Procharger - Anyone running 12PSI without breaking belts?
Old May 10, 2009 | 02:31 PM
Boostedtrack350's Avatar
Boostedtrack350
Default Procharger - Anyone running 12PSI without breaking belts?
I did a search and found several Posts about this, but never learned if anybody figured out how to run more than 9 PSI without breaking the belts?
I know about the AAM Procharger brace. Has anyone had any success with different brand belts?
How much PSI are you running with your Procharger?
Thanks!
How long before Jay'Z tells me to buy Twins? LOL I wish I could Jason!
Old May 10, 2009 | 03:10 PM
str8dum1's Avatar
str8dum1
why are they breaking belts? I saw that video of the brace flexing alot maybe causing the belts to stress and release.
cog belts are pretty stout. It must take a lot of crank HP to turn that charger at 12psi, if its enough to snap belts.
Old May 10, 2009 | 03:42 PM
Zbee's Avatar
Zbee
I run a 9 lbs. pulley Procharger and AAM brace. My Z is solid and reliable. I have not gone with the 12 lbs. pulley because of all the threads I have read where the engine has blown or the belts have shreaded. I am quite happy with the 9 lbs. setup. Remember, Your Z will never be a Corvette or a Viper. I am just happy being able to blow-away the Mustang GT crowd which my Z easily can do. Instead of fooling with the 12 lbs. pulley, I would recommend going with a turbo if you want more power. From reading these threads over the past few years, I think turbos have a higher success rate over the long-run. You will have to significantly build-up your engine though. And this will cost you big $$$. Best Regards, Zbee.
Old May 10, 2009 | 05:28 PM
Boostedtrack350
Thanks for the input. How much power are you making with 9lb Pulley setup?
Old May 10, 2009 | 06:33 PM
Zbee's Avatar
Zbee
~400whp
Old May 10, 2009 | 07:01 PM
fstrnldr's Avatar
fstrnldr
I'm guessing you just offended a lot of people on here
Old May 10, 2009 | 07:11 PM
Zbee's Avatar
Zbee
My buddy has a corvette. It's fast. My Z handles better, and think the Z is better made. But the vette is definately faster, stock. If he modded it up, it would only add to my frustration. No offense intended, I love my Z.
Old May 11, 2009 | 06:09 AM
Boostedtrack350
No offense taken. I'm hoping for a little over 400whp, but I'll be happy with anything 400+. I'm gonna order some stronger belts and hope for the best!
Old May 11, 2009 | 11:08 AM
Boostedtrack350
Seems like, If the problem is the bracket Flexing. why couldn't you have that piece made out of a stronger metal? Even if its heavier it would be worth it because of the ability to make more boost.
Anyone? Anyone?
Old May 11, 2009 | 11:13 AM
Nexx's Avatar
Nexx
just fkn get the AAM bracket already!!! lulz.
Old May 11, 2009 | 11:49 AM
Boostedtrack350
I have the AAM Bracket!! But that does not fix the problem. It makes it better but still has enough flex to pop belts at anything above 10psi.
My question was...Does anybody know if having one made out of a stronger metal would work?
Old May 11, 2009 | 11:51 AM
Nexx's Avatar
Nexx
hrmmm... maybe ask AAM if they can make you one using a metal?
Old May 11, 2009 | 01:51 PM
Jay'Z's Avatar
Jay'Z
Lulz.. You guys wont listen, been there done it..
Go TT!
Old May 11, 2009 | 02:27 PM
Boostedtrack350
Go TT!
So you made the bracket out of steel? I dont remember reading that in any of your post. If not, Do you think it will work? If not, why?
I am trying to work with what I have bro, If I had the money I agree TT is the way to go.
Old May 11, 2009 | 04:21 PM
Zbee's Avatar
Zbee
You're playing with fire, man. Stay under 10 lbs. of boost. If you don't have $$ for a TT, do you $$ for a new engine? Just be careful. Ever heard the sound of an engine throwing a rod? Believe me, you won't forget that sound! Best Regards.
Old May 11, 2009 | 04:44 PM
Boostedtrack350
I'm pretty sure my motor can handle it. Here is my setup. When I started this, I was planning on a Stock block build. Long story short...I ended up with a built block and a Procharger. I just dont have the $$$ to sell the Procharger and buy the TT setup. I'm just trying to make the best I can with the Procharger for now, but my block will hold way more than 400WHP.
ATI Procharger W/Intercooler C2 Blower 12-14 PSI
AAM Supercharger Brace
Wiseco 96mm/8.8:1 - VQ35
Eagle Rods
Machine Work - Block inspected and cleaned, Block Redecked, Block Bored and Honed using a Torque plate, Rotating assembly balanced, Crank Magnafluxed and the journals micro-polished, & Block prepped and assembled
ACL Trust Washers - VQ35
ACL - Main Bearings(STD) - VQ35
ACL - Rod Bearings(STD) - VQ35
HKS Headgaskets - VQ35
L19 Head Studs
Main Stud Kit - Nissan VQ35
Machine Work - Heads inspected and cleaned, Heads Redecked, Ported exhaust and intake runners, 3 angle Valve job, Valve stem heights set, Cold Clearance set for stock cams, & Heads prepped and assembled
Viton valve seals - Nissan 300zx
Engine gasket Kit - VQ35
JWT HD springs/shims - VQ35
VQ35 Pathfinder Rear Cooling Mod
Oil Pump - VQ35 RevUp
Polish upper Plenum and Throttle Body
5/16th Plenum Spacer
RC 650cc injectors
Turbo XS Utec with Remote Map Selector
Greddy Oil Catch Can
Walbro Fuel Pump
PWR Radiator
Evans Coolant
Old May 11, 2009 | 04:51 PM
Zbee's Avatar
Zbee
I didn't know you had all this - sorry. You're good to go. Power up!
Old May 11, 2009 | 04:58 PM
str8dum1's Avatar
str8dum1
so you already have the brace? well besides going 1 off custom, you've exhausted all the normal routes.
looks like choices are to sell or be happy where you are. why not just add nitrous?
Old May 11, 2009 | 05:04 PM
Boostedtrack350
I'm just wondering out of all the threads on Procharger belts breaking. Why nobody mentioned the idea of just making a stronger bracket that doesnt flex?
Am I missing something here?
If I'm stuck with the procharger, I might as well make the best of it!
Old May 11, 2009 | 05:05 PM
eltness350's Avatar
eltness350
The Untouchable
u kno in jay's thread he used some other type of belts that were a bit stronger...buy one of them and see what happens??
