bolt size for jackshaft pulley on vortech
Old May 17, 2009 | 01:14 PM
binder's Avatar
binder
Default bolt size for jackshaft pulley on vortech
I purchased a used kit that "comes with every last bolt" and it was missing tons of parts.
I'm missing the bolt on the jackshaft pulley (the 3.33 pulley bolt) and it appears to be an odd size that i do not have in the shop.
I looked through the install manual for bolt sizes on the mounting plate and i think it would be the 3/8-24 1 1/2" bolt it lists but i'm not sure.
Does anyone know the size of bolt for that pulley?
Also, does it have a special spacer or anything else that goes in that pulley? I made a key out of keystock but there is a pretty big gap between the end of the shaft and the end of the pulley where the bolt goes in. Nothing else like a spacer goes in there does it?
I searched and could'nt find this anywhere. thanks for the help!
Old May 17, 2009 | 02:26 PM
coachk's Avatar
coachk
Did you try the sticky in this forum.....I didn't read all of it, but there's alot of info in there.
Old May 17, 2009 | 02:29 PM
Jeremy@Altered's Avatar
Jeremy@Altered
go on vortechs website and download the install instructions and it will tell you the size of the bolt you need.
Old May 17, 2009 | 02:44 PM
binder's Avatar
binder
ya, i read through it before i bought my kit and i just finished reading it again. No info on bolt size.
I have the install manual here in my hands. It isn't very accurate though. Some of the things i have aren't listed (and i know they are required) and the bolt count numbers are off on some of the bolts.
The reason i'm thinking 3/8-24 1 1/2" is due to the fact that they only list 1 of those and i know i'll need about a 1.5" long bolt. I also don't see any special spacers listed, but it doesn't list the spacers that it included for the pulleys (step spacers or whatever they call them in the manual).
hmm....very poor install manual. My uncle's shop is an hour away from any city that has a parts store. It's way out in the country so I'm trying to get the size before I head back over to the shop so I can save the 1 hour trip each way.
Old May 17, 2009 | 02:48 PM
coachk's Avatar
coachk
Try what Jeremy suggested or PM TIMROD1011...he is pretty up on the Vortech
Old May 17, 2009 | 04:10 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
I don't think that bolt size will be on manual since pulley is already attach to bracket, I'm not sure tho. Call up vortech for find out perfect size bolt and when you go to the store, make sure you bring a pulley and bracket with you.
Old May 17, 2009 | 05:07 PM
binder's Avatar
binder
thanks, i'll give TIMROD1011 a pm
ya, that's what i was thinking too. I can't bring it with me because it's already mounted in the car and ready to go. I also would have to drive an hour to the shop, get the bracket off the car, drive an hour back to the city to find the bolt (which the store probably will have to order) then turn around and drive an hour back to my uncle's shop to put it back together.
I love living in the country but crap it sucks for doing installs like this.
Can anyone pull their pulley bolt out and use a thread gauge on it? I couldn't read my thread gauge when i tried to put it inside the shaft.
Old May 17, 2009 | 05:16 PM
binder's Avatar
binder
TIMROD1011 is not a registered user.
hmm...
Old May 17, 2009 | 05:47 PM
OldManZ350's Avatar
OldManZ350
hmm...
I'm Timrod1011, Changed my Handle about a Year ago......
Old May 17, 2009 | 06:20 PM
binder's Avatar
binder
ah, sneaky sneaky.
Ok, i'm going to break down and call vortech. sucks....lol
Old May 17, 2009 | 06:49 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
ah, sneaky sneaky.
You gotta get use to take off bracket if you willing to replace stuff yourself in future.You can also hook up the belt like oem setup and drive to the store(that's what I did, you can just drive like normal if you still have a stock ecu.)
I can take a picture for you when I take mine out, but will be end of next week.
Old May 21, 2009 | 07:53 AM
binder's Avatar
binder
3/8-24 is the thread size for anyone else that needs to know.
