My Engine and procharger issues
Old Sep 15, 2003 | 05:57 AM
  #221
zland's Avatar
zland
Sport Z Magazine
I got my Ravez fix for the day and it is a good one. Wow, entertaining to me, costly to you. This one will be a beast once it is built. I cant wait to see the dyno. Yes, we are learning and unfortunately at your cost. I feel for you...Jeff
Old Sep 15, 2003 | 06:55 AM
  #222
Chebosto's Avatar
Chebosto
did you calculate to see if the 14psi's pulley size is safe enough for the impeller speed of the turbines? what is ATI's limit?
sounds like a plan Bill
Originally posted by ravaz
Here are the list of parts we are upgrading so far:
14 Pound pulley
Old Sep 15, 2003 | 07:00 AM
  #223
ravaz's Avatar
ravaz
ATI's site says the C-2 will run up to 30 psi.
Old Sep 15, 2003 | 07:24 AM
  #224
Edretti's Avatar
Edretti
ravaz, I'm glad your satisfied with the plan you guys worked out. How satisfied you are is what matters and not what we think. I'm curious to know how much additional money your looking at with parts for all the upgrades. I know the labor might be a special deal but just curious about parts although I know that you haven't decided on a clutch yet.
Old Sep 15, 2003 | 07:26 AM
  #225
etx's Avatar
etx
wow wow! ravaz i cannot wait to see that setup on the Z! Thats about what I am runing on my eclipse and about 14 psi so far. At 14 psi this little dodge motor doubled its hp, and its only a 2 litre motor. 14 on a 3.5 is going to be fun! and that ati sc pushes a lot more air, i cannot wait to see the dyno on that thing!
Old Sep 15, 2003 | 07:55 AM
  #226
ravaz's Avatar
ravaz
Labor is heavily discounted, and parts are all at cost. It should be a fun project, and hopefully nothing will blow up this time.
Old Sep 16, 2003 | 07:21 PM
  #227
HotRodGuy's Avatar
HotRodGuy
Default Re: Re: Re: Re: Re: Overboard
Originally posted by zland
I guess You can say I am biased against American cars (from my experiences) but I did not know the average mustang went 150K without any mods? All of my American made cars seem to have been pretty beat by about 100,000K.
again, it all depends on the owner and how they maintain their cars
what experiences have you had w/ domestics.
Old Sep 16, 2003 | 08:30 PM
  #228
zland's Avatar
zland
Sport Z Magazine
My experiences of domestics vs imports were as stated. I did not maintian either one differently. What i did notice was that American products tended to break more often and that the manufacture tended not to modify their product due to known problems where as Japenese products that had a problem, they problems were fixed and changed in manufacturing.
Again, this has been my experience and I can give you very specific examples of both.
In Addition, I had more unsatisfactory experiences with domestic dealers. Ford, GM, and Dodge products tended to not fix anything under warranty even if it was 20 miles out of warranty where as Japanese products i have own tended to fix things even when they were a little out of warranty.
Old Sep 16, 2003 | 09:44 PM
  #229
Buub's Avatar
Buub
Default Re: Re: Re: Re: Re: Re: Overboard
Um... lumping all American cars in one pile is like saying "Japanese cars" or "European cars".
Most performance-oriented American cars are V-8s. A V-8 has to work a lot less to get horsepower and torque than a 6 or 4 cylinder. Heck my '76 Cougar went way past 100K and it was a piece of crap. But the V-8 in that sucker was unkillable. I even heat-locked it once when I ran out of radiator coolant. I thought for sure I had just welded my pistons to the block. Came back an hour later, and it started up like nothing had ever happened.
Now American four-bangers, there are some really mediocre engines...
Old Sep 16, 2003 | 10:18 PM
  #230
zland's Avatar
zland
Sport Z Magazine
You have had different experinces than myself. I have won 4 and 6 cyc domestic only, no V-8's
Old Sep 17, 2003 | 01:35 AM
  #231
jreiter's Avatar
jreiter
This is the statement that I'm concerned about. The amount of boost that a turbo or blower can make depends on the size of the engine it is connected to (amongst other things). You should verify with ATI that the C2 blower can safely and efficiently generate 30 psi on the VQ35DE engine running 9.5:1 compression. Or if you only plan to run 14 psi, then all the better. But you should still verify with ATI that the C2 can manage it safely and efficiently on your motor with it's custom modifications.
The bigger the engine gets, the harder a specific blower (or turbo) has to work to make the same boost. A blower that maxes out at 30 psi on a 3.5 liter engine cannot efficiently make 30 psi on a 5 liter engine. You'll have to get a larger blower to handle that 5 liter engine. You could keep the smaller blower, but you'd have to run less boost with it.
But anyway, I'm not saying ATI is lying. Not at all. I just think it'd be a good idea to verify with them that the C2 blower at 14 psi will be efficient on your particular setup.
If not, it'll just be blowing a lot of hot air.
Old Sep 17, 2003 | 06:22 AM
  #232
Buub's Avatar
Buub
I remember ATI posting on a different thread that the blower is way under its limits on the Z, and that it has a lot more RPMs left in it on the standard pulley.
Old Sep 17, 2003 | 06:23 AM
  #233
HotRodGuy's Avatar
HotRodGuy
What specific examples have you given me
I sure haven't found it in this post. There are good and bad dealers w/ all cars, there are good and bad problems w/ all cars. You still haven't given me specifics.
I don't know what you are talking about when you say they fix problems mid production and such. What problems are you referring to?
I've had the warranty issue you mention go both ways for me.
Old Sep 17, 2003 | 06:24 AM
  #234
HotRodGuy's Avatar
HotRodGuy
Default Re: Re: Re: Re: Re: Re: Re: Overboard
why was this directed at me
Old Sep 17, 2003 | 08:09 AM
  #235
ravaz's Avatar
ravaz
I'm pretty sure my tuner has contacted ATI about this and I'm pretty sure they said there would be no issues with this, but who knows, I don't know of anyone that's done internal modifications including lowering the compression and running the Procharger on the Z's engine. All I know is they agreed to hook us up with the smaller pulley, so I'm thinking all will be good, I guess we'll see. I'm just dying to see how this all works out for my car, I really hope it works out for the best, I seriously won't be rebuilding this again if anything goes wrong. All I know is I want my car back before the track closes down, and I want to drive this thing soon!
Bill
Old Sep 17, 2003 | 10:08 AM
  #236
kurt leonce's Avatar
kurt leonce
didn't top secret build a VQ35 and put it in a r34 skyline, they were getting about 800whp, Im sure about that.
Old Sep 17, 2003 | 10:40 AM
  #237
ravaz's Avatar
ravaz
I'll take 800 whp
Old Sep 17, 2003 | 10:47 AM
  #238
ForceInduction's Avatar
ForceInduction
Very true on a lot of the statements you made.
The blower might have a maximum boost rating of 30psi but in a lot of causes you cannot get that much psi out of it. You may need to look into the maximum impeller RPM of the blower and how much airflow your engine has.
In a lot of cases you will reach the maximum RPM rating on the blower before you reach the maximum PSI rating. If you go over the maximum RPM speed on the blower you will over spin it, causing harm to the head unit.
I have found out that in a lot of cases ATI blowers can reach 14psi easily. But to be safe you may need to contact ATI so they can calculate the speed of the impeller on the C2 blower on your engine.
Old Sep 25, 2003 | 11:04 AM
  #239
ravaz's Avatar
ravaz
Update*
Check this out:
-Bill
Old Sep 25, 2003 | 11:09 AM
  #240
kurt leonce
looks like it run lean
was it only one bad piston, how dose the others look
