VDC, Slip, p0201 All on?!?!
Old Jun 12, 2009 | 11:55 PM
deanfootlong's Avatar
deanfootlong
so you got the ses code p0102, vdc, and slip light because of the maf not being welded on to the charge pipe??
i just did a greddy tt install on my car. instantly got the ses light p0102, vdc, and slip light on. wondering how to get rid of it. im using a haltech and tuning by map sensor. just not sure how to get rid of the SES and those lights.....
anyone? by putting the maf into a welded placement on the chargepipe doesnt seem like it would be any different than what i currently have set up (using the stock maf and greddy couplers to incorporate the stock maf and housing in the plumbing.
any help?
Old Jun 13, 2009 | 04:01 AM
doug's Avatar
doug
any help?
just a shot in the dark.. but are you sure the MAF is plugged back in?
Old Jun 13, 2009 | 05:07 AM
down_shift's Avatar
down_shift
Make sure the MAF is facing the right way. After checking if the map is installed correctly, reset the ECU. it won't fix itself unless you reset the ECU. I might be wrong but the Haltech and ECU still need a good reading after a reset to be stable afterwards.
Old Jul 14, 2009 | 05:39 PM
Kal_El's Avatar
Kal_El
edit* not the same issue
loudtoyz
Apr 6, 2023 04:52 AM
aarrgghh
May 1, 2022 11:04 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Paul.
Oct 16, 2015 07:34 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
