Cosworth intake conflict
Old May 23, 2009 | 01:07 PM
kevinapex's Avatar
kevinapex
Default Cosworth intake conflict
I did a instal on Cosworth intake and it is resting on the AAM fuel rails, about 1/8" to 1/4" gap from the Cosworth to the lower intake.
I have the AAM rails spaced up to fit the full size RC 750 injectors.
The Cosworth install instructions says to stack gaskets, I dont want to make that much of a gap with gaskets.
Or use a phenolic spacer, has anyone else run into this issue?
Or used this spacer?
Thanks guys,
Kevin
Old May 23, 2009 | 01:34 PM
XKR's Avatar
XKR
Thanks guys,
Kevin
If you have aftermarket Injectors that you have to mod to get it to fit...you have to install the Cosworth with the spacers that you can buy for the cosworth.
Old May 23, 2009 | 02:20 PM
kevinapex's Avatar
kevinapex
Where can I get the spacers from? Cosworth, do you know a part#?
I not sure what your talking about? Does it space the injectors or the intake?
Old May 23, 2009 | 02:55 PM
coachk's Avatar
coachk
This is from another thread....
The reason I am asking is that with the CJ Motorsports fuel rails and HKS injectors, I needed the Injected Performance spacer between the intake runners and the Cosworth plenum to get adequate clearence for the Cosworth plenum to fit over the fuel rails
Old May 23, 2009 | 03:31 PM
ttg35fort's Avatar
ttg35fort
Professional
I also needed the Injected Performance spacer for my CJ Motorsports fuel rails with the HKS injectors.
Evidently, with Deutchworks injectors you don't need it.
Also, it is my understanding that you can use taller injectors, such as the HKS injectors, if you use the Cosworth fuel rails, but I have been informed not to use the Cosworth fuel rails if you are going for high HP. There is concern that they won't flow as well as some of the other aftermarket fuel rails.
XKR's Avatar
XKR
Exactly......thats what I am talking about. Anyone of the vendors that sells the Cosworth will have the spacer.
Old May 23, 2009 | 06:27 PM
kevinapex's Avatar
kevinapex
Nice guys, I should have known IP would have it!! thank you guys for the help>
Here is a link to the page,http://www.injectedperformance.com/e...D=10396&VID=36
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
_koubie_
Sep 20, 2015 06:34 PM
