Haltech racelogic
Old Mar 2, 2010 | 12:32 PM
  #61
Faja's Avatar
Faja
Originally Posted by rcdash
The OP has - you may want to PM him.
I was thinking more along the lines of anyone is the US (sorry... I should have stated that).
Old Mar 2, 2010 | 08:08 PM
  #62
str8dum1's Avatar
str8dum1
proper tires, alignment and boost control will alleviate almost all your anticipated traction issues.
but as you have read, no one in the US has this as its a custom PnP by a UK company and not racelogic.
Originally Posted by Faja
I'm upgrading my turbos from 530BB's to 700BB's (GT28RS) and I'm anticipating that I will have some serious traction problems as a result. I can probably work a lot of the wheelspin out with my Haltech, however, the RaceLogic unit seems like a much easier system to install/adjust.
Has anyone purchased and installed the PnP version of the RaceLogic TC on a 350Z/G35 yet? I've got RC 750cc injectors (saturated) so I should be in good shape I would think.
Thanks,
Todd -
Old Aug 19, 2010 | 01:19 AM
  #63
doomsdaydonkey's Avatar
doomsdaydonkey
hi guys,
another update, I was able to download some software which allowed me to fine tune the racelogic and how it creates misfires in order to stop the wheels spinning... having the software on board shared a lot of insight on the product pnp.
firstly, it does know when you are going around corners and has settings for this...
launch control is awesome with a wet and a dry setting with a minimal speed before the misfire chart starts working...
I have 4 levels of wheel spin to play with, each has its own chart that I can adjust to cause the engine to misfire...
overall I am really happy with the unit and with the software available to customise it, it works like a charm...
still have no idea which kind of injectors I am running but it should be noted that if something is going to overheat it implies that its working consistently for a while, i do a few launches and notice it working in 3rd gears at times...
its great!
cheers
DDD
Old May 12, 2014 | 05:37 AM
  #64
Zorkan's Avatar
Zorkan
Can someone tell me, that the Racelogic TC is it compatible with the Haltech Platinum Pro Z33 standalone ECU? (It's easy if someone tells that, the Haltech has got any Missfire protection? If yes, can I disable it?)
Old May 14, 2014 | 12:28 PM
  #65
str8dum1's Avatar
str8dum1
you wire the racelogic into the ignition, so its compatible with anything, since its a standalone unit.
Old May 15, 2014 | 12:02 AM
  #66
Zorkan's Avatar
Zorkan
Thanks, today I received the official answer too. It's compatible.
aarrgghh
May 1, 2022 11:04 AM
bishop_98
Feb 7, 2016 03:53 AM
