XKR Super G... Going for Mach 1
Old Jul 15, 2009 | 07:22 AM
  #661
str8dum1's Avatar
str8dum1
it took SP 25 psi to make 1033 with billet 6262 turbos on their race car. that was on a mustang dyno with a 3.5L
i didnt know you 'only' wanted 1000 hp on a dynojet. LOL. I just figure since you got it, you'd see what it can do! Probably could run to high 30's if Sharif's ***** were big enough.
a nice lil comparison between 35 and 6262
https://my350z.com/forum/6340374-post74.html
Old Jul 15, 2009 | 07:53 AM
  #662
D350Z10's Avatar
D350Z10
MikE!!!
Looking good, car is gonna be a monster. Any plans to cage?
My car just arrived at Forged today..... getting a few things done to spice it up
Old Jul 15, 2009 | 10:10 AM
  #663
XKR's Avatar
XKR
...Sam/George said with this setup...1100whp will be easy......So 1000whp will be good enough for me......
Originally Posted by D350Z10
MikE!!!
DIL !!!!!!!!! Is that you???? Thanks man...Yeah...as soon as its shipped back to me...I will have it done. I am having it done at a place here in houston. I am worried about "Body TQ"...So I will have it done for sure.
ZdayZ next year??
Old Jul 15, 2009 | 12:00 PM
  #664
D350Z10's Avatar
D350Z10
Very Nice,
My plans are to attend Zdayz next year as of now.
I am about to cage my car as well, are you doing anything to make it look nice? (wrapping in suede..etc)
We gotta run next year for sure, but were gonna need a way bigger strip.
Im adding a few mph to my trap speed
Old Jul 15, 2009 | 01:33 PM
  #665
XKR's Avatar
XKR
Very Nice,
yes.... I will use the same black suede that Alex/FP installed.
Getting a longer runway would be kool.... But you know that Raj ain't having it..
Glad you are coming to the next one... It was fun
Old Jul 15, 2009 | 01:42 PM
  #666
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
car looks really good man!.. I must say though.. even though I like those big a@@ turbos.... I like those breaks more!! got anymore pix? hehe =)
Old Jul 15, 2009 | 01:54 PM
  #667
XKR's Avatar
XKR
Thank you sir... Click on the Cardomain link at the bottom of my sig.
I said I would not hide anything on this build...and I told Sharif/Sam to do the same....I want this build to become the norm....
The section at the Crank was custom built to Strengthen the bottom end....I think Sharif/Sam called part of it "Girdle".....I thought I had taken a pic of that bottom to show...but I cant find it.....Rev's and high boost will not be an issue for sure on this build. This motor is being built to hold the max of the GT35 x 2 which is around 1200.......I just found out that is 400 whp more than i will need for my plans.. ...But the good news is...atleast I would not be pushing by motor to the limit
I am sure Sharif, Sam or George can explain this better.
Old Jul 16, 2009 | 10:50 PM
  #668
ttg35fort's Avatar
ttg35fort
Professional
I stopped by GTM today. Here is a picture of the bottom of my short block.
I have chromoly main bearing caps and a chromoly girdle, which are seen in the picture. I believe Mike has the same setup.
Old Jul 17, 2009 | 05:23 AM
  #669
str8dum1's Avatar
str8dum1
hmm, you coulda stayed with your 850 kit then if you 'only' needed 800 hp. LOL :0 only 800 hp cracks me up everytime i think of it.
I was just hoping to see a dual 35 kit maxxed out on a big motor. Still will be the hightest HP street car with full accessories on the forums though.
i shoulda had Sharif girdle my motor when it was apart. Maybe it's still apart. I should call.
Old Jul 17, 2009 | 08:25 AM
  #670
XKR's Avatar
XKR
Yes...thats what I have....I could not find the pic that I took
Yes...but at 800whp on my other setup.....that was at 99% of the turbo.....but with this setup 800whp is around 60%......I will leave it up to Sharif/Sam on what number to push it to over 1050whp...
He showed me your new motor...its clean and ready to put together.....you may still have time from what i saw.
Old Jul 17, 2009 | 11:53 AM
  #671
Sylvan Lake V35's Avatar
Sylvan Lake V35
Originally Posted by XKR
Yes...but at 800whp on my other setup.....that was at 99% of the turbo.....:
Just out of curiosity what PSI did you run your last set up at and what was the max boost you used? I noticed the waste gates are set to 17psi
PS. My car should be running tonight, I hope I just have to tie the fuel pumps into the line, install the HKS DLI II, Csoworth Intake and run vacum lines oh i also have to bleed the clutch, brakes and power steering. I better get off the net and go do some work the list is longer than I thought. Can't forget the exhaust i have to mate those huge down pipes to my tiny exhaust.
Old Jul 17, 2009 | 12:00 PM
  #672
XKR's Avatar
XKR
Sharif ran it at 23psi on his dyno and it was ran at 22 psi on Dyno Jet..... Maybe JW turned It down after inspection He did not want you to hurt yourself
Old Jul 17, 2009 | 05:21 PM
  #673
zman1982's Avatar
zman1982
I must say Mike that is one sweet *** G. Can't wait to see what it puts down on the rollers.
Old Jul 18, 2009 | 05:20 AM
  #674
XKR's Avatar
XKR
Thanks..... It won't be too Much longer. I will get Sharif to update you all.
Old Jul 18, 2009 | 05:41 AM
  #675
rcdash's Avatar
rcdash
Someone needs to post a GT35R compressor map. From what i recall you can reach max airflow (60 lbs/min each turbo ) at 22 psi. Going higher may not be required or that much more helpful (given how well I expect the heads/cams to perform).
Old Jul 19, 2009 | 05:04 PM
  #676
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Tried to find the compressor map for the GT35R that GTM uses, but with no luck. GT3582R .76A/R, is what's stated on their website, unless Mike has a different set...
Old Jul 19, 2009 | 05:53 PM
  #677
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
From the Garrett website:
Old Jul 19, 2009 | 06:20 PM
  #678
tig488's Avatar
tig488
thats not the right map, thats for the .70 AR housing.
Old Jul 19, 2009 | 06:25 PM
  #679
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Oh well. That's the only map I saw on the Garrett site for the 35R.
Old Jul 19, 2009 | 08:55 PM
  #680
Vq.turbo.DremZ
Yeah i believe all of the compressor maps are for .70 A/R on garrett's website...
