question about a build
Old Feb 2, 2009 | 02:38 PM
zulator03's Avatar
zulator03
Default question about a build
hey z guys i gonna go and get my car turbo soon. i wanted to hit anywhere from the 50 to 600 hp range i think that is pretty high
I wanted to know if these parts will let me get around the hp range i was looking for
Greddy turbo
Greddy Intercooler
pauter rods
DW 600cc Injectors think that should be good
defi a/f guage
walbro pump
still undecided about what cams
Wiseco 8.8:1
Haltech ems
GTM GReddy 3" Down pipes
GReddy Turbo Ti-C exhaust
Zex 35 Shot Wet Nitrous System or 70
Clutch Masters FX600 Twin Disc Clutch
HKS Navigator
Question aboutgreddy profec e-01 with that i can control the boost inside the car. I know that people are going to laugh at this but i was wondering if that build could hold 600 hp
Old Feb 2, 2009 | 02:46 PM
Car vs. Driver's Avatar
Car vs. Driver
Probably ... depends on the quality of the tune and build.
Keep in mind, going from 500 to 600 is a HUGE increase in power. Pick one or the other and build to that.
Old Feb 2, 2009 | 02:56 PM
thom000001's Avatar
thom000001
bearings?
Head gasket?
Connecting hardware?
What about those? If you're already going to be in there might as well upgrade. You won't need the nitrous setup.
tom
Old Feb 2, 2009 | 03:00 PM
Car vs. Driver
I know I sound like a broken record, but ... who's your tuner and engine builder? Have you consulted them yet? That's probably who you need to be asking. You'll get eleventy billion different answers in this thread
Old Feb 2, 2009 | 03:02 PM
8cd03gro's Avatar
8cd03gro
de or hr?
Old Feb 3, 2009 | 08:08 AM
zulator03's Avatar
zulator03
its a de and my tuner would be forged performance idk what elses i would need i think that 500 hp is good enough
Old Feb 3, 2009 | 08:12 AM
XKR's Avatar
XKR
Didn't Forged give you a list of what you would need to hit 500 Knowing Sharif I am sure he gave you a list
Old Feb 3, 2009 | 09:02 AM
IIQuickSilverII's Avatar
IIQuickSilverII
Greddy turbo check
Greddy Intercooler
pauter rods go eagle
DW 600cc Injectors think that should be good i guess thats fine for 500-600hp?
defi a/f guage check, add boost gauge
walbro pump
still undecided about what cams no need for your goals
Wiseco 8.8:1 wiseco is good
Haltech ems good call on the standalone
GTM GReddy 3" Down pipes check
GReddy Turbo Ti-C exhaust check
Zex 35 Shot Wet Nitrous System or 70 no need for your goals, unsafe, rice warning?
Clutch Masters FX600 Twin Disc Clutch ok, but way better options out there
HKS Navigator you just said haltech...
I would also add L17s head studs, HR gasket. For those goals a lot of things you can keep stock. I would suggest a fuel return system as well.
you were already shooting for overkill, unless you are still back in 2005. if you do haltech ems, then have the haltech control boost
Old Feb 3, 2009 | 09:43 AM
Cass007's Avatar
Cass007
Thats a check to Quick's checks
I would get a slightly larger injector as well maxing out injectors is not good.
Old Feb 3, 2009 | 10:34 AM
thom000001's Avatar
thom000001
return fuel system?
Old Feb 3, 2009 | 11:24 AM
chopperman's Avatar
chopperman
If you are trying to reach 600hp at the wheels you will need bigger fuel injectors. If you have 600 at the wheels then that means you have more than that at the crank, so your 600cc injectors wont cut it. 750cc would be a good choice.
Old Feb 3, 2009 | 02:49 PM
zulator03's Avatar
zulator03
i thought for 500 and up you should get pauter but ok i get eagle thank you
DW 750cc injectors thank you
defi a/f guage boost gauge
walbro pump
I need better clutch i need help with that also
L17s head studs
HR gasket.
return system
zulator03's Avatar
zulator03
kk do u think i need anything else i rahter spend all mioney at once but if u guys can get anything elses or add anything elses thank you
Old Feb 3, 2009 | 04:00 PM
Cass007's Avatar
Cass007
pathfinder cooling mod and you will need the engine rebuild gasket kit (forged will have both)
Old Feb 3, 2009 | 06:16 PM
IIQuickSilverII
before the pathfinder mod i would look at adding a radiator IMO...in any case, i havent seen any data on it but i heard it works
there are plenty of options for clutches... my friend derek had excellent results with the rps max 6-puck+fly combo at ~ 580's whp
Old Feb 3, 2009 | 06:22 PM
thom000001's Avatar
thom000001
Yup lots o clutches out there.
Southbend has some good pretty cheap ones too......like mine but it just handle the powah anymore.....poor clutch. I could sell it to ya if you're interested though.
tom
Old Feb 3, 2009 | 07:55 PM
zulator03's Avatar
zulator03
ok so rps max 6-puck+fly combo for the clutch think that is everything now thank you i guess that my build gonna c if i can find more parts for safer build
Old Feb 6, 2009 | 08:14 AM
zulator03's Avatar
zulator03
finally thank you z community here the final build hope it can hit 550 around there
Greddy turbo
Greddy Intercooler
eagle rods
DW 750cc injectors
CJM walbro pump
Wiseco pistons
Haltech ems
aam 3" Down pipes
L17s head studs HR gasket
jwt cams
toyo R888s
koyo raditor
THANK you all see you sooon forged cant wait
Old Feb 6, 2009 | 01:02 PM
chopperman's Avatar
chopperman
Definatly sounds like a solid build. What exhaust are you going to run?
Old Feb 6, 2009 | 02:25 PM
Cass007's Avatar
Cass007
Greddy turbo
Greddy Intercooler
eagle rods
DW 750cc injectors
CJM walbro pump
Wiseco pistons
Haltech ems
aam 3" Down pipes
jwt cams
toyo R888s
koyo raditor
Koyo is a waste of money IMO. If you get the pathfinder mod I suggested (and I have heard XKR say that Sharif recommends) you should not need the additional cooling.
BTW, I think you can get the APS 3.5" downpipes (testpipes) for $269.00, you may need to get the APS 3" true duals with this (turismo used this setup on his Greddy), but it may save you like $400 (not sure on the math, I've had a few drinks).
Here are the links - see for yourself:
http://www.alteredatmosphere.com/mm5..._Code=350Z_EXH
http://www.z1motorsports.com/350_g35...b7fb8e06eacd6b
