Utec problems and SEL, VDC, SLIP
Old Mar 2, 2009 | 04:36 PM
ashtrojan2008's Avatar
ashtrojan2008
Default Utec problems and SEL, VDC, SLIP
Hey guys. Okay, most of my build was posted on (another site), but its obviously gone so i'll do a short recap.
Had greddy tt kit bc malfunction caused overboost and i broke my piston ring lands. blah blah blah. Anyway, its a 2006 rev up. I pulled the engine, had it bored/honed/balanced/etc. I built the engine
CP 8.5:1 cr pistions .5mm over, carrillo rods, arp L19's, hks head gaskets, open dumps, etc etc etc.
I started the engine with the stock fuel system and 440cc injectors. map i had on the utec was perfect. First start up was flawless. Only thing is my SEL, VDC, and SLIP lights are on. OBDII says crank position sensor. Makes sense. I've cleaned it off, checked all grounds, everything is good. They won't go away. Only other thing i can think of is the JWT flywheel. I dont feel like pulling the flywheel back off so any suggestions would be appriciated. My next step is changing the sensor out.
Next issue. I got my fuel system in, AAM stage 1 and rc 750cc injectors, and walbro 255. well they sent be a gss341 instead of a 342 so i'm still running the stock fp till my new one comes in. I set the fuel pressure at 42 psi w/o vacuum, which puts me at about 35psi idle. pressure is going up with boost as it should. The car is running rich as hell! Idle is about 13.8 and as soon as boost hits and utec switches to map wideband pegs out at 10. Also, the rev up (not sure if regular DE's do this too) cuts the injectors on decel showing up lean on the wideband. Has always done this. Now with the 750's it goes rich, about 11.2-11.5 on decel. I tried 2 different maps and parameters on the utec for 750cc injectors including the one on the txs website. They both run crazy rich. I lowered the pressure that the utec switches to map to 0 which helped a bit but not much. I don't want to mess with the maps too much yet till i figure out exactly why it is so rich. By the way i'm just running boost off the wastegates right now, about 5.5psi, for break in. i've got 800 miles on the block. Not gonna boost more till 1000 miles when i change the oil again.
so, if anyone has any suggestions on the lights or has a better map or suggestions with the fuel system, any help would be appriciated. Sorry for writing a novel.
most of my build is on youtube if you want to see. http://www.youtube.com/watch?v=-e9kcBvsPYc
-ross
edit: forgot to add that my tachometer is jumpy. I can move the sensor around and it stabilizes but the lights are still on.
Old Mar 2, 2009 | 04:43 PM
UMW350Z's Avatar
UMW350Z
should be moved to FI...
1) get rid of the UTEC unless you are out of money
2) get tuned
Old Mar 2, 2009 | 04:47 PM
ashtrojan2008
i am out of money lol. I wanted to go either haltec or fcon but wasn't in my budget. I'm getting tuned this weekend but i wanted it to be running a bit better before i make the 200 mile drive to houston.
sorry about the location i'm new to the site. Mods move it if you don't mind
Old Mar 2, 2009 | 05:19 PM
ashtrojan2008
i re posted it in FI
Old Mar 2, 2009 | 05:25 PM
tanabe350z's Avatar
tanabe350z
i know a great tuner that is much closer to home if your located in dallas used to work for him he does great work
Old Mar 2, 2009 | 05:35 PM
track1z's Avatar
track1z
NOTHING is wrong with your UTEC because of brand name.If you just cleaned off the crank position sensor and thats it with the same problom,you might want to get a new crank sensor.Then. if its happened right after the install of the flywheel make sure the flywheel marks ar aligned with the crank shaft.
All you need is a tuner that knows how to tune after that
Old Mar 2, 2009 | 05:43 PM
ashtrojan2008
flywheel is correct, i know for a fact. nothing's wrong with the utec, just thinking the map may suck for my setup or for the revup, because i'm sure the map was made for the original de's and i'm not sure if the tune on the rev up should be any different with the exhaust timing/ fuel cut on decel, etc
Old Mar 2, 2009 | 06:06 PM
track1z's Avatar
track1z
thats your prob
Old Mar 2, 2009 | 06:10 PM
ashtrojan2008
but the 440cc map was working fine
Old Mar 2, 2009 | 06:24 PM
track1z's Avatar
track1z
I think you nailed it with the
I have the same build as you damn near.hmmmm you had any adjustments in your susp lately??
Old Mar 2, 2009 | 07:16 PM
nothix's Avatar
nothix
+1
Old Mar 2, 2009 | 07:58 PM
ashtrojan2008
mark @ sgp should be tuning my setup soon. i'll post all my mods later. too much to type right now.
Old Mar 11, 2009 | 06:38 AM
sik350's Avatar
sik350
I definitely want to get up with you and check out your ride. I pmd you. I dont live 2 far from you just moved here(Fort Polk)la. There is a bunch of 350z on base here as well. I meet a couple of guys from la sreet kingz from pineville. goodluck with your build!
Old Mar 11, 2009 | 08:02 AM
GenPac's Avatar
GenPac
This --- SGP? https://my350z.com/forum/forced-indu...gp-racing.html
Old Mar 11, 2009 | 04:58 PM
nizzy350's Avatar
nizzy350
Default jwt flywheel utec same issue
I had the same issue with a jwt flywheel and a new utec.
I know you said you cleaned it off, but the sensor is a magnet and if any metal pieces are on it, it will screw with the utec. It is much more sensitive then the stock ecu.
I had to use oil and a screw driver to clean the sensor. It took intalling and cleaning it about 4 times before the error went away.
Plus I had to reset the error codes on the ecu to get the lights to go away.
The sequence is here in the forum somewhere. Something like gas gas gas, wait 30 seconds gas gas wait 10 seconds. blah blah blah.
good luck
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
