VDC, Slip, p0201 All on?!?!
Old Mar 12, 2009 | 08:25 AM
down_shift's Avatar
down_shift
Default VDC, Slip, p0201 All on?!?!
I reset my ecu last night and upon start up.. I get all these lights on!!
VDC
Slip
P0201
None of them have shut off. I've driven the car about 10 miles. The RPM's were all over the place at idle but have since got alot smoother.
P0201 looks like it's either a Injector problem or MAF? It's just weird my car didn't have these lights on for ~250 miles and now I reset the ECU and they come on right away
Anyone else run into this problem? I tried to search the code but seems like no one has had this problem to make a thread..
this is a Greddy TT, CJ RFS, Haltech + Turbonetics Reflash
---- Update: fixed problem by putting MAF back into the charge pipe.
Old Mar 12, 2009 | 08:33 AM
terps's Avatar
terps
https://my350z.com/forum/forced-indu...-vdc-slip.html
Old Mar 12, 2009 | 08:36 AM
Cass007's Avatar
Cass007
I have what I thought was the entire list of codes, but that code is not on my list. What year is your car? My list is for 03-05.
- Codes
P0000 No Self Diagnostic Failure Indicated
P0011 Intake Valve Timing Control
P0021 Intake Valve Timing Control
P0031 O2 Sensor Heather
P0032 O2 Sensor Heather
P0037 O2 Sensor Heather
P0038 O2 Sensor Heather
P0043 O2 Sensor Heather
P0044 O2 Sensor Heather
P0051 O2 Sensor Heather
P0052 O2 Sensor Heather
P0057 O2 Sensor Heather
P0058 O2 Sensor Heather
P0100 MAF (Mass Air Flow) Sensor
P0101 MAF Sensor
P0102 MAF Sensor
P0103 MAF Sensor
P0105 Absolute Pressure Sensor
P0107 Absolute Pressure Sensor
P0108 Absolute Pressure Sensor
P0110 IAT (Intake Air Temperature) Sensor
P0112 IAT Sensor
P0113 IAT Sensor
P0115 ECT (Engine Coolant Temperature) Sensor
P0117 ECT Sensor
P0118 ECT Sensor
P0120 TP (Throttle Position) Sensor
P0121 TP Sensor
P0122 TP Sensor
P0123 TP Sensor
P0125 ECT Sensor
P0127 Intake Air Temperature Sensor
P0128 Thermostat Function
P0130 Closed Loop, Bank 1 Or Front O2S, Bank 1
P0131 Front O2 Sensor, Bank 1 Lean Shift Monitoring
P0132 Front O2 Sensor, Bank 1 Rich Shift Monitoring
P0133 Front O2 Sensor, Bank 1 Response Monitoring
P0134 Front O2 Sensor, Bank 1 High Voltage
P0135 Front HO2S Heater, Bank 1
P0136 Rear O2S, Bank 1
P0137 Rear O2S, Bank 1 Minimum Voltage Monitoring
P0138 Rear O2S, Bank 1 Maximum Voltage Monitoring
P0139 Rear O2S, Bank 1 Response Monitoring
P0140 Rear O2S, Bank 1 High Voltage
P0141 Rear H02S Heater, Bank 1
P0144 O2 Sensor Heather
P0150 Closed Loop, Bank 2 Or Front O2S, Bank 2
P0151 Front O2 Sensor, Bank 2 Lean Shift Monitoring
P0152 Front O2 Sensor, Bank 2 Rich Shift Monitoring
P0153 Front O2 Sensor, Bank 2 Response Monitoring
P0154 Front O2 Sensor, Bank 2 High Voltage
P0155 Front HO2S Heater, Bank 2
P0156 Rear H02S Sensor, LH Bank
P0157 Rear O2S, Bank 2
P0158 Rear O2S, Bank 2
P0159 Rear O2S, Bank 2
P0160 Rear O2S, Bank 2
P0161 Rear H02S Heater, LH Bank Or Bank 2
P0171 Fuel System Lean, Bank 1
P0172 Fuel System Rich, Bank 1
P0174 Fuel System Lean, Bank 2
P0175 Fuel System Rich, Bank 2
P0180 Tank Fuel Temp Sensor
P0182 Fuel Tank Temperature Sensor
P0183 Fuel Tank Temperature Sensor
P0217 Engine Coolant High Temperature Enrichment Protection
P0221 Throttle Position Sensor
P0222 Throttle Position Sensor
P0223 Throttle Position Sensor
P0226 Accelerator Pedal Position Sensor
P0227 Accelerator Pedal Position Sensor
P0228 Accelerator Pedal Position Sensor
P0245 Supercharger Bypass Valve Control Solenoid Valve
P0300 Random Misfire
P0301–*P0308 Misfire, Cylinder No. 1–8
P0325 Knock Sensor, Bank 1
P0327 Knock Sensor
P0328 Knock Sensor
P0330 Knock Sensor, Bank 2
P0335 CKP (Crank Shaft Position) Sensor
P0340 CMP (Cam Shaft Position) Sensor (Phase)
P0345 CMP Sensor (Phase)
P0350 Ignition Signal
P0400 EGR System
P0402 EGRC/BPT Valve
P0403 EGR Volume Control Valve Circuit
P0405 EGR Temperature Sensor
P0406 EGR Temperature Sensor
P0420 TW (Two-Way) Catalyst System, Bank 1
P0430 TW Catalyst System, Bank 2
P0440 EVAP Small Leak
P0441 EVAP Control System Purge Flow Monitor
P0442 EVAP Control System
P0443 Purge Control/V & S/V
P0444 EVAP Canister Purge Volume Control Solenoid Valve
P0445 EVAP Canister Purge Volume Control Solenoid Valve
P0447 EVAP Canister Vent Control Valve
P0450 EVAP Pressure Sensor
P0451 EVAP System Pressure Sensor
P0452 EVAP System Pressure Sensor
P0453 EVAP System Pressure Sensor
P0455 EVAP Control System
P0456 EVAP Control System
P0460 Fuel Level Sensor Unit (Slow)
P0461 Fuel Level Sensor Function
P0462 Fuel Level Sensor
P0463 Fuel Level Sensor
P0464 Fuel Level Sensor Circuit
P0500 Vehicle Speed Sensor
P0505 IACV/AAC Valve
P0506 Idle Speed Control System
P0507 Idle Speed Control System
P0510 Closed TP Sensor
P0550 Power Steering Pressure Sensor
P0600 A/T Comm Line
P0605 ECM/ECU
P0650 Malfunction Indicator Lamp
P0705 PNP Or Inhibitor Switch
P0710 ATF Temp Sensor
P0720 VSS A/T
P0725 Engine Speed Signal
P0731 A/T 1ST Signal
P0732 A/T 2ND Signal
P0733 A/T 3RD Signal
P0734 A/T 4TH Signal Or TCC
P0740 TCC SV Solenoid
P0744 A/T TCC Signal
P0745 Line Pressure S/V
P0750 Shift Solenoid/V A
P0755 Shift Solenoid/V B
P1031 Air/Fuel Ratio Sensor Meter
P1032 Air/Fuel Ratio Sensor Meter
P1065 ECM Power Supply Heater
P1102 Mass Air Flow Sensor Function Heater
P1103 MAP Sensor Heater
P1104 MAP Sensor Heater
P1105 MAP/BARO Switch SOL/V
P1108 MAP Sensor Heater
P1110 Intake Valve Timing Control, LH Bank
P1111 Intake Valve Timing Control Solenoid Valve
P1119 Radiator Temperature Sensor Circuit
P1120 TP Sensor 2
P1121 Electronic Throttle Control Actuator
P1122 Electronic Throttle Control Actuator
P1124 Throttle Control Motor Relay
P1125 Tandem TP Sensor
P1126 Throttle Control Motor Relay
P1128 Throttle Control Motor
P1130 Swirl Control Valve Control Solenoid Valve
P1131 Swirl Control Solenoid Valve
P1132 Swirl Control Valve
P1135 Intake Valve Timing Control, RH Bank 2
P1136 Intake Valve Timing Control Solenoid Valve
P1137 Swirl Control Valve Position Sensor
P1138 Swirl Control Valve
P1140 Intake Valve Timing Control Position Sensor, LH Bank 1
P1143 Heated O2 Sensor 1
P1144 Heated O2 Sensor 1
P1145 Intake Valve Timing Control Position Sensor, RH Bank 2
P1146 Heated O2 Sensor 2
P1147 Heated O2 Sensor 2
P1148 Closed Loop, Bank 1
P1163 Heated O2 Sensor 1
P1164 Heated O2 Sensor 1
P1165 Swirl Control Valve Control Vacuum Check Switch
P1166 Heated O2 Sensor 2
P1167 Heated O2 Sensor 2
P1168 Closed Loop, Bank 2
P1169 Heated O2 Sensor 3
P1170 Heated O2 Sensor 3
P1210 Traction Control Signal Circuit
P1211 ABS/TCS Control Unit
P1212 ABS/TCS Communication Line
P1217 Engine Coolant Temperature
P1220 FPCM
P1221 Throttle Actuator Circuit
P1222 Temperature Sensor Circuit
P1223 Throttle Position Sensor 2
P1224 Throttle Position Sensor 2
P1225 Closed Throttle Position Learning
P1226 Closed Throttle Position Learning
P1227 Accelerator Pedal Position Sensor 2
P1228 Accelerator Pedal Position Sensor 2
P1229 Sensor Power Supply
P1271 Air/Fuel Ratio Sensor 1
P1272 Air/Fuel Ratio Sensor 1
P1273 Air/Fuel Ratio Sensor 1
P1274 Air/Fuel Ratio Sensor 1
P1276 Air/Fuel Ratio Sensor 1
P1278 Air/Fuel Ratio Sensor 1
P1279 Air/Fuel Ratio Sensor 1
P1320 Ignition Signal, Primary
P1335 CKP Sensor (Ref)
P1336 CKP Sensor (POS) Cog
P1400 EGRC Solenoid/V
P1401 EGR Temp Sensor
P1402 EGR System
P1440 EVAP Small Leak
P1441 VC/V Bypass/V
P1443 Canister Control Vacuum Check Switch
P1444 Purge Volume Control/V
P1445 Purge Volume Control/V
P1446 Vent Control Valve
P1447 EVAP Purge Flow
P1448 Vent Control Valve
P1456 EVAP Control System
P1464 Fuel Level Sensor Circuit Ground Signal
P1480 Fan Control Solenoid Valve Circuit
P1490 VC/V Bypass/V
P1491 VC Cut/V Bypass/V
P1492 Purge Control/V S/V
P1493 Purge Control/V & S/V
P1564 ASCD Steering Switch
P1568 ICC (Intelligent Cruise Control)
P1572 ASCD (Automatic Sped Control Device) Brake Switch
P1574 ASCD Vehicle Speed Sensor
P1605 A/T Diag Comm Line
P1610 NATS Malfunction
P1611 NATS Malfunction
P1612 NATS Malfunction
P1613 NATS Malfunction
P1614 NATS Malfunction
P1615 NATS Malfunction
P1705 TP Sensor A/T
P1706 PNP Switch
P1720 Vehicle Speed Sensor- A/T Output
P1760 Overrun Clutch S/V
P1775 Torque Converter Clutch Solenoid Valve
P1776 Torque Converter Clutch Solenoid Valve
P1780 Shift Change Signal
P1800 VIAS Control Solenoid Valve
P1805 Brake switch
P1900 Cooling Fan
P2122 Accelerator Pedal Position Sensor
P2123 Accelerator Pedal Position Sensor
P2127 Accelerator Pedal Position Sensor 2
P2128 Accelerator Pedal Position Sensor 2
P2135 Throttle Position Sensor
P2138 Accelerator Pedal Position Sensor
Old Mar 12, 2009 | 08:38 AM
down_shift's Avatar
down_shift
^^ Already checked the brake fluid. Nice quick edit haha.
Checked out that thread too. Doesn't have anything helpful. Utec, different CEL's.
Old Mar 12, 2009 | 08:39 AM
down_shift's Avatar
down_shift
It's a 04 G35 6MT Coupe.
I searched the board for the code and someone posted it's a Injector Circuit Malfunction? But there was also a post about it being MAF related.
I disconnect my MAF and reconnected.. still there.
Old Mar 12, 2009 | 09:05 AM
terps's Avatar
terps
vehicle specific nissian code for
P0201 Injector Circuit Malfunction - Cylinder 1
http://www.pathyoffroad.com/files/obdii_codes.pdf
meh besides that i cant help
Old Mar 12, 2009 | 09:15 AM
down_shift's Avatar
down_shift
"Mass Volume Low Input" Does that mean my MAF is not getting enough air or the voltage is low?
Old Mar 12, 2009 | 10:25 AM
frankie945's Avatar
frankie945
Check your chassis codes the abs side.And see if you get a C1130 code. That code is Engine 1 fuel cut. I'm Curious if you get that code too.
Old Mar 12, 2009 | 10:31 AM
down_shift's Avatar
down_shift
Any DIY for this?
Old Mar 12, 2009 | 10:34 AM
frankie945's Avatar
frankie945
On your maf code. Check your data logger to make sure its still reading air temps ok. I bet it reads fine. Sence u are running on MAP now the maf code will not cause a problem.You only need it for Air intake Temps.
Old Mar 12, 2009 | 10:36 AM
down_shift's Avatar
down_shift
I still need it off for emissions though. Does the MAF have to sit in the air column??
Old Mar 12, 2009 | 10:42 AM
frankie945's Avatar
frankie945
Originally Posted by down_shift
Any DIY for this?
A normal scaner will not check the Chassis codes you need a Diagnostic tester. Any stealerships will have one. I dont think autozones testers check chassis codes. I would call around maybe you can have someone scan it gor free.
Old Mar 12, 2009 | 10:47 AM
frankie945's Avatar
frankie945
Yes, because it also reads air temps. You can delete the whole Maf and go with the haltech AIT sensor. I plan to later down the road.
Old Mar 12, 2009 | 11:00 AM
down_shift's Avatar
down_shift
You can't do that.. Even with the AIT Haltech you will need the MAF in there to get some sort of reading or you car will be dumping fuel not getting a AIT reading to the ECU. (ECU still needs the OEM MAF for that.. or spliced from a aftermarket AIT sensor). I didn't want to go through with cutting more stuff up so I just left the MAF connected to its harness.
I have both in my car right now but the MAF is ziptied in the engine bay not in the actual piping.. Car ran fine for 350 miles like this. I am getting a CEL now after I reset the ECU..
(This was all verified through Hal)
/offtopic
Old Mar 12, 2009 | 12:02 PM
frankie945's Avatar
frankie945
/offtopic
Right, you still need the maf harness just to splice into to send signal, that's it, I believe. Your car is tuned on MAP correct?
One more thing that would cause the VDC SLIP light to stay on is the crankshaft position sensor But I guess you are not getting that code either. I have read that they start to go out after 70,000 miles.
Trying to trouble shoot myself not getting the crankshaft position code but going to change it out anyway. I have a little over 70,000 miles on my Z.
Old Mar 12, 2009 | 12:14 PM
down_shift's Avatar
down_shift
No CEL's just the 0201. I'm tuned on MAP via Haltech
Old Mar 12, 2009 | 12:18 PM
terps's Avatar
terps
wrong thread -edited
Old Mar 14, 2009 | 01:39 AM
down_shift's Avatar
down_shift
Plugged in another MAF tonight.. same problem.. funny thing is.. I pulled the MAF off completely and it idled better ?!!?!?
noticed it only idles all jumpy and stalls when it's a rough start. If the car turns over immediately, the idle is a little better.
I'm dumping alot of gas since I lost half a tank to 70 miles of driving L:AKSDLAKSJ
Gonna look into it more tomorrow..
WHERE THE F IS THE MAF VOLTAGE LOG IN THE HALTECH DATA LOGS?!?! I can't find it..
Old Mar 14, 2009 | 01:35 PM
down_shift's Avatar
down_shift
Mm got P0202 now also.
Old Mar 20, 2009 | 08:05 PM
down_shift's Avatar
down_shift
If anyone was wondering, I fixed this problem by putting a MAF weld on adapter into the charge pipe. Keeps the stock ECU happy now. Car pulls like a **** with traction only in 6th gear lol
