what will I have to upgrade after HRTT 6-7psi? Recommendation
Old Apr 23, 2009 | 01:23 AM
Germanguy's Avatar
Germanguy
Default what will I have to upgrade after HRTT 6-7psi? Recommendation
After the forced-induction for noobs thread and other themes I need a recommendation from you how everything will last longer .
-I have a 07 hr Base model
-Im getting my Gtm Stage 1 turn key kit
-will drive the kit with 6-7 psi 420-450 hp on stock internals/block
-not driving track
I have
-Big rotora brakes
-better clutch rated for aprox 500 hp
-oil cooler (19 row) and gauge
-zeitronix wideband lambda, egt and gauge
-bigger headers from Gtm kit, testpipes 3", catback 3"
What do you recommend, what I should upgrade next ? I have some doubts about the differential? will it hold max 450 hp?
Thanks!
Alex.
Old Apr 23, 2009 | 02:41 AM
0jiggy0's Avatar
0jiggy0
Sp used the diff on their (1300?) HP car, youll be fine. WHat kind of tires are you running?
Old Apr 23, 2009 | 03:45 AM
KS0385's Avatar
KS0385
oops, nevermind.
Old Apr 23, 2009 | 03:49 AM
Germanguy's Avatar
Germanguy
you sure, that this is the diff they used!?! remember I have the base model.
-> tires shouldnt be a problem:P
Sf-challenge
9.5 +28 265/30/19 michelin pilot sport 2
10.5 +23 295/30/19 "
Old Apr 23, 2009 | 04:41 AM
marra23's Avatar
marra23
not much if your gonna stay at 6-7psi.
Old Apr 23, 2009 | 04:59 AM
RandomHer0's Avatar
RandomHer0
Clutch, wideband and exhaust.
Old Apr 23, 2009 | 10:46 AM
Cass007's Avatar
Cass007
Injectors and fuel return system if you really want, but you are probably just fine with the setup you have right now for the power you are looking to make.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
apex locator
Jul 23, 2021 02:27 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
