Turbonetics vs. Vortech need your opionions!
Old Apr 8, 2009 | 09:28 AM
  #81
tylerxfire's Avatar
tylerxfire
Originally Posted by 350z006
Hmm...I don't know if you could adjust you fmu for the bigger injectors...
I would just get the walbro in-tank pump and remove the fmu/inline pump altogether...besides, removing the ss box will also remove your control of the fmu/inline tank anyway right?
The walbro in-tank install is fairly easy to do DIY...phunk has a great DIY for it on the forums...
yeah i hear ya...i was just kinda wondering if i could stick with some of the things i have instead of ditching them with that osiris and if osiris could control the fmu and inline pump...im gonna have to look into it more....yeah the intank install is nothing guess im gonna have to start making some calls
Old Apr 8, 2009 | 10:20 AM
  #82
sentry65's Avatar
sentry65
the burninator
I would so go with the orsiris over pretty much any other EMS out there for the vortech because of how elegant it is and how well it does the job, but I have no idea if it can control the inline fuel pump...my hunch is it can't, so it'd probably be better for people with larger injectors, walbro, and return fuel system
Old Apr 10, 2009 | 09:59 PM
  #83
03Zilverstone's Avatar
03Zilverstone
I have to rebute myself in this thread. I had always wanted the TN because of the low end torque. However when searching stock build dyno charts I started seeing HP and TQ numbers fairly even until around 4K rpm between the Vortech and TN. It looks to me like the TN only has the advantage from around 4K until around 6K.
Old Apr 11, 2009 | 11:15 AM
  #84
zmedic16's Avatar
zmedic16
8psi vortech vs 8psi turbonetics =turbo wins.
Old Apr 11, 2009 | 11:45 AM
  #85
sentry65's Avatar
sentry65
the burninator
that's true
Though people should consider how often you see TN people go above 8 psi vs how many vortech people go above 8 psi, especially with a stock engine.
IMO the bone stock vortech kit with the stock pulley will lose to just about every FI setup out there, except maybe stillen stage 1 or 2.
It's still going to depend on the car and tire setup. An 8psi TN car will need better traction to make any use of the tq in 1st and 2nd gear than an 8 psi vortech
Old Apr 11, 2009 | 11:50 AM
  #86
sentry65's Avatar
sentry65
the burninator
I always thought the TN kit had stronger power below around 4500 rpms than similar spec'd vortech cars, but were about even above that
Old Apr 11, 2009 | 02:36 PM
  #87
tylerxfire's Avatar
tylerxfire
driver wins that race, and who runs 8psi????????? especailly vortech guys....yeah the turbonetics has the bottom end, but i guarantee the vortech has more above 4500 rpm with just 3.12 pulley added to a complete vortech kit...id race a turbonetics 8psi z anyday with my current setup..i beleive it would come down to driver from a dig and i beleive i would pull a turbonetics 8psi car from a roll...who knows though im like the only z in my area...let alone to find a turbo one to mess around with
Old Apr 11, 2009 | 05:31 PM
  #88
03Zilverstone
Here are the dyno charts I was making reference to at the time. Everything almost lines up until 4500 were the TN takes over.
TN
Vortech
Old Apr 11, 2009 | 05:38 PM
  #89
Chef-J's Avatar
Chef-J
Booooosstt!!
Changed, much better competition Same dyno.
That's mine, mods follow here https://my350z.com/forum/shop-builds...non-revup.html
TN
Vortech
Old Apr 11, 2009 | 05:41 PM
  #90
Chef-J's Avatar
Chef-J
Booooosstt!!
Turbo brings more TQ and whp, but i don't see why vortech will get behind on street
chefj
Old Apr 11, 2009 | 05:42 PM
  #91
03Zilverstone
That's crazy. I just commented in there at pretty much the same time you posted here. I think my mind may be swaying here from my recent research.
Old Apr 11, 2009 | 06:15 PM
  #92
03Zilverstone
Here's a chart I just fixed up using those two graphs. Like I saw in the other two, they're neck and neck until around 4k were the TN takes over.
Old Apr 11, 2009 | 06:27 PM
  #93
tylerxfire's Avatar
tylerxfire
another to compare
Old Apr 11, 2009 | 06:29 PM
  #94
tylerxfire's Avatar
tylerxfire
turbo's got the torque hands down, but is it usable on the street? cause i know my 300ft. lbs. at 4000 rpm is useless in the lower gears...vortech seams to be great at mid and top end power and pretty safe, once the pulleys start dropping seems to give soem good power and with the 2.87 torque is higher and starts hard at like 3700 rpm
Old Apr 11, 2009 | 06:33 PM
  #95
tylerxfire's Avatar
tylerxfire
different dyno's different numbers...cant go by that
Old Apr 11, 2009 | 06:51 PM
  #96
03Zilverstone
In the chart I typed up they're both from the dyno at Injected.
Old Apr 11, 2009 | 11:13 PM
  #97
sentry65's Avatar
sentry65
the burninator
IMO that looks like a pretty strong TN car vs a 3.12 pulley vortech that are on the same dynodynamics dyno there.
I have a ton of dynos I can pull out that I've kept over the years organized by specific shops. From what I've seen, the TN starts losing steam up high, and the vortech can catch up to it
IMO the results in first gear will be almost negligible between the two since you go through 1st so fast, you hardly have time for the TN to spool up early.
Look at the drag racing times in the drag race forum....the vortech and TN can be fairly well matched in the hands of a good driver.
Old Apr 12, 2009 | 12:12 PM
  #98
diwun67's Avatar
diwun67
I'd run you from a dig, a roll, and at the track. Too bad you're up there
Old Apr 12, 2009 | 01:59 PM
  #99
tylerxfire's Avatar
tylerxfire
trust me man, id love to get the shot to even compare or ride in another boosted z...i don't even see any z's around my area...actually saw a g35 today, but bone stock , old dude drivin...if im lucky enough to pass a z its from out of state or old people and bone stock..
Old Apr 12, 2009 | 02:00 PM
  #100
tylerxfire's Avatar
tylerxfire
i would be at about 425whp ish, but i gotta get my DW 600cc's in and drop to the smaller pulley and get retuned...it should be done within the next month..
