Powerlab Dyno Video
Finally my tune is done. there is a small problem, but nothing big. the car dies after every pull because my flywheel is light and the rpm drop to fast, and my wastegate have a 8lb spring an my bov have a 4!
anyway, here is the video like i promise. hope u guys like it!!!
http://www.youtube.com/watch?v=YGbM-GqValU
Stock ECU. You can take it to dealer or i think cipher can bump your idle too ( i think only 03~04 model)
Edit: what injectors are you running with? ( sorry if i missed )
so what can this be? just the idle? right now if i let the car idle, the rpm keep going up and down from 550-700, and it sound really funny. can i be running to rich or to lean? thanks for the input
Edit: Stalling issue: I feel like It is something to do with tune. Don't get me wrong, I got the utec, 600 inject and reflash ecu. Still gotta tap it little bit, but not bad as before reflash( that is why I said bump the idle can *help*.
I looking forward to get a retune, I will see if my tuner can do sumthing about that.
I just had(?) an issue.
https://my350z.com/forum/forced-indu...vortech-3.html
i will be calling my tuner today and see what he thinks thanks everyone for the input.
btw i call nissan today and ask them about the idle, and they say the can only go up 25rpm!!!!! WTF!!!!
Your dealer can plug into your OBDII port and raise the idle to whatever they like. I went to Nissan and brought mine up from stock 700'ish to 950 rpm at idle. I only needed to do this when I first added cams to the car which makes sense. But adding a turbo alone shouldn't make it stall. Did you add cams?
might not need dealer to raise idle, if i loosen my bov spring the rpms will drop below 750ish after a blip of the throttle , a few turns and it will stay above 900rpms. give it a shot
