My Greddy TT build is complete!!!
Old Oct 9, 2010 | 08:17 AM
midz350's Avatar
midz350
Great work and nice looking car.
Old Oct 9, 2010 | 02:41 PM
superchargedg's Avatar
superchargedg
Damn Noobs
[QUOTE=xzotklr;8710199]
Originally Posted by projektZ
Posted this in the Orlando Z section, thought I should post here since this is where I gathered alot of info that helped me along the way! ")
Well after countless hours and two months of not having my Z the Greddy TT set-up is finally complete! (minus the tuning) My boyfriend and I did the install ourselves and his dad helped along the way. It was def. not easy and all the threads that say you can do the install with the engine in the car are a lie!!! lol. I have no clue how they did it b/c there are just some bolts on the exhaust manifold you cannot get to! So after 2 or 3 weeks of trying to do the install in the car the engine had to come out.
Mod List:
Greddy TT with intercooler - local forum member
UTEC w/ map sensor - forum member
DW 600cc - thanks to Forged Performance
1 step colder plugs - again Forged Performance
GreddyEvoTT exhaust - local forum member
Turbo XS testpipes - WeSellCarparts.com - best deal!
ACT 6 puck sprung clutch and streetlite flywheel - forum member
Setrab Oil Cooler - local forum member
Cusco oil catch can - not going to install is FS, I want a Greddy one
Walbro FP - injected Performance
AEM UEGO - National Speed
AEM tru-boost controller - National speed
Autometer dual gauge pod - National speed - awesome customer service!
exhaust gaskets, cat/testpipe gaskets - Celebrity Nissan (best price)
Painted the plenum blue
Fabrications/extra modifications:
Powersteering cooler relocation
Washer tank relocation
stock oil cooler elimination
front bumper
radiator overflow tank relocation
fuel lines wrapped in heat wrap and moved from the 1/2 inch off the turbo to about 5 inches away (will be modding further down the rd to add to safety)
Starter wrapped in fiberglass
cool tape added to areas near turbos
testpipes wrapped in fiberglass wrap
wideband bung welded on
exhaust manifold cracked on one side, welded but will prob need to be fixed again at a later date
Started her up last night idles really rough and dies with a touch of the throttle but atleast it started up! Needs tuning really bad have an appt for next weekend with Japtrix
Be careful......They f'd up my buddy's Z. If you decide to got with them make sure you triple check everything they do!!!!!!! It's your engine so....
Sorry but the install's with the engine in the car are not lie's they are just difficult.
Old Oct 9, 2010 | 04:30 PM
Aced16's Avatar
Aced16
Yea I got the Spec SS for the street driveability.....
Which if I am not mistaken, I am still entitled to a ride
Old Oct 10, 2010 | 12:26 AM
accordfreak's Avatar
accordfreak
wow... welding without gloves. crazy. did they weld without a helmet too?
Old Oct 10, 2010 | 05:14 AM
projektZ's Avatar
projektZ
haha true. Thanks so much for the awesome clutch set-up :P Once the motor gets back into the car and tuned you can get a ride It'll prob be a little while for that still though
Old Oct 24, 2010 | 05:55 AM
projektZ's Avatar
projektZ
Time for an Update
Over the past couple monts, the Z has been taken off the road again to undergoe more changes =D.
We removed the motor and tore it down to the bare block and shipped it off to Forged Performance for Sharif to work his magic. We are getting the block S1 Package (Balancing and polishing the crankshaft, check the main bore, decking the Block, pressure cleaning, bore and hone with trq plate, and block re-assembly). Parts include: Arias Zero Silicon AL EXTREME Duty Piston set 9.0:1
.020 overbore, Eagle Rods, ACL Thrust Washers, ACL Main and Rod Bearings, and ARP bolts.
We received the block back and are in the process of re-assembling the remaining parts (valvetrain, upper/lower oil pan, etc.). We decided to strip the paint on the valve cover and powder coat it mag blue along with the front timing cover. It turned out beautiful... see pics below.
There is a back order on some gaskets & O-rings we ordered but we are well underway on getting the motor back in the car. The goal is to drive it up to Forged to be re-tuned for 550 whp.
Updated Mod List (everything in bold is new)
Engine:
  • Greddy TT with intercooler - local forum member
  • DW 600cc - thanks to Forged Performance
  • 2 step colder plugs - again Forged Performance
  • GreddyEvoTT exhaust - local forum member
  • Turbo XS testpipes - WeSellCarparts.com - best deal!
  • Setrab Oil Cooler - local forum member
  • Greddy oil catch can - Forged Performance
  • Walbro FP - injected Performance
  • exhaust gaskets, cat/testpipe gaskets - Celebrity Nissan (best price)
  • Arias Zero Silicon AL EXTREME Duty Piston set 9.0:1 .020 overbore - Forged Performance
  • Eagle Rods - local forum member
  • ACL Thrust Washers - Forged Performance
  • ACL Main Bearings - Ebay
  • Rod Bearings - Ebay
  • ARP Main Studs
  • HKS Head Gasket - local forum member
  • Rev-Up Oil Pump - local forum member
  • Nismo Thermostat - local forum member
  • Genuine Gaskets & O-Rings - Universal Nissan
  • JWT Oil Pan Spacer - local forum member
  • Turbo Rebuild Kit - http://www.gpopshop.com/mitsubishikits.html
  • ARP L-19 Head Studs
  • Koyo R core Radiator
  • Greddy air diversion panel
  • Brian Crower STG II Cams
  • Nissan VQ35 Rear Coolant Bypass System #16317
  • Fuel Return System
Drivetrain:
  • CD09 Transmission
  • SPEC SS Twin Disc clutch & Flywheel - local forum member
Electronics:
  • UTEC w/ map sensor - forum member
  • Turbo XS Remote Map Switch #16234
  • Greddy Profec E-01 Boost Controller
  • AEM UEGO Wideband Air/Fuel - National Speed
Suspension:
  • Tein Monoflex coils with EDFC - local forum member
  • Greddy Strut bar (end plates powder coated mag blue) - local forum member
Brakes:
  • Brembo 4 Piston Front, 2 Piston Rear Calipers - local forum member
  • StopTech Slotted Rotors - local forum member
  • Stoptech Braded Stainless Brake Lines - local forum member
  • Stoptech pads - local forum member
Interior:
  • Autometer dual gauge pod - National speed - awesome customer service!
  • Greddy Counterweight Shift ****
Exterior:
  • Shine Amuse Bodykit - local forum member
  • Nismo Rear Wing
Rims & Tires:
  • NISMO LMGT4 wheels
  • BF Goodrich KDW F: 225/45/18, R: 245/45/18
Cosmetic:
  • Powder coated the plenum mag blue
  • Powder coated the front timing cover mag blue
  • Mishimoto Radiator Hoses (Blue)
  • Powersteering cooler relocation
  • Washer tank relocation
  • front bumper
  • radiator overflow tank relocation
  • fuel lines wrapped in heat wrap and moved from the 1/2 inch off the turbo to about 5 inches away (will be modding further down the rd to add to safety)
  • Starter wrapped in fiberglass
  • cool tape added to areas near turbos
  • testpipes wrapped in fiberglass wrap
  • wideband bung welded on
  • exhaust manifold cracked on one side, welded but will prob need to be fixed again at a later date
This is before we started
Pulling motor out
What happens when you don't wear gloves.
Pulling heads off
Block now ready to ship to Forged Performance
Received Block back (underside)
Eagle Rods
Eagle Rods with Arias ED Pistons
Pretty pistons
Side shot
Front shot
Where we are at the moment... ARP L19 Head Bolts
Powder Coated Plenum Cover (Mag Blue)
Powder Coated Front Timing Chain Cover (Mag Blue)
Old Oct 24, 2010 | 07:35 PM
abushong504's Avatar
abushong504
Looking nice! i know how hard all of that is lol. While you're at it, you should add an ATI damper to your build. Cheap and will help increase the longevity!
Old Oct 24, 2010 | 08:34 PM
350Z400rwhp's Avatar
350Z400rwhp
I really like that powder coating!
Old Oct 25, 2010 | 05:50 AM
suprasam's Avatar
suprasam
I remember when Sandy sent me pics of my S1 block during my build! Very exciting. Good looking build and I will be jealous is Sharif tunes yours to 550hp!!!
Old Oct 25, 2010 | 06:06 AM
Cass007's Avatar
Cass007
How has this thread made it 30 posts without someone demanding pics of the OP We are slippin guys
OP, pics of you with your hands dirty working on the car are a must!!
Not for me, but for my F/I brothers...
Old Oct 25, 2010 | 06:15 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Depending on the fuel system, that should have no issue breaking 600whp on his heartbreaker with that turbo kit and those cams.
Old Oct 25, 2010 | 06:24 AM
JLS2GOZ's Avatar
JLS2GOZ
Saw the "test fit pic" how much HP do those vice grips add........
Nice build ! Good luck.
Old Oct 31, 2010 | 06:35 AM
mario23's Avatar
mario23
Great job...you aren't playin around!!!
Old Oct 31, 2010 | 08:14 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Great updated pics. Looks like everything is coming along nicely.
350z82
Oct 1, 2015 06:25 PM
