turbonetics oil in intercooler and intake piping?
Old Apr 21, 2009 | 09:17 AM
frankie945's Avatar
frankie945
[QUOTE=frankie945;7233434]under boost it will smoke like a ****. If the seals are totaly out it would probably smoke at idle. Where is your oil drain going? to a spacer or upper oil pan? Because if the oil is not draing correct you will have blow by like u are describing. The line needs to be a sraight shot no bends. drain should be right above oil level in the pan.
Old Apr 21, 2009 | 10:13 AM
z33boi's Avatar
z33boi
my oil drain is going to a jwt oil spacer. its not completely straight but damn close.
Old Apr 21, 2009 | 11:57 AM
JETPILOT's Avatar
JETPILOT
I found the oil drain location to be of no importance to the condition of the seals. You can drain either to an oil pan spacer or the upper oil pan. It makes no discernable difference.
Old Jul 11, 2009 | 10:57 AM
erichsherrill's Avatar
erichsherrill
If it is bad seals, oil leakage from the turbocharger seals can be caused from and number of conditions, below are the most common.
1.Excess engine cranks case pressure
A.due to poor crankcase ventilation like a plugged or improperly working PCV (positive crankcase ventilation) system or an open port from the intake manifold to the crankcase.
B.Excessive engine blow by due to worn engine components
2.Too small of an oil return line, preferably ¾” to 1” minimum inside diameter
3.Oil return line routing is critical, there can be no sinks/traps and oil must return above the oil level in the crankcase.
4.Blocked oil drain at turbocharger or crankcase caused by incorrectly installed oil drain gasket or excessive use of silicone gasket material protruding into the oil drain flow path.
5.Air filter restrictions (too small or dirty) will cause a restriction and contributes to excessive amount of vacuum on the compressor end seal causing oil to be drawn past the seals.
PN
Old Jul 12, 2009 | 07:42 PM
bldg250z's Avatar
bldg250z
PN
OK .... thanks for all the feed back i actually found that my oil in my IC and piping was coming from my pcv line (drivers side) that would connect to my air filter connected to my blower on my turbo ..... now i must imagine that this blow by is caused during boost cuz it wont leak at idle or reving but it definately has oil leaking thru there.....
now one of my cylinders lost some compression so i know my rings where going so would that be the cause of this blow by?????
Old Jul 13, 2009 | 05:41 AM
str8dum1's Avatar
str8dum1
^of course!
lost compression = blowby
Old Nov 22, 2014 | 11:50 PM
che69velle's Avatar
che69velle
What's wrong with aps? I have their twin kit and same problem. it smokes after boost, not before or during.
Old Nov 23, 2014 | 09:53 AM
Conway_160's Avatar
Conway_160
What color is the smoke? Black is normal'ish on boosted cars.
Old Nov 23, 2014 | 03:42 PM
che69velle's Avatar
che69velle
Smoke is white but oil level is not changing.
Old Nov 23, 2014 | 06:06 PM
Conway_160's Avatar
Conway_160
How long have you been watching your oil level? Do a compresion test and see if any are low on compression.
Old Nov 23, 2014 | 08:28 PM
che69velle's Avatar
che69velle
Since I got the car. Compression is good, turbos are fresh, had a tuner tell me its cause I have no back pressure, the 3.5" monster down pipes and race exhaust suposedly cause vacuum and pull oil into intake from pcv?, there is oil in the ic pipes. So that may be the cause of it, but she still has same oil level. If I drive around normal, no smoke, in boost no smoke, in boost with up shift and more boost, no smoke. Take foot off pedal and let it roll after boost, one smart car size puff of white smoke and then no smoke.
Old Nov 24, 2014 | 07:04 AM
Conway_160's Avatar
Conway_160
Put a Catch can in, see if that fixes your problem.
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
