XKR Super G... Going for Mach 1
Old Aug 25, 2009 | 06:17 AM
  #821
XKR's Avatar
XKR
Chebesto......Great info...But here is my problem....the last time I did this event I did it in a car that was about to become a fulltime race car. It still had the seats ... But had a massive GT1 wing. They stuck me in a class with cars that cruise at speeds over 200 mph.
I have driven this car at very high speeds and have had others with as much or more racing experience as I do... And alll feel that the rear is lacking a diffuser and a wing. Terry and I are working on a diffuser... But if I want to stay in a certain class... I need to look as close to stock with the body as possible....
remember.... I don't need to stay over 190 for long...just enough to scrub off some time off the clock...
I will test the diffuser that Terry comes up with and see what we come up with....I have a car that has Massive downforce and it all comes from the bottom. I am just hoping to get the same from this setup.
We will let you know what the results are when we test... Good or bad
Edit*** As far as the wheels....they are designed for high speeds...you will see the same rims "SV10" on Labo's, Ferrari's, Porsche....thats why I use 20's to get that extra step. I will look up those books you listed.
  #822
rcdash's Avatar
rcdash
Hmmm... not sure my W/M injection is going to be enough for next ZdayZ airstrip event.
I'm sure I can get someone to unhook a coupler, again.
Looking good Mike, Sharif, and crew.
Old Aug 25, 2009 | 06:59 AM
  #823
XKR's Avatar
XKR
Thanks Raj.......I will be parked outside your house a few days before ZdayZ..
Old Aug 25, 2009 | 11:45 AM
  #824
Driven1's Avatar
Driven1
Professional
Just playing a little catch up on this thread.
Looking good XKR.
Aero at 200 is important but his cooling will be paramount imo. I was running 155+ for extended periods in my ST Z heading through the desert in Utah (literally 115 F) and was watching guages like a hawk and had to back off a few times to let it cool off a bit. Your EGT's will be crazy but the inlet air and coolant temps will be a good guages for you see. Will you be running any type of "virtual Dash" where you'll be able to see things like this?
Also, I run the SV-10's and they are EXTREMELY well made. Had them for years now and even doing long trips, high speed runs, and through cities (NYC for example) I haven't bent one or damaged one (knocks on wood)...and I should have running a 30 series tire on the rear. They are sturdy.
Old Aug 25, 2009 | 12:35 PM
  #825
thom000001's Avatar
thom000001
Mike mike mike mike mike,
IIIIIIIIIIIIIIIISSSSSSSSSSSSSSSSSSS IIIIIIIIIIIIIIITTTTTTT DDDDDDDDDDOOOOOOOOONNNNNNNNEEEEEEEE YYYYYYYYYEEEEEEETTTTTTT?????????
WE'RE WAITING!!!!!!
Old Aug 25, 2009 | 01:12 PM
  #826
XKR's Avatar
XKR
Looking good XKR.
You know it.....temps in Navada is brutal....Thats why I am happy Sharif did that oil cooler setup...plus the Koyo and the other cooling mod. I did not want the Oil cooler and Rad to share the same air flow.
I have the Camp2 and the Defi setup with the alarm so the co-pilot can keep his eyes on the road map warning me of upcoming bends
I agree...the SV10's is top notch....very well made. I am running the 25 profile tires in the rear....so I am sure if I hit any kind of pot hole....the rim is finished.
WE'RE WAITING!!!!!!
LMAO !!!! I am going to start calling Sharif everyday and ask him that. I did it on the other build...
Old Aug 25, 2009 | 02:53 PM
  #827
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by Chebosto
I like really like those front fenders. Is anything similar available for a G35?
Old Aug 25, 2009 | 03:04 PM
  #828
chinabean's Avatar
chinabean
dang i want to see how the rear diffuser looks like
Old Aug 25, 2009 | 03:22 PM
  #829
Chebosto's Avatar
Chebosto
i dont think so, but you can get the knock off one and hack it up and have a body shop blend it into the G35 front fenders.
Old Aug 25, 2009 | 03:42 PM
  #830
ttg35fort's Avatar
ttg35fort
Professional
Do you know who makes the knock off? Actuallly, I don't even know who is the original manufacturer. That would be helpful to know.
Old Aug 25, 2009 | 03:53 PM
  #831
ttg35fort's Avatar
ttg35fort
Professional
The computational fluid dynamic analysis of our 3D model should give us results fairly close to what we will see in the wind tunnel. After we have a 3D design that works well based on the CFD analysis, then we'll have the prototype made. If all goes will, which I think it will, we should only need to make minor adjustments once we are in the wind tunnel.
So, the results will be good.
Chebesto, did you look at the information that I sent you???
Old Aug 25, 2009 | 04:07 PM
  #832
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I am changing my number...
Old Aug 25, 2009 | 04:11 PM
  #833
Jay'Z's Avatar
Jay'Z
PM me new number! lol
Old Aug 25, 2009 | 04:14 PM
  #834
Chebosto's Avatar
Chebosto
yea i got the pdfs. thanks.
i was going to comment on it when i had time later this evening.
if you are going out of your way to re-do the exhaust piping, you can actually have the exhaust gas exiting your car help you create a lower pressure zone in the rear of the car so that the airflowing through your diffuser is being sucked out faster, but you'll have to encorporate the mufflers into your diffuser and be slightly above the venturi channels.
as far as the wheels go. i think you misunderstood me.
with the offset and width, your wheels peek out when viewed dead on from the front, you'll need to get a fairing to cover up the front of the wheels, such that the air can flow around the front of the tire/wheel.
Green arrow show the direction of the air flow from the wheel/tire.
blue is natural air flow from the front of the car,
Red is the areas in which you need to add to reduce the amount of air flowing forward that might screw with the natural airflow you're trying to use for your diffuser...
and no offense to the KurumaZ G bumper, but that will buckle under high frontal stress, you'll need to get an FRP, or CF bumper with reinforcements underneath so it doesn't bow in.. also make sure your front diffuser is bolted in to add more support for your front bumper to maintain its shape..
Old Aug 25, 2009 | 04:29 PM
  #835
Chebosto's Avatar
Chebosto
Original: Amuse Superleggera Z33 body kit
Knock off: i believe M1 motorsports in So Cal was the first to sell it.
Old Aug 25, 2009 | 04:57 PM
  #836
rcdash's Avatar
rcdash
Chebosto, is the 1/2 inch lateral aspect of each wheel really going to amount to a significant increase in drag given that the incremental cross-sectional area would be miniscule compared to the entire front of the car? I think attacking the low hanging fruit (i.e. where 20% effort affords 80% gain) seems practical. Going beyond that seems onerous but perhaps that's required for 200 mph?
Old Aug 25, 2009 | 05:31 PM
  #837
XKR's Avatar
XKR
No offense taken......I understand what you are trying to say....But we have done many 140, 160 and 190+ mph runs over a 3+ mile stretch...(I love Texas)..... And everything held together.
The car will spend more time in the 120 to 150 mph area and then up the speed on the straights.The car has had the once over by a race shop here in houston where the cage and some weight losing work will be done after it leaves Forged Performance.
There will be custom work done to clamp the front bumper into the area of the OC and IC. The bottom of the bumper will have a piece that will be welded to the bottom of the IC and then screwed to the bumper.
The reason I picked this shop is because they do alot of the Texas Mile cars and also Salt Flats monster cars....He agrees with what we found....the rear has to have a difuser. From there we take it to a wind tunnel and see what else we can find.
Like I said...no offence taken....input is always accepted in this thread
Old Aug 25, 2009 | 06:15 PM
  #838
ttg35fort's Avatar
ttg35fort
Professional
Very good idea!!!
I'll take a look at this to see if this will work for us.
Thank you Cheston!!!
Old Aug 25, 2009 | 09:54 PM
  #839
ttg35fort's Avatar
ttg35fort
Professional
Mike, Cheston and Crom,
I sent you guys a drawing that incorporates Cheston's comment with regard the exhaust. Let me know what you guys thing.
Old Aug 26, 2009 | 06:36 AM
  #840
XKR's Avatar
XKR
I returned the email...thx
