smalltuners |DevilŽ| is back !!!!
Old May 6, 2009 | 01:33 AM
  #121
BaZooKa's Avatar
BaZooKa
Originally Posted by midz350
Its 114 lb for one box and 62 lb for the other one as Aramex says this morning.
Great if so aramex will charge $600 as mentioned, they have 1 tracking number right? cuz if they have more than 1 tracking number aramex wont ship the 62lb box threw cargo,they will ship it threw frieght.
Old May 6, 2009 | 01:40 AM
  #122
BaZooKa's Avatar
BaZooKa
Originally Posted by SmallTuner
ehehehe care for another race ... ???
u did pased me but we can race after i install my turbos
LOL yes i will race you after your turbo's , but i dont think you will beat me
Old May 12, 2009 | 02:48 PM
  #123
SmallTuner's Avatar
SmallTuner
Default Update
i just started today , the motor is out now
turbos and manifolds are gonna be installd tomorrow.
Old May 12, 2009 | 03:13 PM
  #124
SmallTuner's Avatar
SmallTuner
ill get some more pics soon
Old May 12, 2009 | 04:38 PM
  #125
str8dum1's Avatar
str8dum1
its dirtyy as heck over there in the desert i cant imagne what your airfilters must look like. I;d be using a pre-filter sock as well!
Old May 12, 2009 | 07:40 PM
  #126
midz350's Avatar
midz350
UPDATE about Aramex prices:
they said it will be $750 but I'm sure it will be $100-200 less than that.
with Aramex you never know until the shipment is arrived.
Old May 12, 2009 | 10:33 PM
  #127
BaZooKa's Avatar
BaZooKa
Congrats More pics and updates
Midz350, dont forget to confirm with us
Old May 13, 2009 | 02:44 AM
  #128
SmallTuner's Avatar
SmallTuner
ehehehe,
i had a hard time cleaning it today
Old May 13, 2009 | 03:28 AM
  #129
SmallTuner's Avatar
SmallTuner
Default Updates
ok guys
oil pan has been removed,
im going to the machine shop to install the oil fittings.
allso i need to go for nissan, some gaskets has to be changed.
im working 20 hours a dayu alone on the project
some pics ...
Old May 13, 2009 | 04:24 AM
  #130
Blackbird CPV35's Avatar
Blackbird CPV35
take good notes, i will be doing this next week and I need to know any problems you encounter
Old May 13, 2009 | 12:50 PM
  #131
SmallTuner's Avatar
SmallTuner
ok
everything still easy.
ill post some pics tomorrow
Old May 13, 2009 | 01:19 PM
  #132
BaZooKa's Avatar
BaZooKa
Cant wait to see the final product ,, GL and Keep us updated with alot of pics
Old May 13, 2009 | 01:46 PM
  #133
SmallTuner's Avatar
SmallTuner
some things need to be done after installing the turbos
banjo bolt(water lines), and oil fittings has to be installd after fixing the turbos to the manifolds.
if u did the APS extreme install, the GTM gonna be easy.
Old May 13, 2009 | 02:15 PM
  #134
ttg35fort's Avatar
ttg35fort
Professional
This is going to be a BEAST.
Garrett 3076 turbos on a sleeved motor = Big, Big Power.
Good luck with the build. I can't wait to see this thing running.
Old May 13, 2009 | 02:21 PM
  #135
ttg35fort's Avatar
ttg35fort
Professional
I just took a look at the build again. Do you have room for another oil cooler? Might be a good idea since you are running a sleaved motor. If you do, run them in parallel (i.e., use T fittings to run roughly 1/2 the oil through each cooler). If you run them in series, you may lose too much oil pressure. Just food for thought.
This thing is going to be FAST!!!
Old May 13, 2009 | 07:10 PM
  #136
Blackbird CPV35
The hardest part of the APS Extreme was the downpipe was one piece and it took alot of talent to get the DP to turbo flange bolts tightened
Does this kit have a 2 piece dowpipe, aka a short elbow extention then a longer downpipe that goes to the factory exhaust location?
Old May 13, 2009 | 10:05 PM
  #137
Chef-J's Avatar
Chef-J
Booooosstt!!
Don't forget to order bigger tires or wider wheels/tires
Good luck! that thing will fly!!
Old May 14, 2009 | 03:58 AM
  #138
SmallTuner's Avatar
SmallTuner
thanks
i dont have room for another oil cooler.
Old May 14, 2009 | 04:01 AM
  #139
SmallTuner's Avatar
SmallTuner
its a 3' long down pipes, i think its same as APS
sure man
Old May 14, 2009 | 04:03 AM
  #140
SmallTuner's Avatar
SmallTuner
Default Update
turbos and water, oil lines are installd now.
the engine is ready to go back in the car.
