad azz. Looking forward to the results.
Old Jan 30, 2009 | 05:33 PM
  #71
phunk's Avatar
phunk
CJ Motorsports
brandon did some more prototyping today without me... so im looking forward to seeing updates myself now LOL! he finished up the cad changes for the throttle mount and machined another proto... so if we like it its go time.
Old Jan 30, 2009 | 07:13 PM
  #72
Motormouth's Avatar
Motormouth
so could you detail your method on choosing this design and calculating expected gains, what cams you made this with, header style...
also, stock throttle body good enough or did you contemplate using a larger bore TB? why didn't you?
what is your testing plan going to be, how will you quantify the gains, how long will testing take?
Old Mar 9, 2009 | 09:57 PM
  #73
Reyes5937's Avatar
Reyes5937
bump for updates
Old Mar 10, 2009 | 10:24 AM
  #74
phunk's Avatar
phunk
CJ Motorsports
we finished all the design work, just never cut one out. when i get closer to needing one for my car (my car is a few months away from running now), or if someone decides to purchase one, its ready to go! we have to work with each customer to make sure that its going to meet their needs, as each one will be a little custom depending on those needs.
Old Mar 10, 2009 | 01:47 PM
  #75
rrmedicx's Avatar
rrmedicx
Well Cut one out cause we need Pix Charles? Nothing makes us happier! LOL
Old Mar 10, 2009 | 05:19 PM
  #76
XKR's Avatar
XKR
Charles...I will have Sharif update you when we will need you and the plenum to show up. Just make sure mine has #000001 stamped on it
Old Mar 10, 2009 | 06:34 PM
  #77
phunk's Avatar
phunk
CJ Motorsports
we will naturally get to it even if no one purchases now, we have just been working on catching up on our existing things as usual, along with all of our new VHR stuff.
Old Mar 10, 2009 | 06:35 PM
  #78
phunk's Avatar
phunk
CJ Motorsports
XKR: Ill stamp yours 0001 no problem, as long as mine can say 00000
Old Mar 10, 2009 | 06:45 PM
  #79
XKR's Avatar
XKR
ok ...
Old Jul 9, 2009 | 08:39 AM
  #80
phunk's Avatar
phunk
CJ Motorsports
almost finished this up.
couple updates... looks a little different but not much. picture one is the last mdf prototype and i put some elbows on the throttle just to verify it all clears the radiator fan setup etc for those who will run piping that way.
the last picture shows it on my car in the middle of manufacturing stages for test fit... notice that i will not be running an elbow on mine, im going straight into the top of the intercooler. i only had to lower the radiator a bit by modifying the bushings it mounts on... pretty easy. did have to cut off the hood latch tho! so hood pins it is.
remember we said between $2000-$3000... well thats changed. we are now looking at $1600-$2200 depending on some final things we have to arrange. i am hoping to get this as far under 2 grand as possible, almost have it all figured out.
