XKR Super G... Going for Mach 1
Old Oct 23, 2009 | 08:16 AM
  #1681
XKR's Avatar
XKR
Lol Tom....
Old Oct 23, 2009 | 11:39 AM
  #1682
Aced16's Avatar
Aced16
ok checking in again mike,how is it looking?
Old Oct 23, 2009 | 12:48 PM
  #1683
XKR's Avatar
XKR
I will have videos for you for SURE next Friday.....I will call Sharif in a few to get some updates...
Old Oct 23, 2009 | 09:54 PM
  #1684
Aced16's Avatar
Aced16
thats what i like to hear, now back to the JZ tread lol its epic over there!
Old Oct 24, 2009 | 11:22 PM
  #1685
str8dum1's Avatar
str8dum1
SO Blackbird is running 11.0 at 134 with his GTM Stage 5 (twin 3082s).
This will give a good idea how much faster XKR's G will be, granted traction etc. It will crush out of the hole, and still have a few hundred more HP past 4500 rpms with a final tune at the 20+ psi that Blackbird is running
Old Oct 24, 2009 | 11:35 PM
  #1686
ttg35fort's Avatar
ttg35fort
Professional
Rich, is Blackbird the guy who was having some issues with his electrical systems a week or two ago? If so, I think this data shows that there was something wrong with his build. I know Mike has a 4.0L motor vs. a 3.5L motor, but the difference in displacement does not account for the 150 ft-lb difference at 4250 rpm. I still think his cams are not advancing when they should.
Old Oct 25, 2009 | 01:35 AM
  #1687
SmallTuner's Avatar
SmallTuner
str8dum1
can u plz make one with the STG 4 vs STG 5
there is one made 682 19.5psi with 109 oct
Old Oct 25, 2009 | 06:56 AM
  #1688
350z-900whp's Avatar
350z-900whp
its mine ... gtm 3.5L stage 0 / 1 heads gtm / gtm 272 cams
on single pump and 800cc injectors by PE
Old Oct 25, 2009 | 06:59 AM
  #1689
ttg35fort's Avatar
ttg35fort
Professional
Did you ever get your electrical issues solved?
Old Oct 25, 2009 | 07:28 AM
  #1690
350z-900whp
well thats not me i never had an electrical issues EVER. that was another car on the forum , my car was built and tuned at GTM
Attached Thumbnails XKR Super G... Going for Mach 1-19psi-109-fuel.jpg   XKR Super G... Going for Mach 1-2.jpg
Old Oct 25, 2009 | 07:57 AM
  #1691
str8dum1's Avatar
str8dum1
Terry, ya thats the car. Very fast down the track regardless if the cams are lifting or not. Way stronger than a fully functioning Greddy kit nonetheless.
stage4 vs stage5
The stage 4 has been corrected down by 10% to correlate with dynodynamic #. All the DJ graphs I have use a (DJ hp)*0.90 correction. CLose enough
Essentially no difference between those 2 cars
All these charts I've been accumulating are nice bc it seems like once past the 3071 size, it doesnt matter how big the turbo is. They all have the same bottom end (under4k and except for XKR), so theres no reason not to go as big as you can fit.
I also think its funny when you look at like Hal's car. Make crappier low end than than these cars, but if you can get up to 148 mph in 400m, i doubt you will loose any race to a car with smaller turbos and less lag. Ya the area under the curve might be less, but that wont keep ya from seeing blinkers
Old Oct 25, 2009 | 08:13 AM
  #1692
ttg35fort's Avatar
ttg35fort
Professional
Very nice comparison. That actually provides evidence that the cams are working fine in Blackbird's build.
You can definitely see the 3082's breathing better than the 3076's in the higher rpms with no real spool up issues. Were both users using the same cams? If so, what cams are they?
As I noted, the extra displacement of Mike's motor will make a bit of a difference when compared to the other motors, but a 14.2% increase in displacement alone will not give a 42% increase in torque at 4250 rpm. So, there definitely is something else going on. Mike also has the Cosworth plenum, which will make a bit of difference, but again nowhere near enough. Perhaps it is the cams. Mike has the JWT C8 cams. What do the cars in the 2nd plot use?
Hopefully by next week Mike will have the final tune and post his final dyno chart. That will be very interesting.
Old Oct 25, 2009 | 08:58 AM
  #1693
INTENSEPOWER's Avatar
INTENSEPOWER
Vendor - Former Vendor
A little off topic, but related to this thread: SW (Boostlogic) just backed up his 240+ mph Texas Mile run from last year, with 243mph! This is with a 3.4L 2jz-gte.
http://www.youtube.com/watch?v=nJ71Tx2t10o
Go get 'em Mike!
Darren
Old Oct 25, 2009 | 11:13 AM
  #1694
XKR's Avatar
XKR
^^^^Out of my league......I would have to bring something else other than the G to do that. 200 is all I want... or could safely get
Old Oct 25, 2009 | 11:20 AM
  #1695
str8dum1's Avatar
str8dum1
considering that guy in FL went 191 with WAYYY less power (hopefully), i think you'll hit 200
Old Oct 25, 2009 | 11:27 AM
  #1696
XKR's Avatar
XKR
Old Oct 25, 2009 | 11:34 AM
  #1697
ttg35fort's Avatar
ttg35fort
Professional
You will be able to get well in excess of 200 mph. The G35 is very aerodynamic, and you will have alot of hp.
The underbody concept is pretty far along at this point, now we just need to get it modeled or wind tunnel tested. The modeling will take some time, but if there are any of you 3D modeling guys out there who want to give us a hand generating a 3D model of the G35, it would be greatly appreciated!!! We need to generate the model either as a STEP (.stp) or IGES (.igs) file.
FYI, the 3D models we downloaded from the Internet (following previously posted suggetions in another thread) have turned out to be pathetically inadequate.
Old Oct 25, 2009 | 11:36 AM
  #1698
XKR's Avatar
XKR
I have the aerodynamics, I have the hp....but I only have enough Ca-ho-ness for 201mph...
Old Oct 25, 2009 | 11:38 AM
  #1699
03threefiftyz's Avatar
03threefiftyz
Looks like the TT gallarado's are closing the gap quickly with the supras though.......SW's car is gross.
Lots of Pics:
http://www.supraforums.com/forum/sho...d.php?t=563777
Old Oct 25, 2009 | 01:10 PM
  #1700
Blackbird CPV35's Avatar
Blackbird CPV35
I am using the very first version of the gtm stage 1 turbo cam. It's really mild for my application and I need to upgrade soon.
I also have noticed that hal was dynoing my car in 4th gear ( almost 80% certain) so that may have affected the dyno numbers
all I know now is that I trust a trap speed alot more than a dyno number
