turbonetics oil in intercooler and intake piping?
Old Apr 20, 2009 | 01:18 PM
bldg250z's Avatar
bldg250z
Default turbonetics oil in intercooler and intake piping?
a few weeks ago i bought a used turbo from a friend in decent condition... after installing the car started smoking at first i thought it was my engine that i might of fried a ring or something as time went by the smoking increased i removed the turbo and found driping oil from the air downpipe to intercooler and more in all the tubing leading up to the intake..... i found no oil in the exhaust piping coming from my headers so please let me know if these are symptoms of my turbo seals going bad and if anyone knows who fixes them let me know turbonetics is charging over 400 just to replace the seals...
thanks
Old Apr 20, 2009 | 02:13 PM
350 Rookie's Avatar
350 Rookie
Seals.
Old Apr 20, 2009 | 02:24 PM
str8dum1's Avatar
str8dum1
+1 on seals.
thats not really decent condition then. nor is it really a friend.
there are other turbo rebuilders that maybe cheaper. i'd check around
Old Apr 20, 2009 | 02:25 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Bad turbos.....sorry you got stuck with the TN kit. I predict a viscous cycle of smoking turbos, and bad seals. Aside from checking all the usual things, like proper oil drain, I can't think of anything else.
Old Apr 20, 2009 | 02:27 PM
Spork's Avatar
Spork
Damn, so I take it I shouldn't even consider a turbonetics kit?
Old Apr 20, 2009 | 02:29 PM
Chasecbc's Avatar
Chasecbc
Im looking to buy a ST kit and I keep seeing TN kits for sale for pretty cheap, are they worth buying and then switching out the turbo for something better? Or just wait until i find a Aps in my price range?
Old Apr 20, 2009 | 03:03 PM
Sharif@Forged
Forged Performance
^^^Neither choice is a good one^^ Don't even get me started with the APS Single T.
I would look at Powerlab for Single T, or Greddy, GTM, for TT's.
Old Apr 20, 2009 | 03:27 PM
terps's Avatar
terps
im sure that wont happen since you wont even reply to emails regarding your aps single upgrade ....
lol sorry had to im a little bitter
Old Apr 20, 2009 | 04:58 PM
Sharif@Forged
Forged Performance
LOL...I reply once...but I refuse to have a back and forth discussion about the APS Single T kit...LOL. Call it writers block..or mental block.
Old Apr 20, 2009 | 07:49 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
sorry to hear about your turbo, you might need to dish out $$$ for a new one :X
Old Apr 21, 2009 | 07:13 AM
bldg250z's Avatar
bldg250z
is it worth paying 400 or 500 to get turbo seals redone or should i invest the 1400 for a new one of course keeping my car parked for way longer period of time to come up with the money!
Old Apr 21, 2009 | 07:18 AM
bldg250z's Avatar
bldg250z
also someone else told me that it might not even be the turbo that it might be a block internal but how can that be if there is so much fresh oil in my piping but none coming out of my headers... how else will oil go into the intercooler piping if not thru the turbo...????? this guy i think knows wat hes talking bout but what do you guys think!?
Old Apr 21, 2009 | 07:32 AM
JETPILOT's Avatar
JETPILOT
I went through 3 turbo's in about 23,000mi with my Turbonetics kit. My turbo wasn't liquid cooled. I don't know if the liquid cooling mod keeps the seals from failing, but I wouldn't install it without the liquid cooling once it's repaired. You just need a rebuild. Try Forced Performance for the rebuild. I don't know if they rebuild those turbo's, but if they do I would send it to them.
Old Apr 21, 2009 | 08:12 AM
frankie945's Avatar
frankie945
The only problem with the TN kit is the AC line and down pipe. It is a good kit If you want just 400whp.
Did you use a spacer or did you drill your block? Most people use spacers so they don't have to drill there block. The drain line is very important on Turbonetics in drains off gravity. I drilled my block and have the water cooled jacket. Great power but no AC...
Old Apr 21, 2009 | 08:16 AM
BoostedProbe's Avatar
BoostedProbe
You didn't drill your block, you drilled your upper oilpan.
Old Apr 21, 2009 | 08:20 AM
frankie945's Avatar
frankie945
what ever upper oil pan ^ that's what I meant
Old Apr 21, 2009 | 08:25 AM
BoostedProbe
I only mention it so other don't freak out about drilling the "block". Because nobody would do that.
Old Apr 21, 2009 | 08:28 AM
frankie945's Avatar
frankie945
I hear yea, on lunch type fast sometimes. My mistake. Good look out...
Old Apr 21, 2009 | 08:44 AM
z33boi's Avatar
z33boi
if the seals are bad, will oil get to the intercooler piping only in boost or can you see signs at idle also?
Old Apr 21, 2009 | 09:16 AM
frankie945's Avatar
frankie945
under boost it will smoke like a ****. If the seals are totaly out it would probably smoke at idle. Where is your oil drain going? to a spacer or upper oil pan? Because if the oil is not draing correct you will have blow by like u are describing. The line needs to be a sraight shot no bends.
