how to take off pulley on vortech?
Old Feb 23, 2009 | 02:27 PM
balla33's Avatar
balla33
Default how to take off pulley on vortech?
just wondering how to take off the 3.33 pulley and install the 2.87
Old Feb 23, 2009 | 04:02 PM
05Z33's Avatar
05Z33
You're going to have to remove the blower from the bracket.
Old Feb 23, 2009 | 04:06 PM
balla33's Avatar
balla33
why remove the blower?
Old Feb 23, 2009 | 04:10 PM
Car vs. Driver's Avatar
Car vs. Driver
You won't be able to get the pulley off because the blower is in the way.
Edit:
I take that statement back ... if you take off the cog pulley assembly you can get it off, you'll need a strap wrench to hold the cog still while you unbolt the pulley. Then unscrew the four hex bolts holding on the cog and it should all come apart.
Old Feb 23, 2009 | 04:25 PM
350Z400rwhp's Avatar
350Z400rwhp
Edit:
Didn't know that! Will I have the same problem taking out my 3.12 and putting in my 2.87?
Old Feb 23, 2009 | 04:31 PM
Car vs. Driver
Not sure about the 3.12 ... but the 3.33 will certainly not just come right off. Either the blower has to move or the cog assembly on the back has to come off.
I installed my kit with the 3.33, then immediatley went to the 2.87 before I finshed up the installation and I do recall being able to do it without removing the blower.
Old Feb 23, 2009 | 05:28 PM
balla33's Avatar
balla33
i got the bolt off of the cog pulley but the cog pulley is still pretty tight should i just pry it out or what
Old Feb 23, 2009 | 05:35 PM
Car vs. Driver
You didn't read what I said ...
You need to remove the main shaft bolt that goes through both pulleys.
Then ...
Remove the four hex bolts holding the cog pulley assembly on and it should all come off.
Old Feb 23, 2009 | 05:45 PM
drumminguy81's Avatar
drumminguy81
oh i get what your pm was about i was able to remove the 3.12 and the 2.87 without taking the blower off or removing the cog pulley.. the 3.33 is too large though luckly i bought mine with the 3.12 already installed..
Old Feb 23, 2009 | 05:46 PM
350Z400rwhp
Whew, good to hear! Thanks!
Old Feb 23, 2009 | 06:43 PM
booger's Avatar
booger
You should remove the 4 bolts holding the blower to the bracket . But i was always able just to losen the top 3 bolts and pry over the blower to get it off . The smaller pulley goes on with out prying on it .
Old Feb 23, 2009 | 06:46 PM
Barzten1's Avatar
Barzten1
When Boog speaks on Vortech drop all things and listen. Miss you my brutha, hopeing you havent sold the G
Old Feb 23, 2009 | 06:51 PM
booger's Avatar
booger
No..i still have it . 18,000 miles...now N/A , Haltech running the car and waiting for things to get straightened out before going turbo . Unless some one offers me a good price on a low mile 03 G35 fully built ready for F/I car . lol
Old Feb 23, 2009 | 07:01 PM
Barzten1's Avatar
Barzten1
Your thinking bout turbos? Zweeeet! Honestly bro, eveyrone write this down. I had more fun when my Z had the Vortech as apposed to the Greddy TT kit. Although when Im out looking for action, Im looking for bikes not cars anymore. I use to beat my car up everywhere I went with the Vortech kit. More usable power. Now the Z is too loud, too fast and too obnoxious to drive safely from light to light. Your going to love the power Boog, but your going to miss your blower.
Old Feb 23, 2009 | 08:18 PM
nothix's Avatar
nothix
just changed pulley last weekend
went from 3.33 to 3.12
Found it Easiest to pull plate off and unbolt the vortech from the plate (loosened)
Just seemed too much of a pita to try and loosen it with the plate mounted
Whole job took about 30min
Old Feb 23, 2009 | 10:01 PM
balla33's Avatar
balla33
i got it off took whole alot of prying but off with the 3.33 and in with the 2.87
Old Feb 24, 2009 | 01:25 PM
booger's Avatar
booger
When I took off the blower , I was at around 490whp and 19psi . It was way to loud and I didnt like driving it much...lol
With a AT5 , I think when I go turbo , Im going to keep it toned down a bit and just have a drivable car
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
