Car continually going into limp mode???
Old May 10, 2010 | 04:39 AM
  #61
QuadCam's Avatar
QuadCam
Originally Posted by KPierson
Are you running a UTEC?
Yes....it definintely is either a UTEC and/or APP issue.
Old May 10, 2010 | 12:14 PM
  #62
wizard's Avatar
wizard
No UTEC...
To make clear, my engine actually cuts out.... and I don't think it goes into limp mode any more...
Old May 10, 2010 | 03:47 PM
  #63
skn5002's Avatar
skn5002
Originally Posted by theking
Has anyone tried running a ground strap from the utec body to chassis ground. Might be worth a try but then again I got the code when I used the emanage with the patch harness.
I might give this a try when I have time this weekend. When I installed the utec, I couldn't get the utec/ecu combo to fit correctly. I could only get one bolt on it, instead of the two. Maybe this is what is causing everything?...hopefully
Old May 11, 2010 | 04:30 AM
  #64
psychoballistic's Avatar
psychoballistic
I have all my nuts and bolts on and the issue still happens... All though the grounding factor may have some validity to it. Maybe a better ground of some sort, different wire, better grounding point, multiple grounding points?
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
Shane86
Sep 17, 2015 05:33 PM
ddegrande21
Sep 6, 2015 11:15 AM
