misfire cylinder 6 mystery
Old Mar 19, 2009 | 08:03 AM
  #41
athenG's Avatar
athenG
Originally Posted by gotparts?
have you guys checked in the open loop fueling portion of your paramaters on the utec? there is an area where you can input the size of injector running and the stock injectors size for scaling of the injectors.
The only way to scale your injector in Utec is by tune your 0 Column. Plugging in the size of injector in the Utec Parameters just doesn't work.
Old Mar 19, 2009 | 08:04 AM
  #42
athenG's Avatar
athenG
Originally Posted by accordfreak
just wondering, the car is still running ok?
LOL... I just got back from the track last night and my car is still intact
Old Apr 6, 2009 | 05:14 PM
  #43
jining's Avatar
jining
WELL my friends, the MAF did not solve the misfire :P I looked at the gm/s on the new maf, and its in spec now, on the low side tho, about 2 gm/s at idle and 8 gm/s at 2500rpm....so im thinking it must be something else :P
A/F alpha on both banks are even (kinda lean 108%)and injector pulse widths on both banks are even so im thinknig its not an injector issue..... tested compression and that checked out... ahhhhhhhhhhh...
AthenG you have any updates?
Old Apr 6, 2009 | 06:33 PM
  #44
athenG's Avatar
athenG
After changing the spark plugs and some minor adjustment on my tune the misfire has gone down dramatically.. I mean it's been over 2 weeks now and no misfire yet, before I couldn't get past 2 days without getting a misfire... I think it was the spark plugs combine that with temp below freezing that cause me to misfire.
My car is still having bog down problem when the ECU try to correct my idle below 700rpm. Above 800rpm my car run smooth so I need to find a way to raise my idle. I have a revup G35 (2005) and Nissan said they couldn't do it but haven't check with infiniti.
Old Apr 7, 2009 | 06:36 AM
  #45
jining's Avatar
jining
thats good to hear your misfire is better, strange that your car bogs, should idle at 650rpm or so.
I swapped my injector #6 to injector #2 to see if the misfire moves :P
Old Apr 7, 2009 | 06:21 PM
  #46
jining's Avatar
jining
Well!!! It seems the mystery has finally been solved, I swapped the injector from the misfiring cylinder (6) with the injector on cyilnder 2, and the misfire has moved to 2. Time to contact deatschwerks.
Old Apr 16, 2009 | 04:10 PM
  #47
terps's Avatar
terps
^glad you got it fixed
I finally solved mine(cylinder 5) or think i did, i swapped coil packs and replaced spark plugs, still persisted. got a new tune and 750+miles and i have no codes. I had stupid rich afr and utec setting were jacked. apparently the utec setting were affecting it.
gl to all the others suffering from this problem
Old Apr 17, 2009 | 04:12 PM
  #48
j.arnaldo's Avatar
j.arnaldo
...you got me all scared now, man...Hope THAT doesn't happen to MY beaZt!!!
____________________________________________________________ ______________
Bone stock 'O4 Touring Coupe: 2O+k, NO feathering, NO oil-consumption issues, Flawless
AT...(Hope it all remains like that forever, 'cause that's how long I plan to keep it!)
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
allmycarsdie
May 13, 2016 04:38 PM
kyin
Sep 29, 2015 06:57 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
