Project SAA3! Game On!!!
Old Apr 17, 2009 | 07:44 AM
  #181
CrazyVQ35tt's Avatar
CrazyVQ35tt
I have been to Sebring raceway with my car many times it takes time and money to run their. Central Florida road course is a slow course but it is open all the time and only cost around $75 a great place to shake down the car and make sure there's no problems. I will be at the end of Andrew Street with the guys working on the Corvettes around 12 I will walk to Andrews and see if you guys are there.
Old Apr 17, 2009 | 11:10 PM
  #182
JETPILOT's Avatar
JETPILOT
I forgot about Central Florida... I will have to try it some time.
We won't be back at the garage until Monday afternoon to finish it up.
Sebring is very expensive. It takes it's toll on your car with the bumps, and you use gas there in crazy amounts becasue of that long straight. It's hard on brakes as well. Come to think of it tires don't last long either.
A word to anyone who purchases this kit.... if you are moving fro mthe Greddy TT you will need to remove the Greddy power steering line fitting and install the OEM PS line fitting. The piping won't fit with the Greddy PS fitting.
If you have the SVRT solid engine mounts you will need a 1/2" spacer instead of the 1/4" spacer provided in the GTM kit since the SVRT engine mounts are 1/4" lower than OEM. The steering knuckle included in the GTM kit will not fit if the car is not raised 1/4" over OEM height. GTM can include another set of 1/4" engine spacers if needed I was told.
With the motor 1/4" over OEM height the GT Spec dry CF bar will fit with a few mm to spare.
Old Apr 22, 2009 | 06:35 AM
  #183
ToastZ's Avatar
ToastZ
Originally Posted by JETPILOT
Unfortunately we had a few setbacks that will keep us from getting the car completed in time to run at Sebring on Saturday.
Jet, How are things progressing ?
Old Apr 22, 2009 | 12:45 PM
  #184
JETPILOT's Avatar
JETPILOT
I am still waing on one part from Nissan. The OEM power stearing output fitting that you have to change when you put the Greddy kit on. I now need the OEM one to fit properly. I have been waiting since Monday.
The part will be here tomorrow. The car should start tmorrow or Fri and Monday it goes to JapTrix for the FCON tune. Sebring May 2nd come hell or high water!
9 DAYS TIL SEBRING! Again!
Old Apr 23, 2009 | 06:53 AM
  #185
rrmedicx's Avatar
rrmedicx
Damn. Cutting in close. Good Luck Jet!
Keep us posted on initial start up.
Old Apr 23, 2009 | 08:22 AM
  #186
GreenGoblin's Avatar
GreenGoblin
good luck bro, I hope it all gets buttoned up
Old Apr 30, 2009 | 11:37 AM
  #187
Jason333's Avatar
Jason333
hi
Where did you have your tow hook with the Greddy setup? I assume the track requires it.
Old Apr 30, 2009 | 11:48 AM
  #188
Jeremy@Altered's Avatar
Jeremy@Altered
You could easily have one that is made to bolt to the front frame next to the intercooler.
Old Apr 30, 2009 | 12:32 PM
  #189
Jason333's Avatar
Jason333
hi
Hmm I need to look into that. Ill get with ya in May for an idea.
Old Apr 30, 2009 | 12:36 PM
  #190
Crom's Avatar
Crom
Like mine... Jet loves it too...
Old Apr 30, 2009 | 12:42 PM
  #191
Jason333's Avatar
Jason333
hi
Link it Crom?
Old Jul 31, 2009 | 08:53 AM
  #192
djtimodj's Avatar
djtimodj
What the hell happened to this build?????? Any updates??
Old Jul 31, 2009 | 09:12 AM
  #193
warmmilk's Avatar
warmmilk
JETPILOT quit the FI section cause of all the fan boi's and nut huggers:
https://my350z.com/forum/7289850-post73.html
he still occasionally posts in the suspension section, or at least he used to...
350Z_Al
Oct 29, 2020 07:44 PM
Dymsi
Sep 29, 2015 11:32 AM
