Project SAA3! Game On!!!
hey JET, why didnt u guys install the down pipes befor puting the engine back ??
if u can get me some info about the down pipes installation, can u reach the turbine studs from under the car with the gear installd ???
It's easier to install the engine from the front of the car without the downpipes instale3ld. The downpipes can be reached under the car wit hthe trans installed with an imaginative collection of extensions and swivels about 2 feet long.
Andrew and I ran into a problem tonight the looks like will be the end to my outing at the track. I am using SVRT solid engine mounts which are 1/4" shorter than the OEM mounts. When we went to put in the replacement stearing universal joint supplied with the kit it was not going in. We had to loosen the drivers side engine mount and use the engine hoist to lift the motor to get the universal joint in. Then when we lowerd the motor the universal joint was rubbing against the turbo turbine housing. I need to get a thicker spacer.
So it looks like Saturday isn't happening for me. Too bad.... we were so close! Losing the $400 track fee and $300 hotel reservation deposit hurts too.
I get the big Ffor FAIL!
We are having a 1/2" spacer made this afternoon. I am going to pick it up in about an hour. This should fix the problem. We will make another attempt to finish the car tonight and have it at Japtrix for the tune at 8AM Thursday. Hopefully they can get the tune done by Friday night by closing.
I hope I can finish it tonight. I hope there are no more issues.
